Good morning Paul. My struggle part. I use a flat No.17 chisel blade. I also use a No. 11 pointed blade to pry the little block of wood out of the chisel cuts. I clean up by gentle scraping vs sanding. Sanding changes the shape of the corners in the notches. Cheers GrantGrant, what do you use to cut your notches in the beams? Thanks, Paul
