The green center section apears to be a housing for a swing up keel board to help with stablity in cross winds.Hi
This is my modified model for static display based on Arthur Ransoms boat which is housed in the Ruskin museum in Coniston. It’s not finished yet but not far off.
Good morning. So neat and tidy. Lovely stuff. Cheers GrantHi
They look great , will you put in reefing points
I’m going to cut a slot in the mast then insert an off cut of dowel to simulate a pulley
YesThey look great , will you put in reefing points
Hi, I used a standard plank benderReally useful and informative thread, thank you. Have just started my 1:6 scale clinker build and it will be my first plank on frame boat. Is there a link to the plank bending with SMD torch threat you mentioned? Have looked but can't find it and the plank bending is the part I have the most trepidation about.
The instructions tell you about the masts and there is a scale drawing on the back of the instructions that show the sail.Where did you get the plans for masts, yards and sail for the kit?
