I asked AI what is wrong with this photo. Here is what it told me.
“Quite a few things are “off” if you look at it like a real age-of-sail ship instead of an AI-generated image.
Here are the biggest problems:
- The lifeboat rigging makes no mechanical sense
- The falls (ropes) are tangled and routed incorrectly.
- Several blocks appear to float or dead-end.
- The tackle geometry would not actually lift or lower the boat evenly.
- Some ropes appear to pass through other ropes or wood.
- The davits are inconsistent
- The support brackets and arms change shape from one station to the next.
- Some davits look too weak to support the boat load.
- The mounting hardware is not symmetrical or historically believable.
- Impossible rope behavior
- Rope thickness changes randomly.
- Certain lines bend unrealistically sharply.
- Some coils merge together organically like melted clay instead of laid rope.
- The blocks are malformed
- Several pulley blocks have impossible sheave arrangements.
- Some blocks appear fused into the rigging.
- A few don’t even have a believable rope path through them.
- Boat suspension is wrong
- The boat is hanging from too many conflicting attachment points.
- The load distribution would twist the boat badly in real life.
- Some lifting lines are attached at awkward or structurally weak places.
- Scale inconsistencies
- Some ropes are enormous compared to nearby fittings.
- Certain blocks are too large for the supposed boat size.
- The spacing between davits doesn’t match the boat’s balance points.
- Deck and hull details blur into each other
- AI smeared some plank seams and fittings.
- Metal brackets mutate into rope textures in spots.
- Several shadows/light directions are inconsistent.
- Historically questionable arrangement
- On many sailing ships, boats were either:
- stored amidships on skids/chocks, or
- suspended from more orderly davit systems.
- This arrangement looks like a hybrid fantasy setup.
This is actually a very typical AI image:
- excellent mood and texture,
- convincing at first glance,
- but mechanically impossible when inspected closely.
For model work, this is exactly why AI reference images are dangerous for rigging unless cross-checked against real ship plans or museum photos.
