Viking Longship - tiny Aoshima model
I followed Harry Houdini's suggested method for wood effects: see here and here and here :-) This is my first time using this technique, which requires the Stylynrez primer. It took me some time to get it to work - it is surprisingly viscous, considering that it is "ready for airbrushing". But Harry helped with some advice (use at least 30psi and a 0.5mm needle) and I got it to work. Then covered it with lifecolor pigments and...it looks quite convincing!
Shields now finished and cleats added to the side railings, for sheets and tacks. Not too long to go now! Once the deck is finished and attached, I can start the rigging, which is a little less involved than the Golden Hind I am working on.
Beitass added...with some rope coils for the lines controlling it.
I also added some rope coils for the sheets, tacks and braces. My first attempts, and some are neater than others. But I expect the Vikings were not as disciplined as sailors in the Royal Navy.
I have started adding the oars...the last step!
Looks great air brushing takes awhile to master dont buy cheap airbrush sets they are rubbish and you will get very frustrated with it.
And it is finished!
You will notice that I did not add shrouds. Technically I think there should be two or three (per side). But they are not always seen in contemporary iconography, although I think they are always present in the reconstructions. I decided to leave them for two reasons....
1) I did not have the right sort of blocks - they are not the usual deadeye arrangement
2) I did not have enough room to add them!
So... it's a compromise. C'est la vie.
I hope this log helps someone in the future. I appreciate the feedback, Thanks everyone.
I was contemplating a separate little case for the Viking ship. It fits easily in my display case, because it is so small! But it is also adorably cute - and it should be seen more widely than it would be if it were located in my hobby room. So, I was thinking of getting it a case of its own.
Then a friend said that it would look good if I had others on the same scale; they could all go in the same case. That got me thinking!
There is a Greek and a Roman warship in the same scale...so I bought those! A nice little trio!
A warning to any one interested in these: they were initially made (I think) by Imai, then Aoshima. I think some are now marketed under Academy.
The Roman one is harder to find than the Greek. I have no idea why. Scalemates info is available for the Roman ship and the Greek ship.
But - be warned, there is a 1:72 scale version of each and I found that many sites (eg ebay) had them listed as the 1:72 scale version but the box gives the length as about 17cm. That is most definitely not the 1:72 version. So be careful. Different incarnations of the kit list it as "no scale" or "1:250" or "1:350", but the best way to be sure is that the model is about 17cm in length.
In doing the searching for these items I discovered there is also an old Imai Santa Maria in the same scale:
So I might have to get that as well...and put all four in the same display!
The other ships I bought just arrived. I was able to get all four:
  • Viking ship (so that is a second one...)
  • Greek Warship
  • Roman Warship
  • Santa Maria
They are all about the same size, if not the same scale. Very cute.
The Roman and Greek are Aoshima, probably reboxings of the original IMAI kits?
But the Viking and the Santa Maria are IMAI - and they are very very faded (not nearly as bright as the picture shows!) I wonder of they are originals from the 60s?
Some collector might prefer to have them as they are.... Being the heathen that I am, I intend to build the Santa Maria. But I will show it great respect!
  • Greek Warship
  • Roman Warship
  • Santa Maria
Looking forward to this..
