USS Constitution - Model Shipways
Hey Chris.
Have you considered adding a "signature" to your user ID here? I've found it useful (especially for myself) to have the ability to go directly to my first and last posts from anywhere I see my icon. But it's also much easier to get to someone else's build from their signature. Most only have signatures linking to their finished projects. I like having the first and last posts linked for my (one and only, as well as) current project.
Cheers and Happy Father's Day
Peter
P.S.
Please refresh my memory on the mill you're using. I know it's neither Proxxon nor Sherline.
Thanks
Hi Peter,
I'll look into adding a signature - thanks for the tip. As far as Mills - I own a TAIG. Its substaintial and has a long x and y table. It also comes with the stepper motor to spin at 10000 rpm which we need to work with wood. You need to install that modification as an extra with the Sherline. Here's the site - I bought this model.
Its compatible with most Sherline accessories (I use their vise and many other accessories - thats the one of the areaa in my opinion they have over the TAIG mill) The Sherline also has a DRO option which could be nice to have.
Hope this helps !
Hi Peter, I called TAIG about a year ago and they did have one refurbished unit (the savings was nominal) - and then I needed to replace furnaces and you know how that would have impacted my hobby budget...
While finishing up the tenon, I turned my attention to the bowsprit cap and jib boom. The laser cut piece that Model Shipways furnished for the cap needed some tweaking to accommodate the tenon and the jib boom. I repurposed the failed jig from a few posts back to provide a properly angled clamping setup to mill the mortise for the tenon and the hole for the jib boom.
I started widening the slot in the cap while still on the milling machine. This got me close..
Fortunately, I had a 3/16" router bit - the same diameter as the jib boom. To use it, I had to switch to the drill press. (Now, if only I'd had that TAIG mill? :p. Yes, Chris and Paul, I will be getting one - sooner rather than later..)
Of course, I had to turn yet another spar. I haven't yet removed the bowsprit from my jig. I'll probably need to tweak that square inch or so at the cap end.
Going home for a "bees knees" before I start work on the bees.
Very good job Peter. Are you going to sand the top and bottom edges of the cap at the same angle?
What are the advantages of the TAIG mill compared to the MF70?
Mustafa, you picked a perfect time to ask that question. I still have the bowspruit mounted to my jig. All I need to do to Square Off the cap is to run it back through the mill. However, for what it's worth. Bob hunt did not do that. Well, at least not in chapter 1.3 entitled constructing the masts- the bowsprit. In his photo p1.3.1-5, the cap is not parallel to the jibboom.
Even later, in chapter 3.1 "the bowsprit", photo p3.1.1-1 shows the cap unaltered.
The MS plans do indicate that the top and bottom of the cap run parallel to the bowsprit and jibboom.
Excellent timing, excellent advice, thank you kind sir.
To answer your second question, I only took a quick glance at the taig Mill yesterday. If an option for a tilting head is not there, I'm going to have to look at Sherline instead. Somewhere, I've seen that that is one of their options.
If no one offers the option for a tilting head, I'll probably stand Pat. I've made myself a bigger table, so overcame that limitation of the Proxxon. I want a tilting head, and a rotating table/vice. I'll let you know if I find the perfect combination. If not, I'm sticking with the Proxxon.
Photos from the actual ship. It's clearly visible that the top and bottom edges of the cap are parallel to the bowsprit. You can easily achieve this by sanding if your circular sander's table angle is adjustable.
Hello gentlemen! After reading your recent discussion regarding the bowsprit and how the cap was cut on the actual ship, I said to myself "I wonder if any of the pics I took last September of the Constitution during my Boston visit would show any of those details?"
Here are a couple of pictures I found in my limited picture stash from that day. You will recall me saying it was cloudy and rainy that morning, so a lot of the spar deck details were covered, but... here a some of the bowsprit area that should be of help.
Looks like the top is rounded but parallel with the bowsprit mast. The bottom is flat but, again, also parallel with the rest of the bowsprit. FYI, the top of the port-a-potty is also rounded... ROTF
EDIT: Not sure if you can zoom in on that far shot to see the bottom. I'll try to do better!
IMG_8708.jpeg​
Is it under construction? Where are all the masts and rigging?
To anyone who has rigged the USS Constitution. I just took a look at the materials that came with the model shipways kit - specifically the 1mm (.040") and 1.5mm (.051") "jewelry nylon" rigging line. My first thought was to just buy from syren model ship company, but they're no longer making rope. That prompted me to look up ropes of scale. And the first question I had to ask myself was, do I want cotton or polyester. Then there’s this, what's the difference between plain rope and cable laid rope?
This is all prompted by Mustafa pointing out I needed to drill holes for the sheaves in the bees.
I believe everything I've bought from syren up until now has been synthetic. And I suppose I could just continue to do that. But seeing the option for cotton has me scratching my head.
No, I will not be making my own.
I'm open to thoughts and feedback on this subject.
