Method of stowage - ballast and ground tier in the hold etc.
  • Thread starter Thread starter Uwek
  • Watchers Watchers 5
Iron Ballast
View attachment 61877 View attachment 61878
A shaped piece of iron ore, probably used as ballast on H.M. Armed Vessel 'Bounty'. For online access text please see the 'Notebook' field within the 'Mail' icon.
Read more at http://collections.rmg.co.uk/collections/objects/63330.html#GsXYtXkSwYOHhMO9.99
Interestingly the Brit RN also used large lumps of Flint as ballast, here in Australia it can be found along our East coast beaches sometimes, although nowadays rounded into Sugar Loaf like configuration (probably from the tide and sand wear over a couple of hundred years). I've collected some of them and can provide images if anyones interested.
Yes please - would be interesting to see
Please forgive my absents, I'll dig through my shed here and find them, I still have a few in a canvas bag.
I build Flintlock Rifles and Smoothbores as well, so Flint is an ongoing interest of mine.
Hello. I was wondering about ballast. Some of my “regulars” may know I am currently building an 1835 English Packet Ship called Seagull.
I believe that it may be planked both internally as well as externally? If this is the case how do you prevent the stone ballast shifting fore and aft as well as riding up the sides during heeling etc? I guess there may be boards across the hull as well as laterally along the sides to compartmentalising the ballast and prevent shifting.
If the planking internally is incomplete then the stones can be placed between the frames assuming there is space. Does this then impact the bilge water capacity and drainage to the pump sump?
Any input, sketches or photos gratefully received. Thanks in advanced Seagull Shipwright.
I am pretty sure stone ballast or shingle was much earlier. Kentledge came into use in the early 18th century and would have been more common in your time frame. These bars would not shift in the hull. There are contemporary pieces in museums around the world and you can find photos on the internet. The approximate amount was typically 30 tons of ballast per 100 tons of rated ship tonnage
Approximate typical size
Allan, As usual thank you for passing on your knowledge and research. Greatly appreciated.
My pleasure. I just happened upon a lot of this information on ballast last week at a meeting with archaeologists concerning the HMS Fowey (44) 1744 which sank in Biscayne Bay in 1748 during a hurricane.
Just found an article on the Fowey that mentions the kentledge pieces weighed about 320 pounds each.
Thanks to all who replied to my post on ballast. A couple of additional questions. We’re the pigs bolted down. Were they mixed with shingle to prevent movement? In Uwek’s diagram were the bulk heads full height or high enough to prevent fore /aft movement of the ballast.
