- Apr 21, 2018
Lots to be found here...
What's it made of?tailstock riser block on amazon...
Tailstock Riser Block Compatible with EMCO Unimat SL/DB Mini Lathe | Mini lathe height adjustment block for tailstock alignment, compact accessory for hobby machining and small workshop projects - Amazon.com
Tailstock Riser Block Compatible with EMCO Unimat SL/DB Mini Lathe | Mini lathe height adjustment block for tailstock alignment, compact accessory for hobby machining and small workshop projects - Amazon.comwww.amazon.com
Looks 3D printed to me; if so I wouldn't want one.it says plastic.
wa da ya think ur gettin for $25?
but for the light work we do, does it matter?... as long as it aligns.
Die casting.Masking and painting the cross slide is fiddly work:
Also, the tool post base (?) was actually cast iron rater than the zinc alloy I've found on the other cast parts. Zinc castings are so accurate I'm guessing some sort of lost wax method.
The green piece in the picture. I checked it with a magnet, and the fact that it flash rusted when I removed the paint, suggests it's made from iron.Die casting.
Not sure which part you mean is cast iron; mine were all zinc.
The very early versions of the SL were cast iron, so I suspect yours has mis-matched components, which could possibly explain issues you've been describing.The green piece in the picture. I checked it with a magnet, and the fact that it flash rusted when I removed the paint, suggests it's made from iron.
Sorry, I disagree. I think you got one or the other.Could also be a transition model. Makes sense to use new old stock for parts that are dimensionally equal. Old paint also stuck far harder to the cast iron due to the rough surfaces that were not machined.
