Making your own Ropes
i guess i am just wondering if the strands have to be unwrapped first or not. The head of my machine has a variable speed drive on it and I can also change it`s direction and I can also control the feedrate on the takeup spool, so I don`t see a scenario where what you said would happen, but hey. I haven`t tested it yet either. I am still playing mind games at this point.
That rope walk works the same way as a normal rope walk. That makes sense, because there’s only one way to make rope. People have been doing it this way for 2,000 years. The only difference is that the endless rope walk has a constant supply of yarn. The strands are twisted in one direction, and in principle, rope is formed automatically as the strands twist together. This happens naturally because the strands are twisted in the same direction. If that strand already consists of twisted rope and it turns out that the direction of your twist is opposite to that of the strand, then it will untwist the strand. It’s just simple math. The rope produced will not be stable because it lacks the natural tendency to form rope.
Actually it doesn't.
a 'normal' rope walk twists the strands hundreds of times.
The planetary type machines twists the strands a few tens of times at most, making it difficult to get the tight lay a traditional machine provides.
which twist are you referring to? The one for each strand or the head rotation itself? The machine I have has both. I was wondering if you could give me a lay length and rope diameter that I could try which you believe can't be achieved with a planetary machine. I am just trying to see if my machine can handle it or not. I have both types of machines.
Yes, it does. You just explained yourself that the machine winds the strands around about 10 times more than the rope. So it’s the same principle.
That’s actually somewhat limited by the gear ratio, though, because it would be better if there were two motors in the system. That way, you could adjust the number of windings more precisely. I once designed a system like that for someone who wanted to use industrial spools of yarn. I was able to power the spool motor using slip rings.
This made the machine much more versatile. Maybe this is something for @Lorenzo71 to design, because the machine requires many more settings than just the weight on a traditional machine.
In my mathematical evaluation the number of torsion/cm depends also on the original torsion of the strands and the final direction of torsion of the rope (rh) or of the cavble(lh). The E-Gutermann strand doesn't have any initial torsion at all, but all the other strands made by 2 or more single filaments have it, and it's usually rh. My ropewalk discerns the kind of starting treads and evaluates the amount of torsion needed: in some cases are not hundred, but thousands.
...which twist are you referring to? The one for each strand or the head rotation itself?
I'm referring to the twisting of the strands by the whorls on a conventional machine. This is what builds the tension on the threads that causes them to form rope when allowed to twist together. The strands are trying to unwind, which causes them to twist together because they have no other place to go.
The orbital machines I have seen do not twist the strands very much compared to the conventional. This results in a relatively loose lay.
Do you have any examples of rope made with the orbital?
When I make rope on my rope walk, I do so over a 4-meter length. The strands then make a lot of turns. It rotates at 2,000 turns per minute, and the process takes 3 minutes. That’s 6,000 turns. The planetary rope walk makes rope over a 10-centimeter length, and in that case, it takes about 10 turns to make the first section of the rope. Over 4 meters, that’s 400 turns—not enough to achieve a good result. I can't show you no results
I have a vertical rope walk machine too. Which I have no problems using instead of the orbital. I just wanted to see if I could make a half decent rope with it. I still have a lot of experimenting to do.
I think your time will be better spent with the vertical.
I have yet to see anyone produce any rope with the orbital that looks like rope.
Whether you go S or Z is really not going to make any difference.
Howdy all,
I have a request. Does anyone have any recorded notes for Gutermann E151 and E382? What I'm looking for, specifically, is the weight associated to the different possible configurations with each thread, and possibly the resulting diameters. I believe I've nailed E121 configuration setups from 3×1 all the way to 3×10 and am now experimenting with the thicker E threads. What I'm missing is a sure starting point. Currently, I've figured out that, for instance, E151 3×2 results in a 0,38mm thread (diameter measurement has to be a close approximation) with an 8% reduction in the first twisting phase and 30g of tension applied. But the resulting rope appears to want to unwind a little, and so I let it. But that's something I don't experience with E121. So I'm wondering if I'm in the ballpark with my weight estimate for 3×2. For 3×4, for instance, I've tried 50 and 60g (10% reduction at first phase) and the resulting rope still tends to unwind a little. I simply let it spin hanging with a weight at its end until it stops.
Any indication would be greatly appreciated.
Thanks!
Howdy all,
Thanks!
Hi Krill, first of all I tell you that I don't have any E151 or E382 to test, so my answer is deducted from the algorithm of my machine. The E151, in my calculation, is about 0,132mm in diameter, so a 3x2 recipe, in my evaluation, it should give you a rope of about 0,35mm.
But, as I told before, I don't have any way to test it on the field.
I also assume that a difference of 0,03mm is something absolutely normal in these experimental measurements.
Howdy all,
Thanks!
I never worked with this type of tread. But I think they come near Skala 200 or 240. In that case you can take a look here:
