My 1/72 scale aircraft
De Havilland Mosquito is finished!
I was a little apprehensive when I started it, but Tamiya did a great job with this kit. Everything went together well. The canopy frame was fun, I had to put the camouflage pattern on it. ;)
View attachment 617417View attachment 617418View attachment 617419View attachment 617420View attachment 617421View attachment 617422View attachment 617423View attachment 617424View attachment 617425View attachment 617426
On the shelf with the RAF aircraft of WW2…
Considering my next build. Jet or WW1…
See ya next time…
it's soo beautiful
Next up…
I need to add to my WW1 category, so this one has been on my short list.
The exhaust usually needs to be modified on the end…
And then there was excessive flash on some pieces…sigh!
After cockpit assembly and joining the fuselage, I sanded and added putty in the required areas and then built the empannage…
Then it was time to start the painting…
This is a darker wood tone than some I have seen, but I think it gives it more of an aged look. Plus once the colors go on the wings, it will look brighter. ;)
See ya next time…
Hi Dean,
I can see this is going to be a great build already. Your wood grain looks great. I wouldn't worry about the wood color. The Alabtros was made in three different factories, the Berlin factory, OAW and LVG factories. Because of the differences in the manufacturing process between factories, it was common to have slight variations in colors.
Bill
Hi Dean,
Bill
Thanks Bill! Good to know my wood tone is feasible.
Hi Dean, just dropped in to see your latest and I have to agree with everyone else, the wood effect looks great. How did you achieve that?
Typically on struts or landing gear I use a two step process…
I paint the base color a dark brown (olive drab) and then I dry brush the gilded oak on that. Then just a matte clear coat.
On this fuselage, I decided to get more variation in color, and to have a lighter overall look…
For this is painted a base color of middle stone, then I dry brushed highlights with the french vanilla, and dry brushed highlights with the gilded oak. Then I did a wash with the mahogany. Then I averaged all that by dry brushing a little light brown. Then I did a final wash with mahogany very thinned out. And finally a matte clear coat to seal it.
The idea is to let the thinned out mahogany settle in between the dry brushed highlights giving that dark grain look. And then averaging that with the lighter brown so there isn’t too much contrast. And the multiple colors gives the realism.
Hope that helps.
Albatros D.II update…
The upper wing was three pieces…
I did not care for this at all…sigh!
Then I painted the lower wings, upper wing, the landing struts and wheels, and the propeller assembly.
Next will be drilling holes for the rigging cables and attaching the upper wing, which will be a delicate process! The struts are tiny and have very little surface area for the glue to bond to. Basically pins on the ends.
See ya next time…
