French-Speaking Members Please!
Columbia, SC
I've purchased ANCRE's French Naval Artillery 1640-1850 in English. Unfortunately, the copies of documents are in French (which they of course would be). The problem is my French is limited to Oue and Non. There is one table in particular that lists many dimensions for gun carriages as of 1699 that I would LOVE to be able to use. I'll work out the dimensions (no doubt in French feet), but would anyone be willing to translate the text in each of the columns? They are written in script, of course, and Google Translate doesn't do script (yet?). The picture below is in high resolution, so click on it to see everything bigger. I've also rotated it so the desired columns to be translated are horizontal.
Whoops, just tried uploading the file, and it reduced it to 1079x1400. I'll crop it to only show the columns to take up less space.
Hmmm. That's not full resolution either. Maybe good enough? I could have sworn I've seen higher res photos when you click on them.
Anyhow, if anyone could translate for me, I'd appreciate it. I get that the first line is weight of the ball in pounds, the second is caliber diameter. After that.....?
Hi Signet
I can help you on this
- cannon balls weight in pounds
- cannon diameter in inches and (can't read that last word)
- cannon balls diameter in inches and ??
- cannon length in feet, inches and ??
- thickness of the bottom of the cannon carriage in inches and ???
- length of the bottom of the cannon carriage in feet, inches and ???
- width of the bottom of the cannon carriage in feet, inches and ???
- thickness of the (?? can't read) in inches and ???
- length of the (?? can't read) in feet, inches and ???
- width at front of the gun carriage in inches and ??
- width at back of the gun carriage in inches and ??
- front axle diameter in inches
- rear axle diameter in inches
- thickness of the front wheels in inches
- thickness of the rear wheels in inches
- diameter of the front wheels in inches
- diameter of the rear wheels in inches
cheers
Gun carriage proportion table for every gun used by the navy / fleet
- cannon diameter in inches and lines
- cannon balls diameter in inches and lines
- cannon length in feet, inches and lines
- thickness of the bottom of the cannon carriage in inches and lines
- length of the bottom of the cannon carriage in feet, inches and lines
- width of the bottom of the cannon carriage in feet, inches and lines
- thickness of the ("flasque") sidepiece in inches and lines
- length of the ("flasque") sidepiece in feet, inches and lines
- width at front of the gun carriage in inches and lines
- width at back of the gun carriage in inches and lines
- front axle diameter in inches and lines
- rear axle diameter in inches and lines
- thickness of the front wheels in inches and lines
- thickness of the rear wheels in inches and lines
- diameter of the front wheels in inches and lines
- diameter of the rear wheels in inches and lines
In " Précis des pratiques de l'art naval" by J.- B.-A. Baron (1813), the LINES or LIGNES are used as dimension of length when comparing french foots to englisn foots. Per ex. 1 english foot egal 11 in. 3 lines and 1/6 of line of french foot or 306 mil. Of meter.
Michel
Thanks so much, guys! Responses like this is one of the things that's so great about an International forum! I believe one LINE is 1/12 of an inch. If I'm wrong, please correct me.
Whoops, I think one got missed. There are 18 columns with captions, but only 17 translations. One towards the middle, I think, but can't make it out.
Michel
I did not know this term line
Good to learn
Sorry for this one, I have difficulty with this kind of conversion. Difficulté in terme of compréhension of all this old things.
Michel
Here is the full translation including the missing column for a total of 18 columns:
- Weight of cannon-balls in pounds.
- Diameter of guns’ caliber in inches and lines.
- Cannon-balls’ diameter in inches and lines.
- Guns’ length in feet, inches and lines.
- Thickness of the gun carriage bottom piece in inches and lines.
- Length of the gun carriage bottom piece in feet, inches and lines.
- Forward width of the gun carriage bottom piece in inches and lines.
- Aft width of the gun carriage bottom piece in inches and lines.
- Thickness of the side pieces in inches and lines.
- Length of the side pieces in feet, inches and lines.
- Gun carriage forward width in inches and lines.
- Gun carriage aft width in inches and lines.
- Size of the forward axle in inches and lines.
- Size of the aft axle in inches and lines.
- Forward wheels thickness in inches and lines.
- Aft wheels thickness in inches and lines.
- Forward wheels height in inches and lines.
- Aft wheels height in inches and lines.
Thanks to everyone for their assistance in translating and interpreting this table. I have created a spreadsheet with this information, with titles changed to use standard gun carriage nomenclature, and have converted all dimensions to standard, current English inches (I could do a metric one if anyone wants it). Only the barrel length has been left in feet, which is what we are all accustomed to. I assume they are French feet. Anyhow, here's the table:
Tables deleted due to several small errors. Please see newly posted table HERE.
I found that :
Le pied de roi : 0, 32483 m (censé être la mesure du pied de Charlemagne : 12 pouces). Il se subdivise en 12 pouces, le pouce (2,706 cm) en 12 lignes, la ligne (0,226 cm) en 12 points (le point =0,188mm). De 1812 à 1840, le pied métrique était de 0,33 m., le pouce métrique de 0,0275 m.
The royal foot: 0.32483 m. It is divided into 12 inches; the inch (2.706 cm) into 12 lines; and the line (0.226 cm) into 12 points (1 point = 0.188 mm). From 1812 to 1840, the metric foot was 0.33 m, and the metric inch was 2.75 cm.
I've found a couple small errors in my conversion from French Feet-Inches-Lines and have corrected them in the spreadsheet. Here's a screen shot of the corrected table:
I didn't want any bad info left out there. Think I'll put a note not to use the previous table.
