HMS Pegasus by Amati
Romania
Hello fine gentlemen. I have purchased this kit more than 10 years ago. Started it but never passed over 1st planking. Now i feel confident enough to build it. attached some pics from where i left it
i have finished redesigning the bow
What sources are you using for your study and fine work? I am guessing you have downloaded the high resolution inboard profile plans of the sister ships Cygnet and Atalanta from the Wiki Commons website and the deck plans for Pegasus from RMG. Are you also using the four volume set of books on building Swan, Pegasus. et al by David Antcherl? The details in his books are incredible for any build, but centered on your vessel.
hy Allan. I have bought the Antscherl monographies and using the references from Greenwich museum for the Swan class. i have altered them to fit the Amati pieces. i am a bit nervous, hopely they will fit in the end.
You are doing fine. Most would modify the pieces to fit the books and original plan rather than the other way around, but go with works best for you. Our hobby is a never-ending learning experience.
Dear Lucian, Amati has misled you.
The ring shown by the arrow was missing from the top capstain. The lower drum also lacked a lower ring, as Amati showed.
The number of ribs is also incorrect. The rib thickness is also incorrect, making the capstain look unsightly and unrealistic.
The number of holes for the levers should be greater.
View attachment 591428 View attachment 591427 View attachment 591429 View attachment 591426 View attachment 591424 View attachment 591425
thank you . balshaya spasiva. i will remake
