Hi Peter, I just love how all the different parts of the Balder in your photos have that brand new pristine look about them. I also spotted that cursed twist in the 4-part main sheet. I used to see that same thing in our company cranes when we would make a heavy pick of bridge beams and about halfway through the setting process the darn things would suddenly twist up causing a serious potential line cutting mishap while under the heavy loads.
Hi Daniel. You are right about the twist. The lower block has a axel but has to much friction:
That's a splendid looking trip! I hope you will be able to have some pictures of the Balder at sea under full sail in the future, that would be really something.
Dom
Thanks, Dom. We all here aboard have great respect for the fisherman who sailed this for weeks on open see.
Here we entered yesterday the harbor of Scheveningen with only the mizzen sail.
The picture is from a photographer from Vlaardingen who went to Scheveningen to see us there.
A moment ago passing Maassluis. Some friends have there a apartment on the 13th stock:
Unfortunate very less wind today.
Due to all the activities on the 1:1, I haven't been able to spend much time on the 1:50. I also laid a second box of bricks in stages:
In my stock, I found a few thicker planks that I used to break up the large area of brick a bit. The combination of stone and wood makes it look a bit livelier.
The hull will be supported in this way:
Around this floor, I am thinking of making a kind of a low quay wall. That way, the whole thing will sit slightly recessed.
But then I still need to be able to remove both parts to display the model in sections.
I still need to think all of this over carefully to make a final plan.
