I just sent him a bunch.I'm sure Jon will chime in with the appropriate photos
Hmmm, heating them will probably ruin the brass finish. As you may recall, I am not doing Connie in the black and white scheme most others are. and I'm trying for shiny brass wherever metal is deployed in the kit. So, heating is not presently in the cards. ...Though I am experimenting with soldering the irons for the jibboom stays.hooks are made of hardened steel so they will snap if you try to bend them. If you are going to bend them, like making hooks, you need to soften the metal, which is easy to do. Just heat them up with a torch and let them cool down slowly. Hope that helps. Let me know if you have any other questions.
Just catching up with about a week's worth of Frank's build log here. FWIW, I also have Olaf Eriksen's book. A very interesting read... and the diagrams themselves will be really helpful in rigging.I originally found the 1812 Isaac Hull Model at the Peabody Essex Museum on the Fine Scale Modeler site. Then I supplemented the collection as I found various images on other sites. (I have a total of 75 images) When I checked the original link to Fine Scale Modeler, all the text was there but the images were not, just placeholders. The text does have a link to an excerpt from Constitution All Sails Up and Flying by Olof A. Eriksen which gives a history of the model. If you have a copy of that book, the text begins on page xxii.
Jon
With all the pin rails finished and in place I was ready to move on to the other bulwark details starting with the cleats. The kit supplies 8 large (5/16") cleats made from Brittania metal. I decided to make these out of wood for a much better look. The Navy plans for these cleats (Plan #28433) gives al the dimensions. They are essentially 8.5" square and 47.5" long and shaped accordingly. I saw three ways of shaping these. First was to use square stock, cut to length and file/sand away the bottom half on each end to make the cleat. I didn't like this as I saw it being difficult to reproduce exactly several times. The next would be to sandwich two thinner pieces of different lengths to make the shape of the cleat. Although this seemed to be a bit more reproduceable, it also seemed like a lot of fiddy work. I finally decided the best approach would be to use a piece of flat stock that was 0.5"x.090" and run it edgewise through the Byrnes saw with the depth set appropriately to trim off the bottom half on either side. This gave me the shape of the cleat which I could then slice off like bread using the chop saw
View attachment 617284 View attachment 617283
Once cut, I drilled a hole in the center for a pin. A little stain and some black dots for the other "bolts" and they were done
Great job gives me ideas when I start my wood kit
Here's where i ran into some trouble. The BJ instructions once again proved to be a source of frustration. The actual instructions for the spar deck construction make no mention of any cleats. The belaying plan in the back of the book do mention cleats, but with little detail and I believe some missing information. here is the plan
The first thing to mention is the note in the far right corner. It states that numbers = belaying pins or cleats. As far as I can see all the numbers on this diagram point to pin rails. No cleats. Next, if we look closer at the bow, it does mention cleats, but provides no details
Although it clearly shows some different sized cleats, the larger of course being the large wooden cleat. It only shows four small cleats, whereas there are 5 0n the actual ship. Three wooden ones that appear to be slightly larger than the two iron ones close to the cathead. The kit provides two sizes of small photo etched brass cleats. For now, I am going to assume that the one directly above the cathead was simply omitted in the drawing and that there are five smaller cleats here. As we move aft, you can see that there is no mention of the large wooden cleat that is currently just forward of the waist. Again, I am going to presume that this large cleat should be here.
Looking at the aft end of the plan, there are more missing details
You can see that there is no mention of the large wooden cleats currently just aft of the waist and just in front of the davit just forward of the mizzen channel. As we get to the transom, there is again mention of some cleats. The apparent size of the cleats is similar to the large cleats on the bow, however, the ones currently on the ship are the smaller wooden ones. I guess I will assume that the ones drawn here simply aren't meant to be to scale. In addition to that, the diagram indicates an eyebolt in the deck for the gaff vangs (denoted "B" inside the red circle). The ship currently has cleats in the corner of the transom, and interestingly, the Revell model shows those cleats present and intended for the gaff vangs. Seems to me that a cleat would be more appropriate for this tie off?
Lastly, there is the cleat indicated in the center of the transom, aft of the boom traveler. Currently, this cleat appears to be in the deck forward of the traveler, perhaps because of the gunport there now. Regardless, there once again is no indication of the size of this cleat, although looking at the real ship, it appears to be one of the smaller iron ones.
I guess at this point, I am going to use the current ship for guidance and position the cleats as they are on the ship now, although I would welcome any comments from those of you who might know better. One last detail, there are 8 of the large cleats provided in the kit. If we take into account the ones missing in the diagram above, there would be 8 needed.
