I bought a set of molding bladesContinuing on with making and installing the frames, there's something you need to watch out for, if you're using the pearwood 3-piece frames. The method I used to assemble the frames, as shown above, was to place the upper side portions of the frames in place, then add the bottom portion on top and aligned with these. I've been placing the "top" of all frame sheet pieces up, so that the bottom portion, which has a vertical centerline in it, can be used to center the frame in the jig, as shown below:
You will notice above that the pieces also have the lines used to bevel the edges to conform to the hull shape. The problem is, if you place the sides into the opening, then add the center/bottom piece, and glue up the assembly, when placed into the jig, the bevels will be on the wrong side (in this case, the back side), when they must be beveled on the fore side. The solution (or at least one of them) is to place the side pieces back-side-up, then the bottom atop them. Then, when placed properly into the jig (frames 1-6 have the outer side parts facing forwards, 7-15 aft:
I chose to keep the center piece facing upwards because I used the centerline to help center the frame. It won't really be visible, and the bevel lines on the center frame don't really apply, because that portion is no longer at the frame location.
This is where I am so far. Only 1 frame broken so far (#1), and that's because it stuck in the template sheet, and I was too anxious to properly un-stick it.
The last ribs go in place:
And, without the jig we have:
Now I have to making the surrounding 1.5 x 2.5mm strip into a moulding, using one of those razor-blade-type thingies I have left over from another build. One is not supplied with this kit; I guess they figure you'll use the one for the main boat. I haven't had much luck making these, in fact I've never been able to make one acceptable enough to use on a kit. Here's hoping for a first time.
Molding blades? To create moldings? Can you post what you got, because the ones included with models seem almost worthless.I bought a set of molding blades
Thanks. Have you tried them out yet? I received ones with 3 different kits, 1 from Croatia, 2 from China, and they all looked nice, being photo-etched stainless, but they weren't hard, deformed easily and didn't cut well. Mine made from a thick razor blade cut really well. The AL ones look great, lots of neat profiles, but will they cut?ArtesIana Latina Micro Moulding Blades
About $13.00
The ones I received from Artesiana Latina worked great and did not dull using Lime and Bass woods. I didnt.try them on any hardwoods yet but intend to use them on Pear on my next model.Thanks. Have you tried them out yet? I received ones with 3 different kits, 1 from Croatia, 2 from China, and they all looked nice, being photo-etched stainless, but they weren't hard, deformed easily and didn't cut well. Mine made from a thick razor blade cut really well. The AL ones look great, lots of neat profiles, but will they cut?
Your log inspired me to take a look at the CAF catalog.Molding blades? To create moldings? Can you post what you got, because the ones included with models seem almost worthless.
To be honest, that's the one I tried for an hour or so, and didn't work well. My cut razor blade did more in 10 minutes.Your log inspired me to take a look at the CAF catalog.
I noticed they they have a molding scraper.
I'm ordering a longboat kit and getting the scraper also. I have the AL scrapers and do not really care for them. The smaller profiles are really limited IMO.
