Imai/Aoshima 1/60th Junk build
Painted the sail battens a basecoat of Bamboo color, once dried I tested out the grimy effect on the painted sail battens, the grime also darkened the sail cloth to my liking. I'm going to try to dry brush a spot of sand to see if I get a more bleached effect. Depending on how the light hits the sail, in some pics it looks darker and some lighter. I lIke it.
Back from the Cruise and working on another 'cruise ship' ;) A cruise up the Yangzi River. Back on the Junk....rigged the boat winches, the anchors and started painting the bamboo sail reeds, looks a bit sloppy, but will be trimmed in with boxcar red and a wash. Because I'm not using the drop-down rear hatch, I decided to use the deck winches as the lifting winches for the lifeboat. The instructions do not even mention as to how they would have lifted it or even properly rigg it. I added 2 eyebolts to the boat to be used as the tackle points, but I may just use small hook to secure.
It was too hot to work long in the shop yesterday, but I was able to get the Foresail trimmed and touched up from the over paint. hopefully, I'll finished the main sail this evening and them be able to wash it and start the main rigging.
All toll, about 10 hours on the 3 sails from the base coat of boxcar red, the bamboo trimming, cleanup, touch-up, and weathering (not counting drying times). I stepped the masts and have the backstays ready. I'll hit the sails with a final coat of flatting agent before mounting.
The paint job is very convincing! But the planking on the sides of the ship hold perplex me a bit. Are they meant to represent thicker timbers?
Thanks, your guess is as good as mine on the weird planking on the sides, I've tried to find better photos on the net to see, in researching, I found there is just not a whole lot written on the building and workup of these type boats. The crazy part is they were sailing generally before most of Europe. I think there is only one or 2 books on the subject, but they really don't focus on the vessels, just trades.
There's more documents on them in Chinese (so not very helpful if you don't read it), but the vessels of of ancient Asia is a subject woefully neglected in Western academia. The irony is that you are correct; they were sailing earlier in the west, coming up with innovations like watertigher bulkheads, sternpost rudders and the compass centuries before them, yet they are less romanticized.
Anyway, looking good!
All mast are set with backstays in place. The mizzen sail is rigged in place with blocks, waiting for glue to dry before setting the reef points. I have to use 4.0mm blocks as the holes were too small to get the rigging through the 3.5 mm size. I could not step down the lines size as it would be way too small. The hard part will be to figure out to terminate the ends of the lines as the Chinese never has belaying pins. So each line will be tied to some point on the deck, this is making me crazy
Looking great!
Thanks John, rigging this is going to be a bit sloppy, just tying the end of the lines down to a bunch of various points. crazy. I had to use my smallest reamer to enlarge the hole for the blocks. I would have drilled but figures I would break a few bits, the reamers are made of hardened steel.
I ordered all the blocks I think I need (for my planned version of the rigging) from Syren and they arrived today. Nice looking blocks :-) Postage to Australia is crazy...I mean, its a normal envelope and it was $25US ($37 Australian!)
Anyway. It's only money. They are very nice blocks.
I have spent two weeks re-organising my hobby room to house all the stuff I accumulated over the years, plus the extra stuff I need for ships! I had run out of space.
So - little progress on my Golden Hind and I still have not started the junk!
The old saying "You can't make a silk purse out of a sow's ear" is true, BUT you can try to make a fake one. The models rigging instructions are WOEFULLY lacking (non-existent). Between studying drawings found on the net and fellow modelers help, I've been able to figure out what is 'missing'. In studying pictures of real sail on junks and similar ships, I've been able to cobble together about 80-90% of the rig. The really hard part is realizing that the Chinese NEVER used any form of belaying pins, they seem to just tie the ropes to about anything. Each of the lines you see ties to rail will have a coil of rope added later. At the base of the mast, I've drilled a hold for a brass rod to serve as the anchor point for the main lift. The instruction just say tie to the bottom - no way that will work. The brass will get darkened later. At this rate it going to take another 2 weeks rigging on the Mainsail and Foresail. The lifeboat is just supposed to tied/hang from the aft rail which is just goofy) I used the 2-rear beams that was supposed to be used to work the aft bulkhead drop door (better than nothing).
I'll be facing that same problem soon enough. Almost no information on the rigging of my own ship type, and no specific securing points for its lines.
I think I can see the end of the road. Finished rigging the mainsail and added the needed lines to the foresail and have it set it in place drying before adding the last of the blocks. I had to add some additional weight to the midship canopy to get it to setup while the glue dries. The bottle of Floquil paint is over 30 years old.
