HMS ENTERPRISE 1774 by RichardJJS 1:48 scale. New Kit from M.D
@richardjjs
Ok, lets see if I can make this make sense. :)
You said you have a3, 5 and 4. That means you are missing a1, 2 and 6.
Again, there are 2 of each.
I found a1 on L5 and H3.
I found a2 and a6 on L1 and H8.
You listed that you had all of the "b" parts.
You listed that you had all of the "c" parts except c3.
I found c3 on L2 and H9.
On the "d" parts you listed you had 1, 2, 3 and 5. However, there are only parts 1 through 4. So, your part listed of d5 must be something else.
Then you say you have parts 7.1 and 5.1. Those should be the pieces closest to the bow in the planking above the wales. If you have something installed there, and have these parts, you installed the incorrect part.
Next you commented in the parts you have removed that you have parts with "e" and "f". In my understanding of the construction guide, these go below the wales (plank rows "a" through "d") and appear to be single thickness.
You listed e2,3, 4 and 5. This tells me you are missing e1.
I found e1 on sheet H3.
In the "f" row planks, you listed you had f4 and f5, meaning you are missing f1, f2 and f3.
I found f1 and f3 on sheet H7 and I found f2 on sheet H4
I put some extra spaces in there to help break up what we were talking about.
I hope this helps you find the parts you are missing.
NOTE: You should use magnification to read the parts numbers. I had to and still almost mistook a "d" for an "a" . :D
Happy building !
Jeff
Problem is Ive removed some of then and marked them
I have 2 of a number of them
i think I had two of he same sheets
Will give you a bit mor info tomorrow
yes its tthe PDF file
I’d guess you have double numbers because they are for each side numbered the same as well as same numbers for each layer, different thickness.
Everything worked out OK, minor taper adjustments for the tapered planks below the wales.
Lots of dry fitting.
Tim
This might be helpful, since now I have removed model from jig for the last time, built a simple felt lined cradle.
Thick stuff barely visible but the wales stand proud.
Easier to see with a straight on shot.
Frames still need final sanding below planking,
Tim
your work is really great
Really think the design of this model is poor (Not INstructions)
The joggling of the planks is bad
Level 2 , 5 , then the next join should be 8 NOT 7
Nothing you can do about itt OR ME
hougt it was mebut i think i have a sheet of planks missing
Ive given up for now will come back Shortly
Ive Swapped my Porsche 997.2 foe a newer 981 Boxtser backward step but needed some money and having fun
I WILL BE BACK
@richardjjs
Happy building !
Jeff
THANKS
@richardjjs
Happy building !
Jeff
THANKS
