Mary Rose 1511 — the epitome of the Northern tradition
European Union
Below is the content of a thread restored from a personal backup, originally posted on another platform that is no longer accessible, presenting an attempt at a conceptual reconstruction of the iconic ship Mary Rose from 1511. Given the significance of this case for the history of naval architecture, but also for editorial reasons, the content of the thread will be reproduced verbatim in its entirety, including all comments made by all participants in the original presentation.
Waldemar Gurgul
The results of the analysis of the design method applied to the construction of the iconic ship Mary Rose presented here, although perhaps no longer entirely unexpected at this latest stage of investigation undertaken, quite decisively complement and correct previous understandings of the history of shipbuilding in this early period. This case emphatically demonstrates that shipbuilding methods that can be called Northern European (as opposed to Mediterranean) are not, as hitherto thought, confined to the early modern Netherlands, from where they were supposedly spread over time to the other regions of the continent. On the contrary, the increasing number of examples being studied show that this is in fact a building tradition that is omnipresent throughout all northern Europe. Suffice it to say that long after the Mary Rose 1511, an exactly identical design method, with all its specific paradigms, was still applied at least 200 years later, for example, for the construction of the very successful Flemish predatory privateer ships, such as the highly regarded Neptunus of about 1690, and described by Chapman as an „extraordinary sailor”, or vessels of Louis XIV's navy of various sizes, such as the light frigate l'Aurore of 1697 (detailed presentation forthcoming).
Even if one is not interested in issues such as the historical context of ship design, familiarity with these methods and the ability to apply them in practice may prove useful to today's authors of reconstructions in order to obtain reliable shapes. It is also worth adding that the ancient design methods, correctly applied, virtually guarantee the immediate fair shapes, without the later, punitive synchronisation of cross-sections, waterlines and buttocks, which was in fact not practised in this early period at all.
This particular study is based on the published documentation of the ship in two excellent monographs of the Mary RoseMary Rose. Your Noblest Shippe, ed. Peter Marsden, 2009 and Tudor Warship Mary Rose, author Douglas McElvogue, 2015. In contrast, one need only caution against the disastrous in content and effect chapter ‘Hull Design of the Mary Rose’ in the first of these monographs, both in a general sense and for me personally. The attempt there to reconstruct the Mary Rose's design method seems to have led to an even more distortion of the lines of the shipwreck than nature has done in 500 years, which consequently led me astray earlier and a lot of time was wasted to finally sort things out. As always, I could also count on the invaluable help of my friend Martes.
So much for the introduction, and before the actual detailed explanations, here are a few welcome renders showing a graphical overview of the results obtained:
MSW member Baker:
Nice work, This shape looks familiar to me
Didn't the Mary Rose originally have a round transom in 1511. And only after the conversion a flat one?
Thanks. The reconstructed design lines may indeed suggest some modifications to the stern. I'll show what's involved a bit later, in the correct order, as it's probably still a bit early for such details now, and the presentation graphics are not yet ready.
Read or assumed dimensions of Mary Rose 1511:
Breadth outside planking
– 40 feet
Breadth inside planking – 39 feet 4 inches
Length between posts (at 3rd deck level) – 3.5 x breadth outside planking = 140 feet
Length between rabbets (at 3rd deck level) – 3. 5 x breadth inside planking = 137 feet 8 inches
Draught at midship (without keel) – 1/10 x length between posts = 14 feet
Height of maximum breadth above waterline at midship – 3 feet
Height of 1st deck at midship – 10 feet
Height of 2nd deck at midship – 7 feet
Height of 3rd deck at midship – 8 feet
Rising of 3rd deck aft – 6 feet
Lengthwise division (number of equal length segments between posts) – 13
Forward rake – 2/13 x length between posts = 21 feet 6½ inches (21. 538 feet)
Aft rake – 1/13 x length between posts = 10 feet 9 inches (10.77 feet)
Keel length – 10/13 length between posts = 107 feet 8 inches (107.69 feet)
Breadth of the bottom at midship – 1/4 x hull breadth = 10 feet
Deadrise at midship – 6 inches
Mainmast position – half the length between posts
Keel assembly, lengthwise division
The base dimension of the vessel – the breadth, being decided, all other dimensions could already have been calculated on the basis of the general proportions commonly used at the time, possibly adjusted by the specific function of the vessel as well as the experience and inclination of the designer. The method of carrying out and the result of such calculations for Mary Rose 1511 is shown above, bearing in mind of course that the values presented here are more or less hypothetical due to the extraordinary distortion of the wreck.
The issue of dividing the vessel into 13 equal parts is quite important, as it not only results in specific values for forward and aft rakes, but, even more importantly, sets the stations for all conceptual frames, including the double master frames and both quarter frames (see diagram).
The waterline is shown horizontally, however, according to the original design it may have had a trim within 2–3 feet. The mainmast position falls halfway along the entire hull.
Longitudinal design lines (risings & narrowings)
Geometrically, these lines are exclusively single or combined circle arcs. At a later stage, in order to achieve a generally similar run of these design lines, the combined circle arcs will quite commonly be replaced by more advanced curves, such as ellipses or logarithmic curves. The extra rise of the line of the floor at the very end of the stern is actually desired to prevent concave hull surfaces in this region (apart from lifting the flat transom panel out of the water for hydrodynamic reasons), and this is not, or need not be, related to the presumed change in stern configuration during the refit of the vessel.
Somewhat anticipating, it can already be said that, conceptually, the Mary Rose exhibits extreme geometric consistency without any anomalies of this kind (assuming, of course, the correctness of the results of this investigation), which practically excludes any local alteration to the ship being made during its life, and especially the lengthening of its keel (according to the hypotheses put forward so far). It is also of note that these hypotheses are probably based only on the circumstance that some of the wreck's components, dated dendrochronologically, revealed newer wood, that is, fitted after the date of the ship's construction in 1511. Yet, the replacement of degraded elements in wooden ships is in itself not unusual at all, especially as the Mary Rose was already a quarter of a century old at the time of her great repair in 1536, which still exceeds the normal lifespan of wooden vessels.
In conclusion, there is nothing in the shape of the ship's design lines which seems to suggest any changes to its design during its service.
Double master frame & quarter frames
Shaping the hull surface starts with defining the contours of the double master and quarter frames, and this step can already easily be carried out straight away on the mould loft, without first drawing these contours on paper.
As far as the master frames are concerned, the lines of the bottom/„flat” were first traced according to the corresponding coordinates taken from the line of the floor for the master frame position, followed by the lower breadth sweeps drawn tangentially to the deadrise level for the master frames position, and finally the two sets were joined by reconciling arcs (dashed red), tangentially at both ends (see diagram). Hopefully for greater clarity, the centre and radius of the lower breadth sweep of the master frames can still be described in Martes' words: „take the difference between the deadrise level and max. breadth level, then take this distance from max. breadth horizontally, and that's the center”.
In the quarter frames, on the other hand, the bottom curves are arcs (as opposed to straight lines). The radii of the two sweeps that make up the frame contour, i.e. bottom and lower breadth sweeps, were chosen to obtain sharp hull shapes, suitable for warships/privateers, and even necessary for short hulls as well, and at the same time to make the subsequent reconciling curve (dashed red) close to a straight line while maintaining tangency at both ends. For both quarter frames of the Mary Rose, the respective radii appear identical, and are 10 and 12 feet respectively (see diagram). It was important that the surfaces of both quarter frames below the draught line should be similar to maintain the correct longitudinal balance of the vessel, a point clearly made in French shipbuilding manuals of the mid-18th century.
This particular method of design, that is, in particular with this specific use of quarter frames (including the subsequent stages described further on), was still being used and described (albeit rather vaguely) as late as 1697 by the Dutch ship carpenter van Yk, and also in the construction of the French ships of Louis XIV's fleet.
Remaining conceptual frames (breadth sweeps)
The procedure for tracing the lower breadth sweeps is fairly straightforward, and involves first creating a vertical ‘scale’ (separately for the two halves of the hull), which horizontal tiers (lines) match the corresponding frame stations. If the distances between the frame stations are equal, the result will be that the distances between the horizontal tiers of this ‘scale’ will also be equal, and vice versa, as in case of the last, additional height of tuck “station”. The initial reference segment for creating this ‘scale’ is the vertical distance between the respective levels of the lower breadth sweep quadrant points of the previously defined master and quarter frames. All that is left is to draw the arcs themselves for all the remaining conceptual frames, in such a way that they are tangent to the horizontal lines thus determined (see diagram).
The upper breadth sweeps for the aft half of the hull sport fixed radius, equal to the radius of the lower breadth sweep of the master frame, while for the forward half of the hull these radii are variable, equal to the corresponding lower breadth sweeps.
MSW member Martes:
In practice this gives a single arc for both sweeps forward?
That's right. To put it yet another way, these are ‘entire’ single circle arcs :).
Remaining conceptual frames (curves of the bottom)
Now, to make the surface of the bottom/“flat” fair, auxiliary lines need to be drawn on the body plan (dashed lines on the first diagram), extending from point A and tangent to the corresponding bottom arcs of the quarter frames. The intersections of these auxiliary lines with the vertical line of the ‘keel’ yield vertical co-ordinates (points B), which should then be transferred to the quarter frames stations on the side projection (second diagram). Longitudinal (other) auxiliary lines can now be drawn, the function of which is essentially to sharpen the hull in zones close to the keel. The intersections of these longitudinal auxiliary lines with the vertical station lines give co-ordinates, which are then returned to the body plan, so that bottom curves for all the remaining conceptual frames can be drawn (as straight lines at this point, except for the last station, which should in principle be an arc from the start – to be discussed separately).
Remaining conceptual frames (bottom & reconciling curves)
In the final stage of forming the conceptual frames, the botttom curves are joined to the lower breadth sweeps by reconciling sweeps (red), tangentially at both ends, with the reconciling sweeps starting from points on the line of the floor. Where needed, the straight bottom lines are completed by arcs, here all with a radius of 10 feet, the same as for the arcs of the bottom of both quarter frames. This, with the exception of the first frame, where this arc is also tangent to the vertical line of “keel”, and its resulting radius is about 6 feet 11 inches. The diagram also shows the geometric construction used to draw the last frame, which requires special treatment due to its position close to the specific sternpost/fashion frame assembly.
Reasons for the disaster of the Mary Rose
Diverse, sometimes quite conspiracy-oriented reasons have been put forward as to what may have led to the ship's disaster in 1545. It is difficult to argue with theses for which there is no hard evidence in fact, however, it can be said with certainty that the very shape of the Mary Rose's hull is already quite unfavourable from the point of view of lateral stability. Without going into complicated explanations of a theoretical nature, this shape can be compared to a circular in cross-section beam floating in water, which, when set in motion, easily rotates around its axis.
In terms of Mary Rose's specific round cross-section, as long as the ship's centre of gravity was relatively low and the line of greatest breadth was sufficiently high with heavy combat equipment, there must inevitably have been a significant raising of the centre of gravity of the entire ship, and worse, a simultaneous lowering of the greatest breadth of the hull to water level, which already ultimately devastated the lateral stability of the ship. Actually, it probably no longer matters how the gun ports on the Mary Rose were closed, directly by the gun crews or by someone else, for example on the upper deck. Vasa 1628 had the gun ports operated directly by gun crews, and still did not avoid disaster for the same reason.
Over time, the relationship between stability and the cross shape of the hull was better realised, and in 1643 George Fournier was able to state in his Hydrographie:
Although the practice [of employing round hull sections], which I described in the previous chapter, has long been and is still widely followed, quite a number of brave workmen, whether French, English or Dutch, depart from it for two reasons. The first, that such ships, being almost round, heel too much in the water. Secondly, because they usually have too narrow a bottom [which is precisely the particularity of Mary Rose – WG].
Below, a round hull cross-section from Fournier's Hydrographie according to the old manner on the left and on the right the shape according to the new manner sporting a wide bottom, laterally more stable.
MSW member Baker:
I completely agree with this statement. great research, thanks
Verification of the results obtained with the (published) archaeological evidence is naturally a mandatory component of the whole exercise. Here this will be demonstrated by using the cross-sections of the hull of the wreck published in the monograph by the Mary Rose Trust as an example, but the analogous cross-sections in the ship's monograph by Douglas McElvogue are equally good. In contrast, many of the other illustrations in both monographs are inadequate for this purpose, due to their over-interpretation by the responsible authors.
The placement of the frame stations in this reconstruction does not always coincide with the stations adopted in the monograph (this is particularly true of the bow section) and in such situations there cannot, of course, be full correspondence of the lines, but then one can judge by the parallelism of the contours being compared. The outer contours of the frame timbers, or in other words, the inner contours of the outer planking, should be taken as reference lines.
Did the Mary Rose have to capsize?
Apart from a better, or more prudent, vertical distribution of weights on the ship, a very effective and often used way to improve the lateral stability of ships sporting tumblehome was to increase their breadth. However, this does not mean increasing the breadth of the hull per se or by any means, but ideally this had to be done in such a way as to “maximise” the breadth above the draught line (typically 2–3 feet) while keeping it as intact as possible at the water level itself. This is shown in the diagram below (dashed lines). In this way, a dramatic improvement in so-called shape stability (as opposed to ballast stability) can be achieved. This procedure was called furring or girdling, depending on the structural way it was performed (for more on this see, for example, Cate Wagstaffe, Furring in the Light of 16th Century Ship Design, 2010).
In an archaeological context, such a case is exemplified by the so-called Gresham ship of the 16th century (for more on this see Jens Auer, Thijs J. Maarleveld, The Gresham Ship Project. A 16th-Century Merchantman Wrecked in the Princes Channel, Thames Estuary, 2014) and a graphic from this report specifically illustrates the essence of this commonly used solution for unstable ships on a concrete extant shipwreck. It is no coincidence that the Gresham ship also features a round hull section having a very narrow bottom, precisely as the Mary Rose 1511.
MSW member Martes:
But you have increased the width on the max breadth level, i.e. the exact same place where the waterline was located at her latest configuration. And even Gresham ship shows that the furring specifically raises the max breadth of the hull above the original level.
This is correct, because we do not know precisely this level after the ship's refit, and in any case it was variable depending on the actual weight of the cargo. Thus, of necessity, these particular diagrams simply show the general principle or idea of carrying out this process that could have been applied, without exact dimensional reconstruction. There is no need for this anyway, as it has not been put into practice.
As for the illustration showing the Gresham ship, it may not show the geometry very accurately. It is rather a more or less loose graphic reconstruction, also out of necessity. Please see how fragmentary the preserved parts of this wreck are (illustration also from the report mentioned above). Actually, the greatest breadth of the hull need not or should not be far away from the draught level. Thus, if the ship's draught was not planned to increase, there was no need to raise it.
Pages from Auer Jens - Maarleveld Thijs J. - The Gresham Ship Project. A 16th-Century Merchant...jpg
To show graphically what Martes had in mind, here is another diagram showing the possibility of girdling/furring, hopefully in a more realistic way, nevertheless, like the previous one laden with dimensional uncertainty so it should rather be taken as an illustration. As a reminder, as the draught of a ship increases (e.g. proves to be too great after launching and fitting out, which is particularly the case for warships), broadening the hull by girdling/furring should also raise the greatest breadth of the hull accordingly, so as to maintain the desired distance, usually 2–3 feet.
MSW member Snug Harbor Johnny:
They had to do this very trick to the repro GH [Golden Hind — WG] to make it seaworthy, as shown in the image below. After the modification, it sailed around the world.
MSW member Martes:
Concerning weight, I suppose heavy artillery + high castles + a lot of heavy infantry combined with insufficient ballast and stores in the hold (because there was no intention for a long voyage and they probably had to reduce the weight of the stores not to raise the waterline even more) brought about the result.
There is a question of how the larger Great Harry (that is assumed to have been built to the same, only enlarged design) had survived.
I am inclined to attribute it to either a miracle or much better seamanship, because she was as overloaded and carried her gunports probably as close to the waterline as the Mary Rose. But she was larger.
Note that the Great Harry is the only ship on the Cowdray engraving of the battle of the Solent that has the guns so low to the water.
The French fleet
the rest of the English fleet
So I assume the overloaded Harry is a faithful depiction.
On 5/21/2025 at 10:46 PM, Snug Harbor Johnny said:
They had to do this very trick to the repro GH to make it seaworthy, as shown in the image below. After the modification, it sailed around the world.
Thank you for showing this
. And a huge round of applause to today's marine engineers for this essentially makeshift repair! It's not the only case they have struggled with the specifics of old designs, and this despite the same applicable laws of physics now and then and all the scientific apparatus available today. Shame...
I was also reminded of a case in which a professor made serious calculations from which it was irrefutably clear that the length of a ship had to be at least about three and a half times its breadth to be capable of controlled navigation. Just how to reconcile the results of these calculations with the vessel San Juan of about 1550, with a ratio of 2.8 : 1 on the draught line, which not only crossed the entire Atlantic, but still hit the exact spot it was intended to reach with a whole fleet of similar whalers.
MSW member Alvb:
I am just a little surprised that on the one hand people had experience with such stability problems and knew methods to mitigate them, but on the other hand they built ships with these very deficiencies.
Yes, that's probably the best summary. A few dozen extra tons of difference in the original and new artillery configurations, a few dozen extra tons of battle crew with their heavy equipment. And if the repair of the ship in 1536 was mainly to reinforce her existing structure, as incidentally was done quite routinely in later times, then an additional few tens of tons of all the new reinforcing elements can be added, especially the standard knees and diagonal braces. The results of the dendrochronological studies are admittedly quite piecemeal, but at least they now suggest or at least do not contradict just such a repair scenario. All in all, at least 100 additional tons, perhaps as much as 150, and most of it at a height quite unfavourable to the ballast stability of the ship. And if still the “whole” crew was on the wrong side at the wrong time, then...
Below is a graphic showing clearly which items have been examined for their age and what the results of this research are (from David Childs, The Warship Mary Rose. The Life & Times of King Henry VIII's Flagship, 2007):
David Childs, The Warship Mary Rose. The Life & Times of King Henry VIII's Flagship, 2007.jpg
[quote: I am just a little surprised that on the one hand people had experience with such stability problems and knew methods to mitigate them, but on the other hand they built ships with these very deficiencies.]
It can probably be explained in some simplistic terms that initially, with the usual use of ships to carry cargo low in the holds, there was no major problem with this phenomenon, and even a certain “softness”, provided by the round sections, may have been desirable so that more violent gusts of winds would not break the masts. It was only when dedicated warships with heavy artillery began to emerge, and at an height unfavourable from the point of view of stability, that the problem hit particularly hard. The general conclusion is, although hardly surprising, that in reality there is no such thing as a universal solution for all applications, or at least it is rarely possible.
Patrick (@Baker; @Backer64 on this platform) came up with the idea to post copies of the publications mentioned above in this thread as well (thanks, Patrick), so they are always ready to be consulted. I think it's a good idea and that they are both in the public domain. Voilà.
Cate Wagstaffe, Furring in the Light of 16th Century Ship Design, 2010:
Jens Auer, Thijs J. Maarleveld, The Gresham Ship Project. A 16th-Century Merchantman Wrecked in the Princes Channel, Thames Estuary, 2014:
If one assumes, in line with the results of the investigation so far and with the present, general state of knowledge, that the Mediterranean methods together with its multi-arc frame construction (usually three) were only widely implemented in England at the times of Mathew Baker, i.e. in the second half of the 16th century, and that until then only the frame construction appropriate to the Northern European tradition, that is sporting just one arc (not counting reconciling or bilge sweep), but of variable radius, was employed, as shown in this presentation using the Mary Rose as an example, then this circumstance can be used to interpret perhaps more rationally and confidently other archaeological finds from this early period in a poorer state of preservation than the Mary Rose.
For instance, in the first volume of the Mary Rose monograph (Peter Marsden, Sealed by Time. The Loss and Recovery of the Mary Rose, 2003), on page 141, there is an interesting juxtaposition of cross-sections of two important wrecks dating from the “pre-Mediterranean” period in England on an equal scale — the Mary Rose 1511 and the so-called Woolwich ship (possibly Sovereign 1487). The assumption of design homogeneity in this early period, specifically the single-arc frame design, allows the breadth and its height of the Sovereign to be determined quite accurately solely on the basis of the modest surviving fragment of the bottom section of the hull (subject, of course, to its minimal geometric distortion), as demonstrated illustratively in the diagram below.
Thank you for your attention so far,
Waldemar Gurgul
MSW member Kenchington:
Waldemar,
I have been following along with your thread. You have presented some fascinating material, but I'm a bit lost -- maybe because you started with your finished renderings and then moved on to how you had constructed them.
What I haven't seen (though that may be my mistake) is an explanation of how you came to your rules for developing the hull shape. Did you "reverse engineer" the shape from the archaeologists' reconstruction, fitting arcs and other curves to that? Or did you perhaps find an account of the design approach somewhere?
You've certainly ended up with a close fit to the reconstruction. I'm just wondering how you got there!
Trevor
Thank you Trevor. The shortest answer is that both. But indeed, this is a more interesting issue (at least to me), deserving of a slightly more extensive response. To start, yes indeed it is a kind of reverse engineering, hellishly difficult, time-consuming and fraught with the risk of an easy mistake, especially since in this particular case the input material (a shipwreck), is far from ideal in the sense of its present geometrical regularity of shape, and secondly this exercise had to be based on material already interpreted (indirect illustrations instead of, for example, a 3D scan of the original object), which creates additional complications and risks.
The aim is to create a complete, coherent and unambiguous conceptual (geometric) (re)construction, which makes it possible to obtain just such a shape as a whole. For this era, they still have to meet the condition of obtaining immediate ideal shapes, in the sense of their fairness, as in those days design on paper, at least complete design, was not yet practised, which only allows for smoothing treatments already in the design stage (i.e. synchronizing cross-sections, waterlines, buttocks, possibly diagonals).
In general, it can be said that the geometric methods applied cannot be completely arbitrary, but must follow firmly from procedures and methods known from written and graphic sources derived from period shipbuilding treatises, manuals, drafts etc. However, this is not a limitation, quite the contrary — familiarity with methods known from these sources makes it easier, if not at all possible, to make such reconstructions successfully. I would also add that I would probably never have obtained (I trust) the correct result in this particular case if it were not for the knowledge and previous experience gained in several dozens of similar projects, and always based on period material (whether plans, wrecks or period models).
Ultimately, it turns out that through this graphical method of analysis, it is possible to find out (or prove) things that are absent or too vaguely described in the relevant written works for just a particular region and time. In other words, its results perfectly complement and even correct the current knowledge derived from unfortunately incomplete written sources of the period (and mistakenly or too arbitrarily interpreted today).
Perhaps it is a kind of deficiency in my descriptions that there is not a detailed reference to the sources for every detail every time, but such a way would hamper my essential task and, moreover, in the vast majority of cases, I guess it would easily exhaust the readers. In this sense, I do indeed have inclinations to show finished results rather than ways of achieving them.
I hope I have formulated all the above and touched the issue in a way that answers your concern or question
Oh, I should also add that the renders in the first post show the reconstructed geometric model in an earlier version, that is, with a slightly larger forward rake than in the later, final version. This of course has to do with the incomplete wreckage (no bow) and having to choose between several possibilities. I could, admittedly, replace these renders or add new ones quite easily, but essentially the intention is that the design method recreated for this case, and presented in such great detail, would enable interested individuals to create a plan or model of this ship themselves.
MSW member MikkiC:
You explain things well Waldemar. I'm enjoying this well written -rather academic - thread. My brain is so engaged and ready for the next entry.
MSW member Alvb:
Thank you for your detailed explanations. I consider your work extremely valuable. The constructions are understandable and easy to follow. The only thing that wasn't entirely clear to me was how the regression curves were determined.
And thank you, Waldemar. That helps a lot.
I'm not as familiar with 16th-Century ship design as I would like to be, so it is good to see your explorations.
One point though:
That is certainly very true, as regards paper or scale drawing any other two-dimensional surface. But did English shipwrights of the early 16th Century not make much use of battens and ribbands to complete a faired design full-scale in 3-D? That had been the late-Medieval practice in the Venice Arsenal and it was still relied on in vernacular shipbuilding in 18th-Century New England. With the (Old) English familiarity with clencher construction through to 1500 and beyond, running a board across the futtocks to determine a fair curve to stem and stern would seem a natural choice.
If they did "design" parts of the hull as it grew on the building ways, it may be impossible to match the finished shape using only the very simple graphical methods that I would expect so early in the adoption of carvel construction. Your curve of the maximum breadth forward of the main bend, for example, is not an arc of a circle. Either the original shipwright used a more complex curve or he did not draw that at all.
Trevor
Expand
In general, I think it can be said that during the actual assembly of the frame structure on the building ways, the procedure was just as you explained. However, there is not at all any contradiction in this with the necessity of some frame pre-designing, because in order to use aligning battens or ribbands at all, first the shape of at least a few frames, erected in the first place even before the ribbands could be fitted, had to be defined. Only then could all the rest of the frames be erected (or even shaped according to these temporary ribbands). Similarly, in cases, when the shape of all the frames is predefined, not merely the conceptual ones, these alignment ribbands are still needed to guide the next, gradually inserted elements into the skeleton structure. Especially since at that early period the frames were not yet a unified whole, but their individual elements (floors, naval timbers, 1st futtock, 2nd futtocks, ..., toptimbers) were not connected to each other at all (so-called ‘floating’ frame components, precisely as in Mary Rose's case). This circumstance, in turn, meant that matching such separate components to the guiding ribbands, even if they had been not overly precisely cut beforehand, was almost always (better or worse) possible.
However, the more precisely the whole process was carried out beforehand (i.e. designing, tracing, cutting out timbers), the less work there was with the subsequent dubbing of the resulting hull surface. In this context, it is telling and interesting to note that in Russian shipyards in the 18th century (i.e. at a time when full design on paper was employed), whole teams of carpenters were permanently employed to do nothing but dubbing, although such a peculiar “extravagance” could probably only be possible in state-sponsored ventures. But this is a familiar problem in England itself as well — William Sutherland, in his 1711 work, even strongly advocated a return to simpler design practices, essentially inherited from the Middle Ages, allowing or facilitating greater precision in all preceding stages, precisely to avoid or at least reduce this essentially rather ‘idle’ in the production sense and also economically damaging process of dubbing.
To put it yet another way, these first ‘futtocks’, to which guiding ribbands or battens could be later attached, also had to be designed in a meaningful/regular geometrical way, because some random shape of these initial ‘futtocks’ would not have ensured a run of the required shape and at the same time fairness of these guiding ribbands or battens. This is precisely what this reconstruction shows — the design process of these first ‘futtocks’, only here they are called ‘conceptual frames’. Building models using the plank-on bulkhead technique is also a very good analogy. On sloppily designed bulkheads, i.e. sporting rather random shapes, it is virtually impossible to lay the planking in a smooth way.
It is also worth adding that the pre-definition of the frames did not necessarily start as late as the implementation of carvel construction. For example, I am now looking at the lines of the so-called Newport ship of the 15th century, sporting clinker planking, and it tentatively looks to have been designed using exactly the same method as was employed for Mary Rose 1511. But indeed here too it is worth doing a proper survey for verification.
Yes indeed, it is not a single-arc curve, but in this case it is a curve composed of two arcs of a circle (in the top projection), as is its part for the aft half of the hull. It is interesting, and probably usually surprising to today's readers, that in fact this line did not even have to be drawn beforehand on the longitudinal projections, but its coordinates could immediately be approximated on the body plan in actual size on the mould loft, especially with the help of various geometrical devices of the mezzaluna type. This was possible and at the same time particularly easy for the central segments of this line (indicated in the reconstruction diagrams above), which are already just single arcs of circles, because these central segments, i.e. between quarter frames, are tangent to the longitudinal line parallel to the ship's axis. This is a broader and interesting issue in itself, but I think I have just produced an excessively long elaboration anyway...
Thanks. I have tried to formulate the explanations as clearly as possible, even avoiding unnecessary additions that only obscure the whole picture. If there is something specific that needs more attention, just please point it out.
MSW member Martes:
It should be noted that the design of the Mary Rose was not borne in vacuum.
Apart from an inventory which gives the numbers of her masts and yards, there are only two clues to the Regent’s design, a building warrant which states that she is to be made “like unto a ship called the Columbe of France” (of which nothing is known either) and a note that she was made by a “novel construction … with ordnance and fittings”. For the Sovereign we know even less. Apart from an inventory which lists the number of masts and yards,[2] there is only a mention in 1525 that she is in bad condition but worth repair because “the form of which ship is so marvellously goodly that great pity it were that she should die”.
The “novel construction” of the Regent could refer to a change from clinker building to carvel or to the introduction of the square stern which occurred generally about this time. Perhaps it was the answer to the mounting of high-velocity, long-range guns in the bows of galleys, which in a calm could manoeuvre to fire into the weak and unprotected sterns of the great sailing ships. The obvious defensive answer was to mount heavy guns in the sterns of the carracks, and more of them; and the only way to provide space for a rearward-firing battery was to make the stern square.
The best, he thought, was his own command, the Mary Rose. “Sir, she is the noblest shipp of sayle and grett shipp at this hour that I trow be in Christendom. A shipp of 100 tone wyl not be soner at her … abowt then she.”
With these qualities, plus proven success in battle, it is not surprising that the design was continued. As replacement for the burnt Regent, a scaled-up version of the Mary Rose was ordered to be built. Called at first the “Gret carrik” Imperyall, she was later named the Henry Grace de Dieu, but nowadays is more commonly referred to as the Henry Grace à Dieu or Great Harry.
Alexander McKee - King Henry VIII’s Mary Rose (1973)
There is a clear succession of design evaluation here, from the French original (the carrack Columbe) through the Regent and larger Sovereign (the parts of which are known as the Woolwich ship), the Mary Rose and ultimately the Great Harry.
McKee - who is responsible for the finding of the ship and raising her - made an unparalleled search in contemporary documents in order to locate and identify the wreck.
Thank you, Martes, for this information.
Somewhat spontaneously — there is a bit of irony in the fact that, for interpreting this particular case, it is the French sources that have proved so pertinent (mentioned above carrack Columbe c. 1500, Fournier's remarks of 1643, the design of l'Aurore 1697 and other French ships of the era, Duhamel du Monceau's treatise of 1752) . It should be noted that these are strictly technical issues. Up to now, as far as I am aware, attempts have been made to create such a conceptual reconstruction of the Mary Rose, however, they were based rather on English shipbuilding textbooks 100 years and more later, which describe issues that were already specific to a period when Mediterranean methods had already been adopted in England for good and developed further. Consequently, these attempts could not and indeed did not produce any meaningful results.
MSW member Martes:
Those quotes also underline the careful attention given to the forms of the ship hulls already at this time, with navies watching each other's designs and wide exploitation of proven and successful variants.
Refinement
Already during the work in progress, a 3D scan of the Mary Rose wreck was accessed (many thanks to the Mary Rose Trust, and especially to Alexzandra Hildred), and although just of the ship's interior, with only a residual surfaces of the exterior planking, the scan nevertheless allowed an additional verification to be effected and even some refinement of the results already obtained as well.
First of all, the scan itself had to be corrected, which proved to be quite difficult in itself due to the particularly severe and at the same time extremely complicated nature of the distortions of the original (wreckage). Overall, this verification went happily well, except that it sparked an additional local correction of the bow shape, consisting of a slight increase in hull volume at this area. Most importantly, however, the previously found design concept of the ship could have remained unchanged, and even the correction of the bow shape itself could have been done precisely in a way that made use of this previously found design method, specifically by reducing the initial radius of the arc of the bottom in the forward quarter frame from 10 to 6 feet. All the rest of the geometric components followed ‘automatically’ the existing geometric procedures of the design, generating, in effect, a more full bow shape. It could be said here that this is one of the main advantages of this particular approach or way of interpreting finds of this kind.
The graphics below show, among other things, pairs of corresponding contours for each station being compared, the outer lines representing reconstructed lines and the inner lines being cross-sections of the interior of the hull (thick yellow lines). The distance between these contours is, of course, due to the thickness of the frame timbers and also, in a rather irregular manner, to the thickness of the ceiling planking, riders, braces and knees.
The final (or refined), reconstructed body plan of the Mary Rose 1511 is as follows, and the alterations, compared to the previous variant, affects only the fore part of the hull. All of the earlier explanations on the design concept, or geometric construction, apart from the change in the value of one radius mentioned above, remain valid:
MSW member Martes:
Can you describe a format that could have been used to transfer the design from one place to another, if it was not done graphically?
What would have to be written on that piece of paper that an English agent brought from France describing the Colombe, so that English shipbuilders could unpack into a hull shape and be confident that the result matches the original?
MSW member Alvb:
I'm currently building a small model from roughly this era. I realized that the bow area doesn't match the visual impression Brueghel creates in his depiction of "Icarus." The design presented here, with its strongly curved breadth sweeps in the bow, comes closer to that.
Therefore, I've taken the liberty of applying the presented method to my design.
Thanks to your clear description, it's easy to transfer.
Only the reconciling sweeps—circular segments that connect tangentially to given arcs—should be easy to find using graphical methods, but no!
Could you perhaps briefly explain to me how to find these sweeps?
Thank you very much.
Thanks, yes that is an otherwise pertinent question. Admittedly, there is a corresponding specialised function in CAD software and everything is done in a flash, however, in actual size, or even drawing manually to scale, it is also or can be trivially easy.
Please see the diagram below. I have drawn a simple instrument there, for example a wooden or plastic one. Basically it's a flexible strip, and it has two segments. The wide, unbending segment of it is applied to the straight lines of the bottom (or to the straight dashed lines in the diagram if the curves of the bottom are arcs), and the remaining thin and flexible part of it is then bent until it reaches the lower breadth sweep. Ideally, the bending force should be applied roughly at the spot of the expected touch point with the lower breadth sweep.
If you still have any issues, please go ahead.
Thanks a lot, that's one of the very reasons of this presentation
It is also worth remembering that seagoing ships sporting short hulls must have sharp underwater hull lines.
MSW member Martes:
The Woolwich ship, the Sovereign of 1487, demonstrates a similar sharp turn of the hull near the gripe forward as evident from this photograph of the wreck:
The photo is taken from Sovereign of the seas : the seventeenth-century warship, 2011 by James Sephton.
Together with the comparison of the midship section of Sovereign with the Mary Rose, this reinforces the similarity of the design of both ships.
For the tragic history of the wreck see here:
https://thewreckoftheweek.com/tag/sovereign-1487/
It is quite possible that in this way we are entering the realm of speculation as to events that may have actually taken place, but the idea itself is most pertinent, because this is exactly how things were done, that is, a set of values defining the geometry of a ship was written down numerically, which in effect quite unambiguously recorded the features of a particular design and later made it possible to reproduce it faithfully. Provided, however, that the design paradigms, i.e. the design methods with their specific handling procedures, were identical. This is also a good opportunity to complete such a basic list found at the beginning of the thread (entry #4) and to group together in one place all, hitherto somewhat scattered data of this kind.
Slightly reiterating here, assuming that the English shipbuilders followed exactly the same design methods as their French counterparts, and that these were as interpreted above, for a faithful reproduction of the underwater part of the hull they would have needed the following set of data from this alleged agent:
Mary Rose (1511) – dimension set
General dimensions
40 feet​
39 feet 4 inches​
3.5 x breadth outside planking​
140 feet​
3.5 x breadth inside planking​
137 feet 8 inches​
1/10 x length between posts​
14 feet​
Keel assembly & lengthwise division
Forward rake
2/13 x length between posts​
21 feet 6½ inches (21.54 feet)​
Radius of the stempost
3/4 x breadth​
30 feet​
Aft rake
1/13 x length between posts​
10 feet 9 inches (10.77 feet)​
Height of sternpost
height of 1st deck at midship (10 feet) + height of 2nd deck at midship (7 feet) + height of 3rd deck at midship (8 feet) + rising of 3rd deck aft (6 feet)​
31 feet​
Keel length
10/13 length between posts​
107 feet 8 inches (107.69 feet)​
Placement of double master frame
6/13 of the hull length (fwd)
7/13 of the hull length (aft)​
Placement of quarter frames
3/13 of the hull length (fwd)
10/13 of the hull length (aft)​
Risings and narrowings
— Line of the floor
Deadrise at midship
6 inches​
Rise forward
6 feet​
Rise aft (height of tuck)
12 feet​
1/4 x hull breadth​
10 feet​
— Line of the breadth
Height above waterline at midship
3 feet​
Rise forward
5 feet​
Rise aft
7 feet​
Reduction of the breadth at quarter frames
1/6 (fwd)
1/5 (aft)​
Transom length
4/9 x breadth​
ca. 18 feet​
Quarter frames
Radius of sweeps of the bottom
6 feet (fwd)
10 feet (aft)​
Radius of lower breadth sweeps
12 feet (fwd)
12 feet (aft)​
Mainmast position
1/2 x length between posts​
I will also take this opportunity to attach the paper by R. C. Anderson dated 1960 and published in The Mariner's Mirror, which indeed cites an extant document of this nature and from this very period. It concerns the ship Mary of the early 16th century. The set of figures is admittedly somewhat different from the list above, and the values given are absolute (as opposed to relative proportions), nevertheless a number of the items recorded relate specifically to hull shapes and not just the size of the ship and its components.
MSW member Martes:
MSW member Martes:
I see at least two English ships on the Cowdray engraving with apparent additional side timbering:
image.png.6437a82ed7d110bc7bef501d195c3f73.png image.png.e680103ac54b4771b79c4cd140ed5db3.png
But the Great Harry is not one of them.
MSW member Martes:
Many thanks for compiling this detailed list, especially in comparison with contemporary document.
It shows the relative ease with which a ship design could have been transferred - a scrap of paper with innocuous numbers would suffice, as opposed to large and cumbersome scale drawings - and, I suppose, it is possible to assume there would have been some code or indicator as to which design method was used by the builder of the original ship.
Yeah, as we've discussed before, those round hull cross-sections ‘screamed’ to be corrected as soon as heavy artillery started to be installed on the ships. However, the Mary Rose was not one of them neither. It even occurred to me that until the adoption of the Mediterranean three-arc master frame design, the ships were built as before, i.e. sporting single-arc master frame, and immediately “upgraded” to the new standards and needs by those side “blisters”. Perhaps they simply could not design any differently than before. And this is why there was such widespread and rapid adoption of this Mediterranean specificity in Mathew Baker's time.
MSW member Martes:
English kings, including Henry VII and Henry VIII traditionally relied, besides the local shipwrights, on Portuguese masters. IIRC, most Portuguese designs into the 18-th/19th centuries are closer to "northern" tradition, but during the reign of the Queen Mary London was full of Spanish retinue of Philip Habsburg, and I was extremely surprised to realize at some point that for long five years it was he and his administration who managed most of England's affairs. This - at least partly - could explain the technological pivot.
On 5/27/2025 at 10:40 PM, Martes said:
English kings, including Henry VII and Henry VIII traditionally relied, besides the local shipwrights, on Portuguese masters. IIRC, most Portuguese designs into the 18-th/19th centuries are closer to "northern" tradition [...].
To be honest, I am not sure that the widespread dissemination of ideas and methods in this later period does not already make such very late Portuguese examples not very authoritative, however, when one looks, for example, at the designs of the master frame by Portuguese Fernando Oliveira from around 1570–1580, such a view already takes on the characteristics of plausibility. They are round, and have a quite narrow bottom. As do most of the designs for seagoing ships in Livro de Traças de Carpintaria, 1616 by Manoel Fernandes, a Portuguese too, which also demonstrate essentially quite circular sections and narrow bottoms.
Below are master frame designs from the manuscript O livro da fábrica das naus by Fernando Oliveira, all sporting a single-arc contour and relatively narrow bottom.
[...] during the reign of the Queen Mary London was full of Spanish retinue of Philip Habsburg, and I was extremely surprised to realize at some point that for long five years it was he and his administration who managed most of England's affairs. This - at least partly - could explain the technological pivot.
Personally, I associate the implementation of the three-arc master frame design in England with Mathew Baker's educational trip to Italy in the early 3rd decade of the 16th century, precisely to learn Venetian ship design techniques. However, your suggestion that Spanish involvement during Queen Mary's reign may have influenced this transformation also seems plausible, given that the Basque whaler San Juan, dating from around 1550, also exhibits just such three-arc master frame configuration. And, after all, the two supposed causes or stimuli need not be at all mutually exclusive, quite the contrary...
Interesting speculations but I would question the existence of a supposed "Spanish" versus Portuguese distinction.
San Juan was, as Waldemar has said, Basque. Yes, her builders were (at the time) subjects of the Spanish king but they spoke a (very) different language and lived in a different culture from that of Castile. The Galicians were different again and, to this day, speak a language closer to Portuguese than to the official Spanish of Madrid. On the other coast, Catalan shipwrights were part of western Mediterranean maritime culture and spoke yet another language. In short, Iberia could boast of multiple shipbuilding cultures, not a simple break between Spanish and Portuguese -- while both of those fell under the same king in the time of Philip II, of course.
Further north, Henry VIII had a Mediterranean-style galley built and his French opponent went so far as to have a galley-building yard constructed on the Channel, complete with shipwrights brought from his other coast, so there was ample opportunity for design concepts to be exchanged.
While invoking Henry, is there reason to doubt the oft-repeated tales of his personal interest in "race-built" ships? If he was, as so often claimed, encouraging experimentation in shipbuilding, then his shipwrights had incentive to gather ideas widely.
Trevor
MSW member Martes:
It is all very entangled, because an origin of a method does not generally mean the origin of it's practitioners. Designs, methods and shipwrights were known to move from one country to another.
Spanish professionals, accompanying or arriving in the wake of prince Philip could have included people from any region that were under the rule of the Spanish crown, or any foreigners in Spanish service. Virtually almost anybody.
Sometimes a king tried to force foreign methods on his own shipbuilders - Ian Friel mentions an (unsuccessful) attempt by Henry V to force the English shipwrights to repair captured Genoese carracks; they took the money, but refused. McEvolgue writes that Edward IV imported Portuguese shipwrights and encouraged them to teach their craft to local shipbuilders.
Henry VII as we see ordered to copy a single French carrack in various sizes, and Henry VIII continued the practice - because until introduction of heavy broadside artillery this was a very successful design - and all of them purchased much ships abroad.
If indeed the stability problem had been perceived after the sinking of the Mary Rose and if there was a targeted effort to find a design solution to it (as opposed to girdling/furring a ship after building), the information may have been obtained from many different sources simultaneously, including professional migration, espionage operations, etc.
Thank you, gentlemen, interesting reading. My personal perception is that the very attempts to resolve quite specific technical issues solely on too high, shall we say, general cultural or humanistic level, which may in fact lead to virtually any conclusion, emphatically confirm the necessity of a relevant and routine study of the wrecks (preferably in the context of other artefacts from the period — iconography, written sources), precisely from the conceptual angle, and not primarily from the carpentry angle, to which it has so far usually been confined. Otherwise it will be a kind of chasing one's own tail, which is unlikely to lead to anything authoritative.
In fact, it is even worse than that, because a few decades ago such considerations, based mainly on general historical premises and only rather selectively and at the same time overly flexible to sources of a technical nature, led to voluntaristic or even fanciful hypotheses and theories which today do not stand up to confrontation with the results of analyses of a conceptual nature. Nevertheless, now these theories, unfortunately already well established in the popular consciousness, are naturally defended by their authors and proponents, including by attempts to discredit troublesome, later contributions in probably every possible way, and even by attempts at bribery, preferably for the cessation of relevant research in this area altogether (I know what I am writing about
Let me use an example. It has been hypothesised above that Henry VIII's shipwrights had an incentive to gather ideas widely, due to the ruler's inclinations on the matter. Maybe, but at the same time it is known that shipwrights are probably one of the most conservative professional groups because of the risk of paying too high a price for experiments with unknown consequences. Besides, it is known from sources that they were able indeed to refuse their rulers, such as the above-mentioned refusal to overhaul the Genoese carracks, or the refusal to rearrange the bow of one of the large ships (Great Harry or Mary Rose) to install additional heavy guns there. A rather apt summary of this issue is perhaps Duhamel du Monceau's comment, which makes it clear that the shipwrights stuck rather tightly to one design which they considered good enough, implementing it repeatedly in subsequent builds, and for this very reason encourages them to be more adventurous in their experimentation. With greater effect? Personally, I doubt it, in keeping with the paremia — tempora mutantur, sed homines manent eodem.
Very true!
If Henry really was interested in improving ship design (and I have never seen citations of original evidence of that claim), then the key point would have been that a shipwright could afford to make a mistake, because his sponsor desired experimentation. As you say, shipwrights (in contrast to boatbuilders) usually could not afford to step very far outside established bounds, as the costs of failure were too high (and there was no realistic theoretical understanding on which to base advances before the late 19th Century). A king willing to spend in an attempt to leap ahead could have made a big difference.
Trevor
On 5/29/2025 at 6:48 AM, Martes said:
[...] because until introduction of heavy broadside artillery this was a very successful design [...].
Agreed. Overall, the hull shapes may be considered successful indeed, deserving the term ‘the noblest shippe’ — the lines of the hull seem to be sharp enough for the ship to move and keep to the wind well, yet not excessively, which would only make her prone to the pitching effect and to the rapid hogging as well (incidentally, as could be revealed from the wreck's scan, at the time of her demise, some 1.5–2 feet at the midship). Just that circular hull cross-section with the narrow bottom, and the resulting lateral stability problems...
Admittedly, It was still planned to make and present a regular line plan of the underwater part of the hull, possibly for use in model building, for example. Instead, until then, for a demonstration of the final shape of the underwater part of the hull, below are quick renders including waterlines, perhaps best illustrating the nature of the Mary Rose's hull shapes. As a reminder, the waterlines shown here are purely consequential, that is, they took no part in the formation of the shapes (i.e. on the basis of the cross-sections, waterlines and buttocks synchronization, procedure not applicable at the time). These were obtained in their entirety by the found design method shown earlier.
MSW member Baker (@Backer64 on this platform):
For the preparation of the upper deck, I have been in contact with the Mary Rose organization this week.
It appears that the anchors had just been lifted. As a result, they were still busy storing the anchor cables, so that they were still partly on the upper deck.
So they went to battle in a rather hasty and disorganized way, it seems.
In an area with little room to maneuver.
An overloaded ship.
etcetera...
And,
again, great study on the hull shape
:imNotWorthy:
On 5/30/2025 at 9:28 AM, Baker said:
So they went to battle in a rather hasty and disorganized way, it seems. In an area with little room to maneuver.
Thanks a lot, Patrick. That's interesting and new information you provide above regarding the unfinished process of clearing the ship. Also, this is probably a good time to say that your adventures or endeavours, especially those concerning the formation of the hull shapes of your impressive Mary Rose model, which you show in your thread, also influenced the very idea of dealing with this case
Later design parallels
Ships of similar design concept to Mary Rose 1511, from different periods and different regions of northern Europe, have already been mentioned earlier in this thread. Below are a handful of such quite numerous, specific examples, ready at the same time to be shown graphically.
Among the cases studied in detail so far, mention should be made of the design of the French heavy frigate of 1686 by Pierre Chaillé (relevant presentation to be found in another forum), and the design of the French light frigate l'Aurore of 1697 by Philippe Cochois (awaiting a separate detailed presentation). Here a reconstruction of the body plan of the latter frigate superimposed on her original period plan. Among the fundamental features, decisively determining the similarity of the methods employed, attention should be drawn first and foremost to the order in which the contours of the conceptual frames were formed, as well as the specific geometrical procedures used for this purpose. Identical as in the Mary Rose case, the bottom (green) was formed first, followed by the lower breadth sweeps (blue), and only in the last step were the two sets joined by reconciling sweeps (red), tangentially at both ends. Among other things, it is still worth pointing out here not only the very fact of the use of quarter frames, but also the same specificity of their use as in the case of Mary Rose.
And the draught of l'Aurore of 1697 in its entirety, including the body plan shown above (French archives):
Regarding the fundamental importance, in conceptual terms, of the hull bottom, which is in fact the design basis of ships built in the Northern tradition (in the literal sense, as opposed to the Mediterranean tradition), and the specific use of quarter frames, this is particularly very well illustrated on the surviving design proposals of French capital warships of late 17th century. Below is a drawing of one such design for a first rate ship by Laurent and Étienne Hubacs from 1679 (French archives), and among the not very numerous design elements (but already unambiguous for obtaining the specific form of the hulls), there are in particular the two design elements mentioned earlier (that is, the bottom featuring its curves and both quarter frames). Notable are the much fuller shapes at the midship than those of the Mary Rose (providing in themselves better lateral stability and, of course, carrying capacity), required for a heavily armed vessel. In passing, only one of the two double master frames is drawn on the plan (the aft one is omitted), presumably because of the quasi-identity of this pair.
In fact, it can be said that the entire description of the Mary Rose's design concept so far, even including the comments on the specifics of the shapes and the resulting properties of ships, is also relevant to the above examples (which, of course, no longer applies to their proportions, individually selected for the intended, specific application of these vessels). Also, by the way, it is worth appreciating the overall flexibility of the Northern method, allowing a wide range of shapes to be obtained according to needs and requirements, which is probably why, among other things, it has been widely used for such a long period of time.
It is possible to point to more similar period sources, written and iconographic, as well as providing more detailed explanations, but I guess everything should have its limits .
Nevertheless, leaving aside the almost unexplored archaeological finds from this conceptual angle, it is probably appropriate to point out, perhaps more as a curiosity, yet attractively much closer chronologically to Mary Rose 1511, the case of an intriguing votive model of a galleon, dated to the late 16th and early 17th centuries, now in the collection of the Historical Maritime Museum in Stockholm (Votive ship -Sjöhistoriska museet / DigitaltMuseum).
Although an attempt at a conceptual reconstruction of this model has already been made by Peter Kirsch and presented in his excellent publication The Galleon. The Great Ships of the Armada Era, published in 1990, but now, in the light of recent investigations in this area, it may raise objections due to it being essentially based on English shipbuilding manuscripts of the first half of the 17th century, closer to Mediterranean traditions, which in effect generated the trapezoidal hull cross-sections in this reconstruction, characteristic precisely of Mediterranean three-arc master frame designs.
However, the cross-sections reconstructed in this way are quite noticeably different from the round cross-sections featured by the original model, as can be judged from the following comparison graphic (as an aside, an identical treatment was attempted in the inevitably unfinished attempt at a conceptual reconstruction of the Mary Rose herself, published in one of the chapters of the ship's monograph). Naturally, it has to be taken into account that the hull of the original model is probably somewhat flattened in the manner typical of votive models; nevertheless, the specificity of the shapes in this model is quite telling and begs for the use of Northern, single-arc master frame design (plus reconciling sweep), precisely as in Mary Rose 1511. Admittedly, on the one hand, such a choice might be made easier by more confidently establishing the provenance of the model itself (essentially unknown) on criteria other than the shape of the hull, yet, conversely, this very feature might help to establish the place of origin and time of its creation.
As for the plausibility of the very specificity of the shapes of the Stockholm galleon model itself, at least in the light of the corresponding cross-section shapes of the wreck of the Swedish naval ship Bodekull, in service between 1661 and 1678, it does not raise any reasonable doubts, as can be compared with the sample graphic below. It is worth noting here that Bodekull was built in the period when English design methods were only just beginning to be implemented in Sweden.
The 3D scan of the wreck is made available on the Sketchfab website by Swedish Historical Maritime Museum (3D models by SWEDISH NATIONAL MARITIME AND TRANSPORT MUSEUMS (@maritima) - Sketchfab), and more about this wreck and the ship itself may be found in a paper by Niklas Eriksson, A New View of the ‘Edesö Wreck’: identifying the Swedish naval vessel Bodekull, built 1659–1661 and sunk 1678 from written sources, 2018, and attached below.
Anticipating the end of this thread, I would once again like to thank all those involved, especially Martes, whose comprehensive assistance and on a variety of detailed issues proved invaluable.
Waldemar Gurgul
Thank you for posting all of this great information, Waldemar!
If you are coming to an end, I must start over and try to assimilate everything you have offered. However, I still get the feeling that I am missing the foundations of your conclusions. Are there earlier threads in which you developed your arguments?
Trevor
Thank you very much, Trevor. Yes, a whole series of threads in this area have already been created. The majority of the most mature, and also the most closely related to Mary Rose's case, as they concern the Northern European tradition, are on the sister nautical-modelling forum (easy to find, I believe). All in all, it has been quite a long and difficult road allowing for the eventual breaking free of the overly speculative and yet universally uncritically accepted doctrines of today on this issue.
I would also like to add, for the sake of greater clarity, that this very issue, in its historical terms and significance, is indeed very closely related precisely to Mary Rose herself, and more specifically to her incomplete, haphazard and simply wrong conceptual interpretation (or rather only a residual attempt at such an interpretation, limited to ‘forceful’ matching of a more or less random arcs to the contours of Mary Rose's frames), published in one of the chapters of Mary Rose's archaeological monograph. Archaeologists themselves, or at least some of them, are nowadays drawing attention to this fatal circumstance, it is just that no one has so far been able to offer a complete yet convincing solution.
In addition, this disastrous state of affairs has also been largely contributed to by the failure so far to offer a proper study and publication of Mathew Baker's manuscript, which essentially, as it seems, describes the Venetian methods he learned there. In fact, even the availability of the manuscript itself is so far strictly restricted to only a small circle of interested parties, maybe not without reason. As a result, in today's historiography and consciousness, “classical Venetian methods” are taken for “classical English methods”, and — quite ironically and also misleadingly — the Baker's manuscript itself is even called the Fragments of Ancient English Shipwrightry.
I am attaching below a file with published conference materials from 2003, from which one can see just how weak premises today's doctrine on this issue has been based on (apart from the general historical ones, which by the way you cited earlier, the catastrophically wrong conceptual interpretation of the Mary Rose case and a handful of rather naive explanations, or rather speculations, of a conceptual nature). Sadly, this is the result when technical issues are looked at and explained in, shall we say, a predominantly “humanistic” way.
In fact, it may be even surprising that nobody has done anything about it so far, at least not in an effective way, but this, I guess, may have been influenced by more than just substantive considerations.
Nowacki Horst, Valleriani Matteo, Shipbuilding Practice and Ship Design Methods From the Renaissance to the 18th Century, 2003, part 1:
Nowacki Horst, Valleriani Matteo, Shipbuilding Practice and Ship Design Methods From the Renaissance to the 18th Century, 2003, part 2:
As a kind of epilogue to this thread, I am also including here a case from another, rather distant part of Europe, nevertheless thematically and chronologically highly relevant to the issue.
In 1570, the Polish ruler Sigismund Augustus, intending to build a royal fleet practically from scratch, instead of turning to Gdańsk/Danzig, which, after all, was at the time one of the largest, if not the largest builder and exporter of ships in Europe, but over which he had almost no political control, asked none other than the Venetian doge to send an expert (granted) who could design and build ships. Most telling, however, is the expressed rationale for this request, clearly stating that Venice was second to none when it came to the ability to build the best ships in the entire known world of the time. Or at least that is what was thought at the time.
