Turning my attention to the bowsprit itself today..
First I figured out how to setup my Proxxon mill for the squaring off of the end of the bowsprit. I repurposed a previously used jig. I plan to secure the bowsprit in one of the long slots to square off the front end and to mill the tenon for the cap.
Square it up to the mill table
Demonstrating how I plan to keep the tenons oriented correctly..
This is how the setup looks at a glance.
However, I had to back track because I forgot that first I had to taper the forward end of the bowsprit. I needed the mill to get me close to a point where I could sand the taper round.
I used a compass to draw a 7 mm circle at the sprit's end. Following the Hunt practicum's directions, I made it larger than the 1/4" diameter that it will ultimately be squared off to. I wish I had checked first, but the math suggests there's not enough material left to get to perfectly square 1/4" ends. There will be some rounded edges. It may not be much of an issue, since the "bees" at the top will sit on a bevel anyway.
The wing attached to the inboard end of the bowsprit is an aid in aligning it for 90 degree rotations for milling.
Of course, I forgot to take pictures of the lobbing off of the excess wood on the three sides that needed reducing. You'll notice that the very end of the sprit is sitting on a ledge. The height of that ledge was chosen so that I had a straight cut with the mill from the beginning of the taper to the end of the bowsprit. That mark at the far end of the vice (sadly, barely visible) is where the taper begins. The circle at the end of the bowsprit is where the taper ends. After milling, I had three sides at 90 degrees to one another converging at the circle. Then I resorted to sandpaper to round off the edges.
The vertical lines on the plan look like they're inboard of the tip of the bowsprit. That's just an optical illusion.
