Chess trees
I am researching a 44 gun British frigate of 1744 and the contemporary plan does not show chess trees on the hull. It does show two fenders, but no chess tree. I looked at several more plans of fifth rates prior to the 1745 Establishment and none of the ones I saw show chess trees. Those that I saw from 1745 and beyond do show them. My conclusion would be that they came into use with the 1745 Establishment, but, the 1719 Establishment gives scantlings for chess trees for ships of 70 guns and smaller. Does anyone have information based on contemporary sources regarding when chess trees would have been installed on British naval vessels?
TIA
I checked my plans list for 44 gun and found this for a 1741 Establishments Fifth rate Pearl j5475 ZAZ2278
I think I see something that could be a ches-tree - had to look it up in Falconer I just thought of it as being a fixed sheave block.
Pearl has two full gun decks plus possible guns on the Q-deck and F-deck. I am imagining that these things sailed like a slug - being short and fat with too much hull for wind to hit for its length. I like to think of a frigate as being long, low, and sleek. A ship with one full gun deck and additional guns on the Q-deck and F-deck. Blame
FIRST FRIGATES ,THE GARDINER,ROBERT CONWAY MARITIME PRESS LONDON 1992
HEAVY FRIGATE ,THE VOL.1 GARDINER,ROBERT CONWAY MARITIME PRESS LONDON 1994
I am still waiting for vol. 2
A deeper search of my files:
positive for ches-tree =
Garland 20 1719
Argyle 50 1719
Centurion 60 1732
Namur 90 1723
Shark 8 1732
Victory 100 1737
Suffolk 70 1739
Yarmouth 70 1745 possible
Royal George 1756
At first I only looked at the ones I have prints - much higher resolution
So it was one example of every class for every Establishment.
The haphazard nature of ches-tree presence had me looking at KB size NMM icons.
When it came up with Namur 90 I stopped.
My opinion has it the the presence or absence of ches-tree on design plans is not a reliable indication of anything. I suspect the the presence on a particular design plan was an affectation of the draftsman and added on a whim.
The captain or shipsmaster? (the details guy for the ship's functioning) could add or remove a ches-tree with an afternoon's work?
I would vote that any ship from 1719 Establishment on could and probably did have at least one ches-tree.
Maybe that is why the one I am researching sunk in a protected bay while towing a capture. :) I would not have chosen this ship under normal circumstances.
In any case, I wonder which Pearl drawing is correct? I have the one below in high res from RMG and she shows she was built similar to original Roebuck, Fowey, et al. The double tier of stern lights in the drawing above makes her look like Roebuck when they added the faked tier so she looked like a larger ship to the enemy. This drawing shows no evidence of a chess tree but the fenders are very clear.
Here is what Winfield has for Pearl:
Pearl 1708 40 1706 Establishment
Pearl 1726 40 1719 Establishment
Pearl 1744 44 1741 Establishment
Pearl 1762 32 Niger class
Pearl 1780 18 sloop ex-French prize
A ship may be a total loser as a design - but it did exist and should be modeled if only to show what was an example of a bad idea.
I have it in mind to eventually build an 80 - a rate that was the worst of all possible choices - yet the RN Suits persisted in building them even after every captain who commanded one informed them about how poorly an 80 performed. My perverse streak likes the idea.
Thanks Dean,
There are missing things on the drawing like the anchor lining, hawse holes, et al, so the chess trees may indeed be one of them. The project is for HMS Fowey, that was rebuilt as a 44 supposedly based on the plans above which list Pearl, Roebuck, Lark, Fowey and others in the upper right corner of the drawing. I am working with the National Parks Service on this and want to be as accurate as possible. There are some oddities, including the framing, according to the archeologist I am working with, based on the wreck in Biscayne Bay. Sorting these out is a bit of a challenge.
Thanks again for your input, it is always appreciated.
