Metalworking. Electroplating (Electroforming), Copper Plating, Soldering, Blackening. Making: cannons anchors rims hinges by serikoff
In this video he let the object turn around for better results. Maybe a solution for you instead of the magnetic stirror.
Thanks. Yeah, I thought about that, but there's one downside: one motor = one detal... I still want to make more than just one at a time. And such a mechanism isn't that easy to assemble, since it's gears that reduce speed, and they need to be printed, and I'm too lazy.))) I just ordered a mixer for 4 euros and it's ready. ROTF
Sergey, thanks for the very detailed and educational tutorial. I appreciate the amount of time you've invested to document and share with everyone! The scientist in me makes me want to put together a shopping list and start my own experiments.
Alas, if I had any time at all right now, I'd be happy just working on my ship. With this said, I do respect those, like yourself, with the talent, patience and perseverance to do this and every fabrication task themselves.
Thanks for sharing.
Thanks for the kind words. Yes, experimenting takes a lot of time and effort, and I'm glad someone besides me will benefit from it. There's a lot about this topic online, but little specifically related to our hobby. I've tried to change that. I might not be doing everything right, but I think the result is what matters. If everything turns out the way I want, it will be worth it and I can confidently recommend it.
In this thread, I'll be detailing all the techniques I use to manufacture metal parts, as well as the following topics:
- soldering metal (what I use, how I do it, and subsequent processing)
- blackening (what I use, how, and how to achieve a natural look for cast iron and forged steel)
- electroplating or electrochemical copper plating.
*Take a few minutes to read this, and you'll be amazed, I guarantee.
So, what is electroplating? If you think it's complicated and not for you, after reading this post, you'll realize it's much simpler than you thought.
Laziness is the engine of progress. I've always looked for a way to do things faster and with less effort. So, I searched for a way to produce identical parts in large quantities. And the only way is 3D printing.
But many might argue that this isn't as authentic, that painted plastic will never look like blackened metal... and I completely agree!
But what if you coat the plastic with metal?! And then blacken it... and voila – electroplating is your thing!
So, what is electroplating? It's a method of coating one metal with another, in very simple terms. This can be used for gold plating, silver plating, zinc plating, and many other things, but we're interested in copper plating.
But! I just said it's coating another metal with metal, but what does plastic have to do with it? So, for copper plating to work, our plastic part needs to be electrically conductive. But how can we do that? One option is graphite! Regular graphite, the kind you find in pencils. But applying this powder is problematic, so there are ready-made sprays that can be used to apply a layer of graphite like a coat of spray paint.
And now our part is ready for copper plating. And if anyone thinks this is just for show and that such a part won't be able to withstand the load, it all depends on the time it takes to copper plating. The longer the process, the thicker the copper layer, and such a part can even be sanded. Next, I'll show you my experiments with loads on such parts (rims and hinges), and you'll see... no, you'll even be surprised at how durable they are!
So what have we come up with? If a part looks like metal (which it essentially is), if it bends, polishes, and blackens like metal, then what difference does it make what's inside? Many people copper-plated tin (chemically or galvanically), which is a brittle and very flexible metal. How is it any better than plastic, which is much stronger (for its intended purpose). By the way, weight (for those who prefer metal) can sometimes play a cruel joke, when a heavy cannon is torn from its carriage on a finished model during transportation due to shaking...
So, if you've read this far, I suggest you take a look at my experiments in electroforming. I'll try to explain everything in detail so that even a child can follow it. Let's go!
But first, here are some recommendations for mandatory implementation.
Protective equipment: mask, gloves, glasses.
1. Details. I glued the details made of SLA photopolymer plastic (which I printed on a 3D printer) to the CA. They need to be positioned so they don't block access to each other's side walls or touch each other. This will prevent the graphite coating from being applied properly. It's important to understand that the fasteners should be located where the part won't be visible. Large parts are best fastened at several points, preferably hidden from view and on protruding areas. I'll talk more about fasteners later. Also, closed parts (bells, buckets) need to be fastened sideways to prevent air bubbles from forming inside. This is important!
2. Graphite. Applying graphite varnish to the parts and to the adjacent wire is essential. The aerosol spray is applied like paint and is odorless, but its downside is that it's not cheap. Apply it carefully to avoid any gaps or drips. It's best to apply it once, then check everything and repeat. The layer is very thin, so it's best to apply a little more to avoid creating gaps later, but don't go overboard (again, it's not cheap, costing 17-20 euros).
3. The graphite layer is quite fragile. Don't place the part on anything rough. The holder should be designed so that the parts are always suspended and don't touch anything! You can lightly polish the surface with a very soft cloth before immersion.
Very important! You must wait until the surface is completely dry. Although graphite appears to dry within a few minutes, this is deceptive. Complete drying takes 2-4 hours! If this is ignored, the layer will be loose and fragile, the process will be slow, and a "sugar" will form on the surface.
Caution! Graphite is very finely dispersed and must be sprayed in an isolated area. If you get it on the floor, the dust will spread everywhere and be difficult to clean. You have been warned!
4. Electrical equipment. We need a DC power source. Any spare charger will do. I used a 5-volt, 1.2-amp one. This is more than enough for our purposes. We connect the positive and negative terminals of this charger to the XY-SK35H step-down converter (easy to buy on AliExpress for 10-15 euros). We'll set the desired current and volts on it (more on this device later). From this step-down converter, we need to connect two positive terminals and one negative terminal (or two negative terminals, too).
5. Anode (+). Two copper plates (pre-polished to remove oxide film with steel wool or sandpaper, important!). It's advisable to make covers out of non-woven material, like a coffee filter. This is necessary to prevent copper debris from getting into the solution (see below for the importance of this). The plates should be above the solution level, and the contacts with the wire should be on the surface.
6. It's best to secure the plates with clothespins for stability. They should be positioned so that they are directly opposite each other. The container should be larger than the volume of the solution. For 1 liter of solution, use a 1.5 liter container.
7. The details should be arranged in layers but in the same plane! Nothing should be loose or protrude beyond the main plane (very close to the plates). It's advisable to make sure the entire plane can rotate or periodically stir the solution. Ideally, connect an automatic stirrer or an aquarium pump.
Again, the sedimentation rate will slow if the solution isn't stirred. The copper will settle to the bottom, and the process will take a long time. To ensure the copper is distributed evenly throughout the solution, the solution must be constantly moving. Either stir it regularly or install an automatic system to stir it for you.
8. Cathode (-). The negative terminal must be connected to the wire with our components. The distance from the copper plates must be the same for all components. The components should never touch the copper plates. (You can make two negative terminals, and run another one to the other side; that's what I did.)
9. Solution. I bought a ready-made one, which I recommend. It's an acidic solution for bright copper plating. You can try making it yourself, but you'll need pure copper sulfate (not agricultural grade), sulfuric acid (battery grade), alcohol, salt, and thiocarbamide. But if you buy everything, the cost will be more than a liter of the ready-made solution. Yes, you'll end up with five times more raw materials, but why bother? This solution has no expiration date, and with filtering, one liter is enough for many models. Look for it in specialized stores where jewelers shop; it costs 5 euros.
10. Converter settings. This type of equipment is quite expensive if it is professional. I bought this device for 12 euros. Look for the XY-SK35H on AliExpress. How to set it up: 1) connect to the network (+- wires from the power supply), 2) turn on the Power button (ON), 3) then press SW and make sure that "IN" is NOT there, that is, so that we see the outgoing settings and not the incoming ones, 4) press V / A and in the set cv (00.00) setting, set 02.00 Volts (this parameter is not mandatory, it will automatically change as needed depending on the Ampere, but the upper limit can be set to 1-2 V), 5) press V / A again and in the set cc (0.000) setting, set 0.080 Amperes! This is important, not 0.8 but 0.08!! This parameter is the most important. 6) after inactivity, the settings will be saved. Done.
These parameters aren't universal, but rather an example with this number of parts!
You need to calculate according to the following principle:
- Start and until complete copper plating - 0.01-(0.02) Amps per square centimeter.
- After the entire surface is coated - 0.02-(0.03) Amps per cm². (But you don't have to change this if you're not in a hurry).
How to calculate the area of the detals: Take the part and draw the outlines of all the surfaces that will be copper-plated around it on a piece of paper. If the part is a cylinder, mentally unfold it into a single plane. Add up the area in square centimeters. For me, it was approximately 2 x 4 = 8 cm, 8 x 0.01 = 0.08 Amps. This step is very important for selecting the current.
11. After an hour, you can slightly increase the current (amperes. Volts are set automatically; if there are more parts, you can set the maximum to 2 volts). This isn't necessary if you're not in a hurry, but since I added a coin and a pendant to the copper plating, I increased it to 0.1 amps. After the entire surface of the parts is copper-plated, you can increase the current to 0.02-(0,03) amps per cm², but this isn't necessary.
It's important to understand that: 1) if the current (amperes) is low, the process may proceed very slowly or even stop. 2) if the current is high, the copper plating rate will be higher, but there's a risk of localized thickening and pimples. The current should be optimal, closer to the values I listed above. If the part is very complex and its area is difficult to calculate, increase the current by 5-10% every half hour and monitor the progress. If it speeds up and there are no artifacts, repeat, but do not increase it too quickly or too much and check constantly, especially during the first attempts.
12. Process. The gun was copper-plated for over 6 hours, and the small parts for up to 5 hours. In the photo above, you can see how the copper gradually crept up onto the parts, covering them. However, one hinge (3rd from the left) and one middle rim didn't even begin to coat for almost 3 hours... I was beginning to think there was a gap in the graphite coating, but after 3 hours, these parts finally started to coat. Apparently, the copper bypassed the gap, or other parts absorbed all the current. So don't panic if you don't see anything. Hold a flashlight to the wall, and you'll see the copper growing.
13. This is the result after 6 hours of crawling and +14 hours of subsequent copper plating.
Unfortunately, I forgot to rotate the coin in the holder, and as the character in "Pirates of the Caribbean" said, the coin became part of the ship. It was firmly attached to the holder. To prevent this, you need to rotate it every couple of hours.
This result could have been achieved faster, but I decided to try the slower method to achieve the most even layer. Now, we'll speed things up.
14. Filter. Here's a clear example of why a filter is needed. After use, the plates should be rinsed with running water and the filter washed. Before the next use, the plates should be treated with steel wool.
15. Layer thickness. Depending on the copper plating time (in my case, it was 6 hours of layer growth and +24 hours of layer buildup), you can build up the thickness of a sheet of paper—0.1 mm or 100 microns. While this may seem like very little, this thickness isn't really necessary. 50-60 microns is sufficient to safely grind and polish the part. And at a thickness of 60-100 microns, the part's strength is simply incredible, but the burrs increase and the geometry changes. More on this later.
16. I forgot to remove the copper from the water after rinsing, and it turned out like this. The colors are simply stunning...
But that's not a problem. It's just oxide, and it can be easily removed with steel wool. But there's a catch, and I'll explain it in detail below!
17. Artifacts. Waves or burrs, as I understand it, appear more often on the top, so it's better to place the part upside down. To prevent this, stir the solution or rotate the part regularly. Pimples or growths (like coral) are caused by high current. (I try to avoid this. It's better to go slower, but then there won't be any extra work when sanding.) But even if these appear, copper sands perfectly with sandpaper and polishes with steel wool (but I'll explain more about polishing below!)
In this way, as you can see, you can copper plate any metal, from jewelry to coins.
For comparison, the original 1 hryvnia coin is on the left, and the copper-plated one is on the right. If you'd like, I'll coat it with a green patina to achieve an antique look; more on that later.
18. Strength. I tested parts with a 0.1mm layer thickness. They were so stiff in bending that they couldn't be compared to regular copper. I could almost reach a 90-degree angle before the part broke. But bending at 50-70 degrees was completely straightforward. I tested the tear-off strength of a rim of similar thickness. It's a shame I didn't have one with the ring raised, so I could have tested it more accurately. Even so, it's clear that the rim easily withstood over 4 kilograms and broke at 5. I'm sure it would have withstood even more if it hadn't bent from a "flat" position. But then, the glued joint might not have held up. It could have simply torn away from the hole (wood or glue). But even if we take this figure into account, I'm not sure most of you have a model that weighs even as much as this rim alone. Therefore, I think, for those who want strength (although I am sure that half will be more than enough) - you can safely build up 100 microns, but there is one But!
19. Geometry. Due to the increased layer thickness, especially on small parts, changes in geometry will be visible. Edges will thicken and round, and textures will become smoother.
In the photo: on the left is a 0.4 mm thick plastic part. In the center is a 50 micron copper layer, on the right is a 100 micron layer. (*Painted plastic rim).
If strength and thickness are required, then this should be calculated as much as possible during modeling and taken into account when constructing the geometry; this will avoid problems. If the layer thickness is not too thick and extreme strength is not required, a 30-40 micron layer can be used - that's a third of a sheet of paper - which, with ideal geometry and minimal sanding, is more than sufficient.
The geometry of parts can be refined experimentally. In a 3D program, you can model dozens of variations in size and shape in just a few minutes. Print hundreds of parts at once and then copper-plated them in the same quantity, then choose the best ones. You can make them slightly uneven, with different positions, to achieve maximum realism... but it's impossible to manually produce the same number in such a short time using the standard method, that's a fact.
I'm already preparing a second set of tests to demonstrate different conditions, how to and how not to copper-plated them. I also plan to test copper varnish (if I buy it). It's even more expensive and harder to find than graphite. But it works much faster, is more predictable, and the copper grows not from the holders, but over the entire surface.
Naturally, I also plan to show you how to blacken it all. This process also involves some tricks, as the cannons need to be blackened using one method to make them look like cast iron. And everything else - anchors, rims, hinges - should be blackened using a different method to make them look like forged steel.
To be continued.
Thanks for sharing, it's easy and practical system.
This is a wonderful presentation Sergey, thanks for sharing.
Thanks for letting us know about this amazing technique. I admire your research into the subject.
Thinking of other uses apart from modelling.
Keep up the good work
Thank you for your comments and interest in this topic. Now I'll finally show you the result after blackening.
Copper Blackening (After Galvanization, but this is also applicable to ordinary copper).
I blacken with the well-known Brass Black by Birchwood Casey (new bottle design).
Since it's not cheap, there are a couple of ways to use it efficiently.
Option 1. Diluting the solution 1:5 or 1:10 (or even 1:20) with regular water. This changes the exposure time. If you need to monitor the process, the 1:10 option is best. The blackening time will be 13-17 minutes. If diluted 1:5, it will take 5-10 minutes, and if diluted 1:20, you can wait anywhere from 20 minutes to half an hour.
During blackening, you should constantly brush the surface of the part with a regular brush to remove any residue. This will interfere with the process, and the blackening will be superficial, insufficient, and not very durable. Be careful, as the blackening is weak during the process, and the metal part of the brush and other parts can scratch it. After finishing, rinse the parts with running water and dry them with a soft cloth or cotton cloth. But...
...if the exposure wasn't long enough, you can get a dark bronze effect like this (if that's what you're looking for). But if you want forged metal, you'll have to wait.
But I don't want that effect on the cannons, since they're made of cast iron, so I need a different color. Plus, the shine is too high, which is excessive for cannons. The cast iron is matte with scuff marks on the protruding parts, so it's fine for an anchor, but not for cannons. (This cannon is from the first test!)
In the photo above, the right loop is dark brown, the left is black. The rims are also different colors, so you need to carefully calculate the concentration and exposure time if you're doing multiple passes to ensure all pieces are the same color.
The two side rims are hand-made (quickly), the blackest one is painted plastic, and the two center ones are copper-plated plastic (50 and 100 microns). Experiments with the rims and hinges will continue, so these are just trials for now.
I liked the gun better after the second test, but it's far from perfect. It's not smooth, so it doesn't have the extra shine, and the blackening is more matte and blacker on this surface. But still, there's too much roughness.
The result after the start of the 3rd test (3a) gave an approximate roughness, but still, due to the smoothness of the surface, the color was more graphite than necessary and the tests continued.
After re-coppering, but without polishing the surface before blackening, this is what we got: the anchor (3) and the cannon (3b). But as I already mentioned, this surface (which wasn't polished with 000 steel wool after copper plating) is very fragile and not scratch-resistant, because...
... I removed the blackening with 000 steel wool...
...and repeated the blackening (3) and (3b). This time the surface was more scratch-resistant, but still somehow too light a graphite color and had a bluish tint.
And since I got the same result on the large anchor (4) and on the gun (4a) I decided to remove the blackening with steel wool and resort to the second method of applying the blackening with explosives to achieve a deeper black.
Option 2: Apply the clean BB solution drop by drop from a syringe to a brush and rub it evenly into the part.
You need to constantly renew the layers for 10 minutes. This means brushing over all surfaces, applying the solution, so that the surfaces don't dry out and that with each pass, the brush removes the old, used-up residue, allowing access to a fresh batch of solution. Thus, after rinsing and drying with a napkin, the color was deep and dark, but not black, but more of a very dark graphite.
But I don’t know why, I thought that this photograph doesn’t convey the shades, but after a couple of days the color of the small anchor became almost the same as the large one, although the large one was initially clearly darker... mysticism.
It turns out that both methods (thinning and applying pure) yielded virtually identical results. Although initially, the small anchor was clearly more graphite-like. BUT, upon closer inspection of the last two photos in the next post, which only show the results against the background of the ship, a slight difference is still visible, and the large anchor is still slightly darker than the small one.
I did the same with the gun from the 4th test (4a). After removing the blackening with 000 steel wool, I applied clean BB and rubbed the solution in for 10 minutes, and got the result I wanted. (4a) is darker in color, matte, and more like cast iron dirty from gunpowder, both in tone and texture.
After four tests and numerous experiments, I finally achieved the desired color and texture for forged steel (anchor 4) and cast iron (4a).
While I'm not sure everyone will agree with my choice, I'm giving you the opportunity to choose the color and texture you like and create the look you like.
To summarize:
(1) - very smooth surface after heavy polishing with 0000+. First, blackening with a 1:10 dilution for 17 minutes. Then, twice applying a pure BB solution and letting it dry.
(2) - very rough surface. First, blackening with a 1:10 dilution for 17 minutes. Then a second application with a 1:5 dilution, letting it dry and wiping.
(3a) - after repeated copper plating, blackening with a 1:10 dilution for several minutes and a long exposure.
(3b) (3) - after repeated copper plating for two hours, blackening was done with a 1:10 dilution and a 17-minute exposure, but the layer was weak (I previously wrote about why). Then, after removing the blackening, blackening was repeated with a 1:10 dilution for 17 minutes. This produced a good result for the anchor, but insufficient for the gun.
(4a) (4) - after repeated copper plating for two hours, the gun (4a) was blackened with a 1:10 dilution for 17 minutes, and the anchor (4) was blackened with a 1:20 dilution (since it was large and required a lot of liquid) and a 17-minute exposure, but the graphite color was not deep. Then, after removing the blackening, blackening was repeated by applying pure explosive for 10 minutes. And after this, the result is an anchor with a deep, dark graphite color and a faint sheen, while the cannon (4a) is more matte, darker, and practically sheenless.
P.S. Don't look too closely at the texture yet (some have visible imperfections and printing marks). These are just test samples, and they were made using parts that had previously been rejected.
Thank you very much for posting this! A valuable technique. Several years ago, there was an article in the Nautical Research Journal where someone used electroforming to make the large cowl ventilators found on steamships. His technique:
1. Carve a (solid) wooden pattern, or, today, 3-D print one.
2. Make a two-piece silicone rubber mold using the wooden pattern.
3. Cast a metal pattern in the mold. The metal to be used is Cerro, a bismuth alloy that melts in boiling water, used by gunsmiths to make castings of bullet chambers.
4. Electroplate.
5. Remove the Cerro in boiling water, leaving a thin shell.
There is, or used to be, an American company named Caswell that sells plating supplies.
Roger
This is an interesting process. I will need to look into it.
A quick update regarding blackening after electroplating.
I don't know if this happens with brass, but it can happen with copper, so be careful!
After a couple of months, stains appeared in the places where I handled parts with greasy hands!
The rest of the surfaces are fine; the stains are only on those that came into contact with the skin.
But that's not a problem—it can be removed simply by wiping with a cloth and rubbing alcohol.
But you need to be careful, otherwise you'll have to do this on the model. It's best to wipe the metal with alcohol before final fixation and use gloves when fixing.
_________________________________________
The results are looking great. Lot of work, but that's the fun about this hobby.
What a great outcome! You might also experiment with graphite powder to knock down the shine...
This is a great sharing of useful information. Thank you for taking the time to record your experience.
Friends, thank you for your interest and feedback! There's much more to come.
This is exactly the idea I applied in my second version of the electroforming machine. Thanks for sharing the video.
Galvanizing Unit (electroplating machine) 2.0
*As I mentioned, a contactless stirrer isn't suitable for our purposes, as it creates a vortex that sucks air to the bottom of the container. So, I decided to create a different stirring method and simultaneously increase the capacity and the number of anodes. Let's get started...
1. Electronics.
I cut the bottom of a 3-liter container to the height of my control unit. I used a scalpel and a tool like this one, using slow but steady circular motions. Then I cut a window in the bottom for the control unit and inserted it.
I attached terminals for the wires just above the center. And in the center in the lid of the second container (also a 3-liter one), I installed the motor. This motor has an incredible gear ratio, and at 5 volts, it only makes 3.3 revolutions per minute. You'll understand this later. I ordered this motor from AliExpress (model C). Motor>>>
This motor has an M3 thread, and I installed a screw there, the tip of which I ground to the diameter of the brass tip (so that the tip could be inserted onto the tip of the screw). I mounted a bearing on the screw shaft and secured it with nuts. I also attached a clamp from a paper clip around the bearing itself and secured it on both sides to the plastic frame (the tank lid). This clamp and the bearing will transfer the negative charge to the shaft (screw) and then to the part to be copper-plated, so this area needs to be conductive at all times, but not slow down the motor.
Then I connected the wires to the control unit and to the motor.
And then, after checking, I secured the two bases with pins and nuts.
With that, the top part of the device is ready; let's move on to the bottom:
2. Anode.
I mounted polished copper plates on a special ring using clamps, and then attached the wires to the ring using other clamps. The plates were placed in a non-woven fabric (a filter is essential). I connected the wires from the ring to the control unit as a positive charge (anode).
All that was left was to connect the two power supplies to the terminals. One 5V for the motor and the other (it doesn't matter which, as long as it's no higher than 30V; in my case, 12V) to the control unit.
The end result was this unit, which my wife called "The Bomb" ROTF ROTF ROTF ROTF
And there is some similarity, it's funny)))
3. Cathode.
And now the most important thing – the detail itself, which needs to be copper-plated
More precisely, the details. I describe how I modeled, printed, and prepared the parts in the construction chapter—working with metal. Briefly, copper wire is attached to the parts, and the ends of these wires are soldered to the main support wire. I soldered the parts so that they were submerged in cold water to avoid overheating the joint between the wire and the plastic during soldering.
Then I coated the entire structure with graphite spray varnish.
WARNING! Be sure to let the varnish dry for at least 5 hours.
Then I bent the wire so that all the parts were equally spaced on two levels, like on a carousel. After that, I secured the supporting wire (by the way, it's 1 mm, not 0.5-0.6 mm like the others) to the terminal connected to the motor's rotation axis (which carries the negative charge). I replaced the clamp with a more unique brass one for a simple 5-cent terminal.
Now everything is ready for galvanization. I need to wait for the varnish to dry, and then I think I'll start tomorrow.
Sergey, your creativity is amazing. I have tried electroplating with limited success, but with the information you've provided, I think my next attempts will be much better. Thanks for sharing your research.
