Titebond Speed Set Wood Glue
Random topic, born from recent experience.
When ordering some more Titebond III recently, I added a bottle of Titebond Speed Set to my cart on a whim, figuring it will eventually come in handy. I finally used it a few days ago and was pretty impressed. They market it as "50% less clamp time" and I'd say that's spot on or even conservative. In my case, the piece was pretty thin and not under much tension but in a spot where clamps wouldn't work. I spot glued the piece and hand clamped it for maybe 15-20 seconds and it was already starting to take hold. In fact, once I realized it was setting so quickly, I had to pick up the pace a bit to make sure the rest of the piece was aligned before gluing the rest. Good stuff...does anyone else have experience?
For many years I was puzzled but was ashamed to ask. Why everybody on this forum uses Titebond glue for wood for their models? What is so special about it? The only wood glue Home Depot sells here in Toronto is this carpenters glue. I do not know where in Canada people get this Titebond glue and why. Why not to use just a simple PVA white glue they sell in Dollar stores?
I suppose there is an analysis of generic vs big brand glues somewhere out there, perhaps with little difference in performance, all else equal. Side note - I’ve always been curious about Lepage glue, which I see in building logs/videos. As for fast retention, I’d have to say most generic white/yellow wood glues are similar, meaning slower to cure under pressure. **I am not a scientist** ;)
Titebond Speed Set - I am not so worried about the set time with PVA. Is Speed Set so fast that keeping a strong thumb pressure the whole time is something you want to do?
For me, it is more a matter of getting a strong clamp on the joint. The closer are the two wood surfaces, the stronger is the bond. A dried pond of PVA is a flexible plastic. Before Babebot, I dipped a foam stick applicator into a pool of PVA on a piece of CutRight wax paper. For luck, I used the same wax paper square for a whole project. The mound of left over polymerized PVA could get thick. I could flex it. This tells me that it is better to keep the layer where PVA chains intertwine with other PVA chains as thin as possible.
The troublesome bond for a strong clamping is planking. Either to a frame or to a beam - for much of it a skyhook is needed. I used to use brass lil pins in a predrilled hole with a scrap wood square as a hitch chock for a clamp. If the pin is bonded, it is - nipping it off flush and file. If it comes out there is a hole left. A Bamboo dowel is used to fill it. This means that the hole must be in a specific location on a plank. Random dowels here and there is not good. It is necessary to do the whole fastener pattern. Bamboo end grain and brass - this is not something that would be visible on a ship seen at a distance.
If a zone on two meeting surfaces is PVA coated and allowed to polymerize - 24 hrs - and when the plank is to be fixed in position - the rest of the meeting surface has wet PVA, a not too hot iron will activate the dry PVA to grab its opposite and be an instant bond. This is a strong clamp while the wet PVA produces the strong bond.
This saves a year of drawing Bamboo dowels - drilling a near infinite number of holes - dipping a dowel in glue and inserting it - nipping a filing. In the end all this work produces a look that should not be there to begin with.
Lepage is a Canadian company. Franklin is in Columbus, OH. Makes sense that a Canadian retailer with a focus on low prices would source from a Canadian mfg.
White PVA dries transparent clear. Yellow PVA dries amber clear.
Titebond II is formulated to be water resistant. It does not survive immersion.
Except for perhaps really low cost generic versions, I doubt that the bond strength is all the different on a practical basis between brands or between white and amber. Yellow has a strong grip on the woodworker market. TV shows get paid for displaying brand names products. I figure that for many of the brand name versions - especially companies with a broad range of different types of glue -that it is more of a matter of labeling. One or two companies may actually synthesize the chemicals and beyond this it is
more of a matter of the label on the container at the end of the filling and labeling line. If two brand names have the same type container - I see that as a dead giveaway that they come from the same source.
As for Titebond II - for me - it is a comfortable and reliable tool that been staying with over a long time. Probably more of a neurotic comfort than anything else. It is not worth the risk to switch to white. Lineco pH neutral is white so if amber is a problem, it is good enough.
The original Lepage was fish glue. A protein glue in the same class as hide glue. Hot ethanol totally denatures protein glue. If the hot ethanol can penetrate a bond there is near instant release. The adhesive residue is curled up little balls easily removed by rubbing or scraping. As for hide glue - the premixed has urea added to keep it liquid - for maybe a year at RT. There is a high water fraction in premixed. Water does unpleasant things to a wood surface that is sanded and or scraped to a final finish.
The hot pot granules come as about five grades - the higher the number the stronger the bond - the shorter the working time. For the highest - if you blink it may be too late. There is a trick involved though. The stronger the bond - the more rigid is the glue. At the top end a sharp wack stands a good chance of shattering the dry glue.
I figured it out searching Google. Titebond II originates in US and was first single-component wood glue to pass the ANSI/HPVA Type II water-resistance test. Regular Canadian LePage woodglue is not as water resistant as Titebond II but PePage OUTDOOR is exact equivalent.
Any suggestions for what beats Titebond for waterproofness
The Higgins boats were plywood and resorcinol glue was the adhesive - two part - contains formaldehyde - will not work as an adhesive below 70 degrees F - is purple. DAP Weldwood Resorcinol glue is listed in older references. DAP seems to have discontinued it.
Two part marine epoxy seems to replaced it
Do a search for resorcinol glue for a history and - it seems - discourse on waterproof marine adhesives in general.
Epoxy comes in several flavors - the black stuff with metal powder that discolors everything it can to water clear. I would try the convenient to use type first - all of it is probably sufficient for a hull that does not live in salt water full time.
It seems that it pretty much the same as Elmer’s white glue.
I’ve used Elmer’s white glue for over 60 years building ship models. Never had a problem. Sets fairly fast.less than 20 minutes. Probably closer to 10 minutes.
And if you don’t think it doesn’t makes a strong bond, try separating two pieces of wood after the glue sets for 24 hours.
