Looks like a windlass to me. Used to haul anchors and tighten lines.I've seen photos of models with this in them, and drawings as well (near both the fore and aft ends of ship's boats), but don't know what they are.
Google AI says it's used for towing (with a couple possible titles), but I fail to understand how. Any info and/or references would be appreciated.
Does your document describe what that fixure is for?![]()
Temps de débarquement et d'embarquement d'une chaloupe. - Page 3
Il manque les caliornes suspendues aux vergues sur votre schéma. Ce sont elles qui soulèvent la chaloupe en premier lieu.5500.forumactif.org
Yes, there is one of these constructs at each end. AI seems to indicate they were used for pulling ropes and such, but I would think that would require a lead or some such (similar to a hawsehole, but could be open-topped). Without that, ropes at an angle would wear against the wale, and move around.Hmm. Doesn't look like it would be used for handling anchor rodes or such because there are no fairleads or chocks in the area. It could be used for hauling the boat since it's near the bow and has a rounded center section which would serve to keep the line centered. However, that would lead you to expect something similar at the stern. Is there anything similar at the stern? Fair winds!
Thank you for that. A very interesting conversation at that thread.![]()
This document runs to several pages, it suggests that a secondary side line was also used to protect boat.Thank you for that. A very interesting conversation at that thread.
However, if you/they are indicating that during transfer of the boat from the deck to the water, the lifts are connected to the central round portion of this structure, that doesn't make sense to me. A simple hook or loop attached to the top of the keel structure seems better. The structure we're talking about here is intentionally mounted low, and that would/could make the boat tilt to the side, and the design of the structure, allowing it to slide, would make it worse. It seems it's designed for a lot more than just lifting the boat, and designed poorly for the simple task of lifting.
Typically, any windlass could serve as a capstan or be used for towing, hauling sails, or handling the anchor.Does your document describe what that fixure is for?
My guess woud be a fair lead of some sort. It shows no mechanism to serve as a windless.
I have not seen that on English long boats, in drawings, plans or models.
A windlass would tend to be mounted more mid-ship.
Cap'n Signet:However, if you/they are indicating that during transfer of the boat from the deck to the water, the lifts are connected to the central round portion of this structure, that doesn't make sense to me. A simple hook or loop attached to the top of the keel structure seems better. The structure we're talking about here is intentionally mounted low, and that would/could make the boat tilt to the side, and the design of the structure, allowing it to slide, would make it worse. It seems it's designed for a lot more than just lifting the boat, and designed poorly for the simple task of lifting.
I meant at the top of the bow, which the keel extends into. Sorry, I don't know the terminology, especially since this is a small boat, not a ship. On the model I'm making, I simply drilled a hole at the top of this area, above the rail. I don't see a similar location to use at the stern, though.Cap'n Signet:
Your reasoning is sound but a hook or loop on the keel would be even lower and increase the risk of the boat heeling in the lifts.
I agree, no. 6 would work great. Possibly for rigging too.What would make sense is a "toggle or iron strap" as shown as item no. 6 in the drawing below, This is a drawing of a 19th century American whaleboat from The Whaleboat by Willits Ansel. However, there is no such hardware shown in either the photo in post #1 or the drawing in post #3.
While I've seen these "spool things" on 30'+ boats, mine is only 14-15' and Boudroit still shows them.I admit that a whaleboat would likely have been lighter than the ship's boat under discussion.
Google AI calls them fairlead rollers or bollards, but when I search for those items, I don't find anything that looks like this, or seems to serve the same function.This remains a bit of a head-scratcher.
This is not related to the sail rigging. This fitting is also found on heavy longboats. Bear in mind that it is a French boat—technically much more complex.Cap'n Signet:
Your reasoning is sound but a hook or loop on the keel would be even lower and increase the risk of the boat heeling in the lifts. What would make sense is a "toggle or iron strap" as shown as item no. 6 in the drawing below, This is a drawing of a 19th century American whaleboat from The Whaleboat by Willits Ansel. However, there is no such hardware shown in either the photo in post #1 or the drawing in post #3. I admit that a whaleboat would likely have been lighter than the ship's boat under discussion. This remains a bit of a head-scratcher.
Fair winds!
French boats were stacked on top of each other. Look at this Roger. Idk.Longboats and later, Launches were fitted with rollers at bow, stern, and sometimes both. The location depended on how the anchor was handled. Brudroit (sp?) writes that location of these rollers depended on how the anchor was handled. British longboats hauled from the bow, French longboats over the Stern, and when the British adopted the launch they hauled over the stern too. I don’t believe though that this is one of these rollers as they were much smaller, at the level of the gunwale, and handled a much smaller messenger line not the cable itself. It might be somehow be involved with handling the much larger anchor cable as it came aboard.
Likewise, I don’t believe that it was used to hoist the boat in and out of the water. Hooks and ringbolts were used for this. Launching a small boat from a large vessel could be a hazardous undertaking. It required detaching the boat from the falls as soon as soon as
it became buoyant. The difficulty of doing this with both ship and boat rolling and plunging in a seaway is evident from the many patented devices for disconnecting boat falls developed in the late 1800’s. Anyone who has tried to untie a knot in a wet line under tension will understand this.
Roger
It's called the stemhead. A hole there is pretty common on small boats. One is shown in the photo. In the interest of full disclosure, the hole you can see is in the stern post since this is a double-ender. Fair winds!I meant at the top of the bow, which the keel extends into. Sorry, I don't know the terminology, especially since this is a small boat, not a ship. On the model I'm making, I simply drilled a hole at the top of this area, above the rail.
I've used Google translate on the entire thread referenced above. It is all about the rigging from the masts and spars used to lift the boat, not the connections at the boat, despite the diagram above.All very interesting, and seemingly documented if only I could interpret the French, and the Accumulated Idiocy could manage translation of specialised jargon.
Plus I can't see how a cable, say for an anchor, around the item in question could be lead over the rail and into the water without causing damage to the rail and/or cable. Some larger boats I've seen have a roller at the stem for this, so for it, it would mamThe drawings I have seen show a very sturdy fitting built in to the hull, apparently to allow considerable force or weight to be transmitted. Hence the suggestions about anchors. My first thought was that it would be related to towing, built to take sudden shock forces and dissipate them into the major hull structure of the keel without damage. The photo of a bored stemhead does not do this job - though for the weight of the boat shown, it is adequate, for a loaded ships boat the stem would disintegrate when a couple of tons is applied to a rope, or a metal hook in that configuration.
My thoughts exactly. Plus a loop around the round portion would slide back and forth, adding to that instability.The diagrams of how the boat is rigged for launching over the side seems to be likely. The weight of the boat is handled, and as someone mentioned, a quick release loop would do the job of launch / retrieval. The main problem being that the attachment is so low that there could be a risk of instability which would have to be mitigated by additional lines.
