The Ocean going rescue tug, HMT Rollcall W81 1920, Built using Caldercraft's Resolve grp hull and plans (much modified).
There is nothing like a bit of retail therapy to cheer you up. So I splashed out on a new milling machine from Proxxon, more a combination of bits that go together to make a more substantial unit than my MF70. The MF70 is quite good but limited by size. The major components of the new setup are a BFB 2000 drill stand, a KT150 compound table , and a bfw 40/E mill/drill head. Too early to say how good it will turn out but very promising so far.
Back to Rollcall and a good bit of progress. The lifeboats and davits are all rigged and the flying bridge attached and the supports added, yet to be painted. Next up is to rig the fore mast.
A very nice Proxxon buy: I have the same set-up.:) And again a nice detailing paint-job, Jack.
Hi Peter, very pleased with the Proxxon, particularly like the motor, feels powerful and under stressed, would have liked a 6.4 mm collet rather than the max. 6.0 mm, as I have a lot of 1/4 inch bits. But that will be easy fixed. The motor is quieter than a Carmelite nun at breakfast.
Cheers JJ..
A bit of a milestone I have finished and added the fore mast along with a start on the rigging,this no doubt will be great fun. I don't know much yet about tug signal lamps but this girl has more lights than my Christmas tree. The lamps are two piece white metal and I struggled to know what colour to paint them. In the end I whent for black with a whitish gloss wash to try and imitate glass. Just about OK.
As can be seen I have started the ratlines, in the background of some of the pics. is my build of Vangard Models HMS Alert, from some years ago, that is up to be cleaned. I look at her and wonder how I ever managed to do the rigging, now impossible with only one fully functioning arm. This wee bit on Rollcall has totally debunked the idea of one last fully rigged ship, pity.
Some pics.
PXL_20260609_175944541.jpgPXL_20260609_175956673.jpgPXL_20260609_180011043.jpgPXL_20260609_180022373.jpgPXL_20260609_180040700.jpgPXL_20260609_180113735.jpgPXL_20260609_180143162.jpgPXL_20260609_180219697.jpgPXL_20260609_180235438.jpgPXL_20260609_180742888.jpgPXL_20260609_181229635.jpg
Cheers JJ..​
A bit more completed. Now the front one third is all but finished. I made a balls of the ratlines, so the shrouds where cut off and replaced with finer ones, the same for the ratlines. The steam winch looks quite nice and not much changed from the kit. To finish the mid section I needed to add the two compionways up to the flying bridge. A second faux pas; I should have drilled holes for the top rail, so know I cannot use the kit white metal parts,(which where not too bad), so I have started making a pair from sstyrene and brass for the rails.
Some pics. in particulary the wrong order,(football is on soon).
PXL_20260616_165134197.jpgPXL_20260616_170122560.MP.jpgPXL_20260616_170139433.jpgPXL_20260616_170150197.jpgPXL_20260616_170216979.jpgPXL_20260616_170228168.jpgPXL_20260616_170305083.jpgPXL_20260616_170352675.jpgPXL_20260616_170443043.jpgPXL_20260616_170456350.jpgPXL_20260616_170504267.jpgPXL_20260616_170555572.jpgPXL_20260616_170615562.jpgPXL_20260616_170618556.jpgPXL_20260616_170655877.jpgPXL_20260616_170715245.jpgPXL_20260616_170839857.jpgPXL_20260616_170914327.jpg
Cheers JJ. Vive la france.​
So much to see with so many details…. Once again, nice additions, Jack.
Good afternoon.
Things have been going along steady with no real problems, although I should have fitted the companion ladders up to the flying bridge sooner as the where a bit of a squeeze but went in ok in the end. The main mast supports a substansual derrick with the boom streatching well down over the engin room. It sports a large travelling block and hook. There was quite a lot of rigging to be done and the ratlines are a real trial for me now but again they look alright. After seeing the cost I thought I would have a go at making a bow fender. The one in the pic. won't make the cut but it shows promise.
Next up will be the towing rails and I will have a think about how to make them. I have experimented with some 3.5mm styrene 'T' section but it is hard to shape without twisting, so I am thinking about some sort of jig.
Talking of experiments I roughed out a 12 inch gun barrel in 1/96 scale with a thought of turning four of them for my next project. But it looks a non-runner as they are too long and thin for my lathe. A support might help but the long taper is near 100mm and has to be cut in three sections, repetition would be dificult.
Some pics.
PXL_20260630_082230222.MP.jpgPXL_20260630_082322178.MP.jpgPXL_20260630_082357840.MP.jpgPXL_20260630_083909749.MP.jpgPXL_20260630_084002520.MP.jpgPXL_20260630_092341936.MP.jpgPXL_20260630_130212262.MP.jpgPXL_20260630_130238502.jpgPXL_20260630_130258480.MP.jpgPXL_20260630_130312273.MP.jpgPXL_20260630_130335000.MP.jpgPXL_20260630_130340412.MP.jpgPXL_20260630_130544534.MP.jpgPXL_20260630_130557443.MP.jpgPXL_20260630_130805576.PORTRAIT.jpgPXL_20260630_163258007.MP.jpgPXL_20260630_192450950.MP.jpgPXL_20260701_095434211.MP.jpgPXL_20260701_123357521.MP.jpgPXL_20260701_123655949.MP.jpg
Cheers JJ.
Come on England!!
honest.
Good afternoon.
Classic Jack work- brilliant. Yep England stuttered to a Victory…..we will take it. Now SA is predictably out my second citizenship kicks in ROTF . Cheers Grant
Half time in the Argentina match so just time to show some pics. of my progress. Mostly centered around the main mast and derrick. I have also started to add some detail to the wash deck, including two small davit supports beside the first towing bow. These are not shown on the CC plans but are shown in plan in the British Steam Tugs book. I have made another fender for around the bows but still not right. Will try again.
The Pics.
PXL_20260707_125928763.MP.jpgPXL_20260707_125937051.MP.jpgPXL_20260707_125943881.MP.jpgPXL_20260707_130433209.MP.jpgPXL_20260707_130443297.MP.jpgPXL_20260707_130452744.MP.jpgPXL_20260707_130514838.MP.jpgPXL_20260707_135118216.MP.jpgPXL_20260707_135241150.MP.jpgPXL_20260707_135854391.MP.jpgPXL_20260707_135955701.MP.jpgPXL_20260707_140224558.MP.jpgPXL_20260707_140242835.MP.jpgPXL_20260707_140308167.MP.jpgPXL_20260707_140324805.MP.jpg
Egypt are 1- 0 lets hope they can keep it up.
Cheers JJ..​
What I also read somewhere else is right here:
Any one who wants to improve their model making only has to look at your builds, Jack
Truly magnificent!
….ahhh….sadly not. Great come back by Argentina tho. Cheers Grant
As a liverpool supporter I am a great admirer of Mo Salah, but he has looked a bit on the decline this last year or so. And sadly it was his lazey attempt to buy a penalty that led to the third goal. Pity. Still Torstein Traeen leads the Tour, Victor Hovland just won on the PGA, so England better look out for Norway!
Seems like yesterday was mine for getting things wrong, including Rollcall.
See next post JJ..
