Better to get a "hot enough" devise. Cooking or charring the wood is best avoided.now to just get a hot iron, or somesuch
now to just get a hot iron, or somesuch.
I wrap it in a wet towel/cloth to do this.Try zapping the wooden piece to be bent in your kitchen microwave.
There seem to be many ways to broad bend successfully. I wish someone would invent a practical adjustable tool for edge bending which is as critical and much more difficult to do. Spiling is the best way to go, but most kits only supply straight sticks so it is not so easy to taper in breadth then edge bend so they do not lift.
he difficulty encountered with edge-bending that you've described is God's way of telling us that he never intended wood to be bent on edge.
You are of course correct, but with the vast majority of planking wood supplied being straight sticks instead of spiled planks something needs to be done. Happily, the method shown in the videos by Chuck Passaro works extremely well to get the proper shape and avoid lifting and gaps.
Yes, spiling is a great way to go, and some kits provide spiled planks, but most do not, so alternatives are needed. I have only used the Chuck Passaro method with Castello and Swiss pear so cannot speak for the sapeles and other woods we often see. It would be great to see someone use this method and post how it turns out. His method has made it possible to plank a hull realistically with the straight pieces usually provided in kits which I think is terrific.but note that in his demonstration videos he is bending Alaskan Yellow Cedar which is much more amenable to heat-bending than the low-quality "walnut," "mahogany," and other questionably identified exotic species frequently found in kit boxes.
When I soak a piece of castello planking 0,06" thick and 0,25 inches broad overnight I can edge bend it easily and clamp it down to keep it flat, then dry it over time or with a hot air gun. When I tried to do it dry before trying to heat it, it cracks. I had no clue about the chemistry, but I know what has worked in the past.
