The Hayling Hoy, 1759 by AnobiumPunctatum - scale 1/36
Dear Christian
A very impressive start to a beautiful project!!!
I will continue to follow the project with great interest and curiosity.
I would be happy if you would elaborate on the way and methods of working with the cnc, so that we can learn from your most impressive abilities!
Dear Christian
Thank you very much. As I haven't planned to write a build in the beginning of the project. I have not much much fotos, to show the preparation of the different parts. Sorry, for a more detailed description you have to wait until I continue with the Fly.
In mid-February, I began building the parallel frames. As shown on the Disposition of Frames plan, the parallel frames consists of 21 double frames and one single frame (midship frame).
To compensate for any inaccuracies during assembly, I added 2/10 mm to the inner and outer sides for the frame thickness when preparing the individual parts for my CNC machine. Only time will tell whether this allowance is sufficient or if I will need to add another 1/ to 2/10 mm in the future for my next project.
Due to the tight tolerances, I milled a small jig for each double frame. This allows the components to be assembled very precisely and quickly.
Originally, I had planned to use a two-part template; however, this idea didn't work out as intended. So I decided right away not to use the upper part of the template after the second frame.
One half of the frames consists of floor timber (10'‘), second futtock (9’'), and toptimber (8'‘), while the other half consists of a crosschock (9.5’'), first futtock (9.5'‘), and second futtock (8.5’').
First, I assemble the half consisting of the first and second futtocks in the template.
Then I glue small spacers onto the second futtock to compensate for the 7/10mm offset. Now I flip the component over and place it back into the template. Now the other half is glued onto the first half. The small part shown in the photo with the individual frame members is very helpful for aligning the floor timbers.
I assembled the floor timbers for frames 10–12 from two separate pieces. This way, the grain of the wood aligns better with the direction of the frames. David Antscherl described this technique in his book "The Fully Framed Model", Volume I. You can’t see this on the finished model.
(The photo is from my Alert project)
That is looking very nice, Christian.
