Queen Elizabeth II 1/1200 by Revell
Belgrade, Serbia
I must confess, while on my summer vacation this year, far from home, tools, paints, and everything else, I wanted to take something easy to build with me. Because every time I look at ships anchored in the sea, ships moving in and out of the port, checking each one on MarineTraffic to see where she came from and where she’s bound, I want to build something! :D And if I don’t, it will torture me!
This is why I left my incomplete Tovarisch build at home and bought another "small" plastic kit from Revell - Queen Elizabeth II, in 1:1200. With a minimal set of paints (I borrowed the white from my current build - I wish I wouldn't do that!), I've started my new vacation build!
I thought it would be a relaxing fun to assemble it looking at the sea and ships in the harbor. That was the plan....
PS
Dear @Lorenzo , I saw your build of Queen Elizabeth II when I got back to Belgrade, it is amazing and helped me a lot to realize my mistakes (I am not too familiar with the prototype) and get some ideas to improve my own afterwards. Anyway, thank you very much! This one and the other ocean liner builds are awesome!
The first thing I realized, was that I forgot the masking tape at home - as I said, "no tools"! :D
I started with the red underwater part and decided to paint the stand orange. Originally, it should be black with a golden ribbon — but not in my case. I still have some doubts about this decision regarding the stand, but it gives the model a festive, tropical and extraordinary look.
No primer - remember, no tools! :D The orange one still needs several coats - done, just saving the HDD place on the server.
I was considering construction masking tape for walls and so on — there was a construction shop nearby — but I remembered my childhood in the ’80s, when I attended a small youth ship-modelling club. We used electrical tape for waterlines, long before the fancy tools from Revell and Tamiya. I took a black roll and moved on!
The most important thing is that electrical tape is flexible and stretchy, so you can’t just stick it on — you need to control the resulting line carefully.
The best practice in this case with an ordinary brush is to keep the tape up and paint only down from the tape - so the paint could never leak under the tape. Even keeping that in mind, I still did some mistakes in the bow section - I will fix them later with smaller parts of the tape, first with white - then with black under the line:
Using the daughter's pencil and few EUR coins, I marked the waterline, applied the resin tape and turned the hull upside down to paint the board down from the tape, over the red paint:
This was the result. I also painted some decks and other parts (basins, etc.). @Lorenzo - you should notice, that I painted by mistake one superstructure deck gray instead of white and around the funnel also gray instead of green. I am still thinking of repainting these parts, but not decided yet.
(to be continued)
These little ships are fun to assemble.
The other day, I bought the Revell Bismarck—also in 1/1200 scale—at a second-hand shop.
There are still a few Revell passenger ships left, but they have been discontinued.
Salud Beer Beer
I totally agree, it was a real fun! :D Especially in terms of the effort-to-result ratio. The kit is highly detailed and quick to assemble at the same time. I can also feel a technologist behind it, designing the kit in a way that simplifies its painting - giving access to areas that are hardly accessible on an assembled model. You can get a sharp border between colors simply by painting the parts separately, even without masking tape, as in my case. So, with a relatively small effort, you get something valuable, while simply having fun in the process!
Beer
Just a small update to keep posting.... I fixed most of the problems with white/black border line (now I see at least one place I've missed!)
Cut off the decks with an office scalper I bought in the closest bookstore and gave a dry test to the decks, to see how do they fit:
(to be continued)
The lifeboats were painted white and orange. I’ve also darkened the portholes and so on with my daughter’s pencil, which I used for the waterline, so they contrast somewhat with the white board - first of all on the superstructures, like here:
Then on the hull as well. The decks were put & glued in their final places, and the most intriguing part was putting the lifeboats with davits inside the hull, because there is almost no space for them. But with some patience and a thin kitchen knife as a kind of ruler, everything is possible! ROTF
Then I had to put on a lot of small parts, like the main mast, flagstaffs, etc. - but I decided not to glue them, because they could easily be damaged on my flight back home, since I decided to take the model with me. Also, there was still some work to do:
  • the waterline - it was very hard to make such a thin waterline with two strips of electrical tape, keeping the spacing between them exact. I thought about using a small white thread to glue over it, or even a thin paper strip, but decided to do that later.
  • the decals - I was afraid to lose them with only warm water and no tools with me.
Taking this unfinished state into account, the final photo gallery is on its way... :cool:
Thanks, Lorenzo, and to all the guys who liked the result!Beer
That glass table is ideal for photographing waterline models.
Indeed, the table is a real hero of the photo session! :D It mixes with the sea behind in a wide range of angles, actually. But these photos were taken in the evening, at the sunset, when the sun sets down behind and the sea breeze calms down. In the morning you won't get this impression.
I even thought to create a cardboard waterline model of one of the tankers, ro-ro vessels, container ships or bulk carriers passing by! But I said to myself: Keep Calm (c) and build your kit, since you would end up with two new incomplete builds otherwise! ROTF I decided to focus. But next time, if I get a chance, I will certainly consider this option! :cool:
I was taking inspiration in "Marella Discovery", passenger ship, moving in front of me to the port and back to the sea many times, in the daytime and especially in the night! (absolutely amazing, honestly - a cloud of lights over the black water).
With a view like that, how do you accomplish anything ?
One of my boredom builds while camping.
Nice job!
This Revell's tugboat is also on my list, but I would like to transform it into a real tugboat model, she had long and interesting history and still sailing, although converted to a pleasure craft. :cool:
As for your initial question - honestly I don't know. Looking at all these ships moving in and out of the port, coming from the horizon, anchoring and then leaving - it gives a specific inspiration to make a model and put it on the table. :D
That tugboat wasn't on my list, but I've just added it. :cool:
Revell has some delightful civil ship kits.
Airfix and Heller do too.
Juan Sebastián Elcano or his sister Esmeralda??
Yes, most likely! Thumbsup I wonder if there are other similar tall ships. The intention of my comment was to ask our colleague @cdnfurball to share with us more photo and maybe the details of the kit & the build. There is a kit from by Artesania Latina built by @Ignatius27 recently in this section of the forum seems much bigger. ;) I would say it looks like IMAI (Aoshima, Minicraft, LEE, etc.) Esmeralda/Elcano in 1:350.
By the way, I am looking now at this build https://shipsofscale.com/sosforums/threads/airfix-1-600-rms-queen-elizabeth-2.6556/
And probably I will do some improvements later to my Queen Elizabeth 2 in addition to the decals and waterline... :D
PS
I have a similar challenge - looking at the ships in Simon's Town, or driving or walking along the sea has the same effect. I must build a ship! I am at the point where I am going to migrate from general subjects and kits to only kits with a naval/maritimetheme. Is there a support group for this deep psychological issue ...? ROTF
ChrisSC has several projects on this forum. He has built excellent ocean liner models. Exquisite work.
Boatman - I see you might be interested in building the J.S. Elcano / Esmeralda model kit from Artesania Latina. She was alot of fun to build and, as one of my first hybrid wooden boats, took me about 10 weeks to build. Some info about the kit: scale 1/250, length 18+ inches long by 10+ inches high. While she is specified as a Level 1 "beginner's kit" she was anything but easy. The challenge with Artesania Latina is that they don't provide printed directions for their models - all they give you is a CD with videos of how the ship is to be built. No drawings, rigging plans or deck plans...you are pretty much on your own.
The worst part of this otherwise great kit is the rigging. With 19 sails and stays, 80+ blocks and tackles, and about 40+ metal rings, the kit was very challenging to rig: about a level 3-4 rigging plan rather than a level 1. The rigging darn near killed me!
I am also interested in building tall ships and windjammers (sailing ships with auxiliary petrol power from 1850's on). In addition to the Esmeralda, I plan on building Gorch Fock (Mantua), Nippon Maru (Woody Joe), Amerigo Vespucci (Mantua) and the Charles Morgan whaler (Model Shipways).Feel free to reach out to me if you have any questions Good luck!
@Ignatius27 I think it is too large for me :D I cannot afford the space for the model! So being honest, I am considering Aoshima/IMAI 1:350 Esmeralda. But only when I finish my Gorch Fock series (yes. Tovarisch is only the first in the line) :cool:
