USS Constitution by BlueJacket 1:96
Hello All,
Another victim here of the MSW disaster. Two and a half years into my build and sadly, I did not keep a personal copy of my log. So, instead of trying to re-do the entire thing from the beginning, I am going to start up my log from where I am. As it stands, I am just getting started on the spar deck. Here are a few photos of the ship currently
Thanks Peter, I'm sure I will. I would imagine the folks here are just as friendly and helpful as those I got to know on MSW.
Having gotten the spar deck planking all figured out, it was time to get started on all the furniture. I have a fairly good sized piece of wood taken from the Constitution during the '73-'76 overhaul. I wanted to use this wood to fabricate all the parts of the deck that would be stained or varnished and not painted. Mostly this includes the fife rails, pin rails, hatches and the ships wheel. The ships wheel was going to be the most challenges for sure, especially at 1/96 scale, so I got started on that first.
At first, I thought the wood I had was pine because of the large grain pattern, but then realized it was Douglas Fir by the typical redish color.
Considering the grain is very close to that of pine, I used a pine 2x4 with a similar grain pattern to practice with. The plan was to cut a thin strip, sand it down to proper thickness and then use the laser engraver to cut the parts. According to the Navy plans, the wheel is 2- 3/4" thick. At scale, that would be .028", which is not much to work with. I decided to try .040", as I didn't think the difference we be too noticeable. The first problem encountered was the grain. Turns out the heartwood doesn't burn as easily as the softwood. To get enough power to cut through the heartwood, the softwood would get excessively scorched. The solution was to cut the wood in a manner that would provide me with a small strip that was mostly the softwood. After many failed trials, I finally got things tweaked to where I could get nice clean wheels with out too much scorching
With the center hole removed, I could place the wheel on a dowel and using a jig I put together, I could drill the holes around the perimeter for the spokes. The spokes were made by cutting a very thin strip from the heartwood and placing that in a dremel. With the dremel turned on I squeezed the piece between a folded piece of sandpaper to create a very small dowel - about .020" in diameter
Once the holes were drilled in the wheel, the center could be punched out and then spokes installed
Then repeat with another wheel
Once the two wheels were attached to the drum, I could easily cut the dowel flush
I got a little lazy at the end and used some .020" styrene rod for a few spokes. The point of this was proof of concept. Since I was already happy with my ability to make wooden spokes, I didn't bother with the last few. You can also see in this photo that I had drilled a hole in the center of the dowel to place a pin to help position the side frames. The frames were cut using the laser and turned out pretty nice
And finally, a complete wheel assembly
Once stained, the scorch marks from the laser will blend in. Overall, I was very pleased with the result, especially considering the size. Now to do it all over again with the wood piece from the real ship
Thanks for the warm welcome guys, and the compliments. Johann, I definitely think I'll fit in here.
Paul, sine you commented on the guns specifically, I thought I'd post a few more close up pics. You are 100% correct. At this scale, it was a challenge. Can't wait to get to the carronades (said with dripping sarcasm :) )
The second photo was taken after adding the diagonal knees, as well as the shelves for the gun tools (rammer, worm, etc). As you can imagine, everything is very tiny. The eyebolts and hooks for the tackle were made from #18 or #22 fly fishing hooks. I would cut the hooks off and use the shank as an eyebolt, or reshape the shank back into a smaller hook
The blocks are 3D printed, 2mm in length. Still technically a little oversized, but anything smaller would be insane
Lastly, another shot with the guns in the background, but really wanted to show off the camboose. If you zoom in, you can see a coffee pot and a stew pot, all made from scratch
Thanks for looking
Thanks for all the comments guys, it certainly has been a warm welcome here at SoS.
Paul, one thing about the fish hooks, they are hardened steel. You can cut and use them as eyeballs as is, but if you ever plan on trying them for tackle hooks, they need to be softened before bending. Simply heat with a torch to a nice red glow then let them cool slowly.
Thanks Mustafa, just got started working with the Constitution wood piece. Hopelly it goes well and I'll have something to show in a couple days. After we that, I plan to start on the file rails
View attachment 597956 View attachment 597960
Thanks for looking
Using the fly hooks are a great idea that I never thought of. I tie my own flies and have a nice selection of hundreds of hooks from 12-22, so I will have to give this a try.
Hi Stevinne, I guarantee you will be glad you did. with fish hooks, you have a large selection of sizes, wire diameters and eye diameters.
I thought I would post a little about current progress, although a bit slow. As I mentioned previously, the ability of the laser engraver differs depending on density of the wood. My plan was to cut a slice off the piece of original wood I have that would not have any grain to it. here is another photo of the piece of wood with an outline of what I hope to carve out
Using my newly acquired Byrnes saw, I was able to cut out two strips that were essentially all softwood. I eneded up using the top section instead of the bottom, mainly because of the depth of cut. The plan was to then run these strips through the thickness sander to give a uniform .040". My little homemade thickness sander has one drawback. You cant get your fingers very close to the "cutting" edge, so it requires fairly long pieces. to get around this, I glued my short strips to a longer piece, just on the ends so that I can peel them off once cut on the laser. After thinning the pieces out, I made my first attempt at cutting some wheels
The strips were just wide enough to accommodate the wheels and actually were a tiny bit flat on one side, but I figured I could position them so that this was hidden behind the side frames. Here they are freed from the original piece and ready for drilling some holes
Here's where things went a little south. My first attempts were not terribly successful. These wheels are .040" thick and I'm trying to drill holes in them that are .023" diameter, so not a lot of leeway. My first try, I was a little off center and cut through the side of the wheel. On the next one, the wheel actually broke. Needless to say, I need to cut a few more wheels and try again. I figure it will probably take about 6 tries to get two good wheels. Hopefully I don't run out of wood.
Stay tuned
Mah oh man, I can't believe the level of detail you're adding to the gun deck. Even if you leave some of the spar deck planking off, how much of this is going to be visible to anyone viewing your completed project? - especially if you put it into a case. You and Jon seem to be birds of a feather. I mean that in a good way. Awesome!
