I've purchased ANCRE's French Naval Artillery 1640-1850 in English. Unfortunately, the copies of documents are in French (which they of course would be). The problem is my French is limited to Oue and Non. There is one table in particular that lists many dimensions for gun carriages as of 1699 that I would LOVE to be able to use. I'll work out the dimensions (no doubt in French feet), but would anyone be willing to translate the text in each of the columns? They are written in script, of course, and Google Translate doesn't do script (yet?). The picture below is in high resolution, so click on it to see everything bigger. I've also rotated it so the desired columns to be translated are horizontal.
Whoops, just tried uploading the file, and it reduced it to 1079x1400. I'll crop it to only show the columns to take up less space.
Hmmm. That's not full resolution either. Maybe good enough? I could have sworn I've seen higher res photos when you click on them.
Anyhow, if anyone could translate for me, I'd appreciate it. I get that the first line is weight of the ball in pounds, the second is caliber diameter. After that.....?
