Re: Royal William 1/48 scale
Continuing with the lanthorns the three of them have scrolls each side of the connecting rod, I have not seen these on other Period ships, the only thing I can think is that they are a platform for the sailors to stand on when lighting or maintaining the lanthorns.
First attempts,
I should have soldered these on before attaching the actual lanthorns themselves, but now I jusst CA glued them in place and bound them with some very fine copper wire,
close up view, still have to tidy up the binding copper wire,
My supply of copper wire,
view from above,
and from under,
and on the Period model,
best regards John.
Its been awhile since I last posted so this is a bit of a catch up,
I drilled and fixed eye bolts to the lanthorns and also the transom, this pic shows the measuring for the attaching wires,
After attaching the wires,
and several views of the attached lanthorns,
thanks for looking in,
best regards John,
Whilst I was casting the anchors I decided to also cast the Dolphins for the stand at the same time, this is the open mold for the Dolphins,
And after casting, I have already removed the clamps from the mold,
and the open mold with the cast Dolphin,
Still have to cut off the sprue and clean them up a bit,
This is how it will sit, only it will be on the cradle that supports the ship,
and the four Dolphins in front of one part of the cradle,
best regards John.
