Right there with you brother!!!One more time, THIS IS MAKING ME CRAZY!!!
I'll tell you. I am starting to get annoyed with my Constitution. The fittings are to scale, I know, but they are too small to effectively handle. Take the eyebolts, for instance. They are a nightmare to use. So I had to make my own. Not to scale but functional which is what I need for the rigging steps. I can't be spending 20 minutes trying to thread an eyebolt that is too small. Are you getting the same issue with the blocks? I was looking quickly at the inventory of blocks that I got and some of them are tiny. I may have to resort to putting something bigger.I went to the USS Constitution Museum website and searched simply for "blocks". This was all I could find using that search word. For those of you going for the original layout, these are supposed to be the specs for the 1797 original.
Note: Main jeer blocks are 26" long., which would argue for 6mm blocks for the jeers.
Evidently, you need to choose your A/I assistant carefully. My first pass using one agent stated that there was no 1929 block list. Checking with Grok, I found this:
"The 1929 Block List (Plan #30359) is a U.S. Navy engineering drawing from the 1927–1931 restoration of USS Constitution (“Old Ironsides”), made available by the USS Constitution Museum as a resource for ship modelers and researchers. It appears in the museum’s “Modeler Resources” collection under the Masts, Yards, & Sails section, alongside related 1920s–1930s plans for spars, masts, sails, and fittings. These plans were primarily prepared by naval architects at the Charlestown Navy Yard under Lieutenant John A. Lord (Superintendent of Restoration, 1927–1931). The bulk of the drawings from this period document the extensive work in which roughly 85% of the ship was renewed/replaced; the full set of plans redrew the vessel accordingly."
I tried to copy the link but failed. Here are screen shots for the main mast and yard. Note: the largest blocks on the list are the "jeer falls" at 16" length. Suggesting that 5mm is a better fit than 6mm. No?
The specs for the foremast tell the same story.
But at least, I feel vindicated in my choice of block size...
Taking a break is the best course of action. She's kicking my butt. I am strongly considering using my 3d printer. not sure yet. I would have to paint all the blocks black, I think. But the downside is that I like wood and I don't know if I would like the plastic parts even though they are painted black.Am I ever! The reason I haven't posted in a while, is that I've been struggling with the rigging of the jeer and quarter blocks. Because I opted for the Syren replacement blocks, I'm dealing with nice scale, but difficult rigging conditions. I have more difficulty doing the seizing of the slings than threading the blocks, but then again, I haven't had to rig two blocks together since I finished the spar deck carronades. Those were fairly easy in that I did the rigging off deck and only hook the tackle to the eyebolts. I'm not looking forward to the jeer trusses. But, in for a penny, in for a pound. Since I already went to the Syren scale on the spar deck, I'm committed to it going forward.
One trick I learned on the carronade tackle was to use a pin vise to drill through the holes in the blocks, to make sure there wasn't any obstruction for the line to get hung up on. Also, putting a dab of C/A glue on the tip of the line and letting it harden (after tapering by hand to form a pointy end) made threading the blocks a LOT easier. Good lighting, magnifiers (Mr MaGoo glasses), and fine pointy tweezers are essentials for success too.
If you're getting frustrated, take a break. Don't take it out on Conny! Come back to her with a cool head and steady hands.![]()
Honestly, that's exactly what I have been doing with my Constitution. Taking a break! Not to muddle up your build log, Peter, with my issues, but I've gotten frustrated with some of the (what should be) basic upper hull planking not coming out right, so I've set it aside and I've been working on some "prep work" on my next build, which will be Ernest Hemingway's Pilar fishing boat. Anyways, my point is, breaks are not a bad thing. We know going into a build like the Constitution that it's going to be a long process. It's not a race. As long as you guys will still hang with me long after your own builds are done, I'm ok with these occasional intermissions.If you're getting frustrated, take a break. Don't take it out on Conny! Come back to her with a cool head and steady hands.![]()
AgreeHonestly, that's exactly what I have been doing with my Constitution. Taking a break! Not to muddle up your build log, Peter, with my issues, but I've gotten frustrated with some of the (what should be) basic upper hull planking not coming out right, so I've set it aside and I've been working on some "prep work" on my next build, which will be Ernest Hemingway's Pilar fishing boat. Anyways, my point is, breaks are not a bad thing. We know going into a build like the Constitution that it's going to be a long process. It's not a race. As long as you guys will still hang with me long after your own builds are done, I'm ok with these occasional intermissions.
just to clarify. The tiny eyebolts that I am referring to are the ones that go on the fighting tops. even Hunt seemed to use bigger eyebolts based on the photosAm I ever! The reason I haven't posted in a while, is that I've been struggling with the rigging of the jeer and quarter blocks. Because I opted for the Syren replacement blocks, I'm dealing with nice scale, but difficult rigging conditions. I have more difficulty doing the seizing of the slings than threading the blocks, but then again, I haven't had to rig two blocks together since I finished the spar deck carronades. Those were fairly easy in that I did the rigging off deck and only hook the tackle to the eyebolts. I'm not looking forward to the jeer trusses. But, in for a penny, in for a pound. Since I already went to the Syren scale on the spar deck, I'm committed to it going forward.
If you're making your own eyebolts, I'd have a hard time believing that the eyes would be too small to get rigging through. I just checked my fighting tops, and, while there's no mention of where the eyebolts came from in my build log, they appear to have been hand made - given slight inconsistencies in sizes. If you used a needle nose pliers to make yours, you will surely be able to get rigging through them.just to clarify. The tiny eyebolts that I am referring to are the ones that go on the fighting tops. even Hunt seemed to use bigger eyebolts based on the photos
good point. cheers!If you're making your own eyebolts, I'd have a hard time believing that the eyes would be too small to get rigging through. I just checked my fighting tops, and, while there's no mention of where the eyebolts came from in my build log, they appear to have been hand made - given slight inconsistencies in sizes. If you used a needle nose pliers to make yours, you will surely be able to get rigging through them.
No one will be examining your model that closely when you're done. If someone does show up with a vernier caliper and a binder full of plans, send them packing! Size them to suit yourself.
