Le Requin-Zebec-1750 POF 1:48 (ZHL)
Paper modeller here. Impressive build and skill so far. Congratulations @Daniel20 !!!
I could never do wooden models...
I am designing a paper xebec 1:250 scale.
I researched days over days for it on the web, especially regarding the lateen rigging.
BUT there remains one question I could not find an answer to:
Thanks to the low profile xebecs could be propelled by oars and that's why there are many wooden models containing oars stowed away on quarter deck or bundled up and hanging from the side of the hull.
But there are no benches between the cannons. Did they pulled the oars while standing? Is that even feasible?
I read through many xebec build threads here on SOS. All astonishing builds with expertise and good research. But there I couldn't find an answer to my question, too. The oars subject was never mentioned or I failed to notice.
What do you guys think?
Hello ElMax, you ask a great question that now I will try to find an answer to. My immediate thought is the men rowed from a kneeling position but wow that would be hard on the knees. And thank you for your compliments.
I don't know much about rowing but imagine a pirate crew after rowing on the knee they could not board any merchant ship or fight the navyROTF
Hey Daniel, just catching up on your build. Beautiful work thus far! I’m looking forward to seeing your future progress.
Don’t worry about your log sitting idle due to other obligations, it’s not going anywhere. Case in point, my ship build…lol. My granddaughter reminded me recently I need to work on my ship. I have been told by a 9 year old…haha!
Thanks Dean, for now the other obligations are piling up.
If you get told that by the Admiral, then you really have some serious thinking to do…
Good afternoon, Daniel! A xebec is not a galley; oars were used rarely—only during maneuvers. Consequently, xebecs were not built with dedicated rowing benches, as these would have been useless most of the time and would have caused significant obstruction.
The rowers worked standing up, with one men to an oar on small merchant vessels, and sometimes two men if the ship was large and heavily armed.
I have come across at least one image of a Mediterranean xebec from that era showing rowers standing at their oars. It is interesting that the stern platform has been removed from the ship.
During maneuvers on xebecs, the rowers faced the bow of the ship. Interestingly, the rowers on the pilot boat towing the xebec also face forward so they can see where to maneuver. The vessel is likely heading toward a cargo berth with a particularly complex navigable channel.
The image shows a single rower at each oar. For two people, the oars featured special handles, as shown in the picture below.
Thanks for this information, Igor, great illustrations. I have seen conflicting information on this subject, not surprising though considering the amount of time gone by. Below I copied and pasted a query I did on Copilot however I have found Copilots answers are not always accurate.
What position did men assume while rowing on 16th century xebecs ships, standing or sitting?
Men rowing on 16th‑century xebecs rowed sitting, not standing.
The evidence comes from how xebecs were built and how their oars were used:
The rowing position​
  • Xebecs evolved from Mediterranean galleys, which universally used seated rowers on benches.
  • Contemporary descriptions note that xebecs carried 18 oars for maneuvering in calms, directly inherited from galley practice.
  • Their low freeboard (low height of the deck above the water) made standing rowing impractical and unsafe.
  • No period source describes standing rowing on xebecs; all surviving technical descriptions align them with galley‑style seated rowing.
⚓ Why seated rowing was necessary​
  • Long, heavy sweeps required leverage best achieved from a fixed seated position.
  • Stability: standing rowers would raise the center of gravity on a narrow, shallow‑draft hull.
  • Coordination: Mediterranean rowing systems relied on synchronized seated crews.
Summary​
Xebecs were fast, hybrid sail‑and‑oar vessels. When using oars, their crews rowed seated, just like galley crews, because the hull form, oar length, and Mediterranean rowing tradition all required it.
If you want, I can also explain how many men rowed each oar, or how rowing differed between xebecs and full galleys.
Good Monday morning all. I'm back working in the shipyard slowly planking the stern section below the transom. There is a considerable bulge requiring soaking the strakes then bending with my trusty curling iron (which so far is the best bending tool I've found). I had neglected to sand off the char at the stern post edge before I started the planking, so I had occasion to use my riffler file in the limited space which worked out perfectly.
It would appear I have my ship perched precariously over the edge but it's just an illusion of sorts as you'll see in this next shot.
Sometimes this is the only workable position I can get.
Next, I've been experimenting on planking hold down devices, the rib spacing is so close, and they are so thin I came up with a wedge system I had used previously on my Bluenose. Metal wire loops that you place between the ribs, turn it 90 degrees then place in the wedge, and it firmly holds the plank against the ribs.
That's it for now, thanks for looking in.
Till next time.
Dear Daniel! I, too, have come across conflicting information. The *Methodological Encyclopedia* of 1780 contains a description of the Mediterranean felucca. It states, among other things, that the rowers would remove the slatted hatch covers located between the guns and sit directly on the deck, bracing their feet against the deck beams below.
However, if you look at the blueprints of such ships, it is evident that sitting in that manner is very difficult. It is possible that this method was used only in dire situations—for instance, under enemy fire—whereas under normal circumstances, the rowers operated their oars while standing.
In various images of feluccas from that era, it is impossible to tell whether the rowers are standing, sitting on special benches, or sitting on the deck with their legs dangling into the hatches. I didn't find any paintings depicting xebecs with oars. The paintings of feluccas shown below most likely feature special benches, just like those found on typical galleys.
View attachment 643095View attachment 643096
View attachment 643094View attachment 643093
Till next time.
Good morning Daniel. How are things in the "Great state of Texas? Man, this is such an interesting construction. I have massive buyers remorse not buying this Xebec kit, however with my robust modelling I think many of these tiny frames etc would be broke by now ROTF. You are owning this. Cheers Grant
Thanks Grant, along the gulf coast we are finally starting to cool down, and the politicians are heating up! Ha! The upcoming holiday season is my favorite time of the year. You've no need for buyer's remorse Grant, you already have a premier version in your inventory.
Great information! Thank you very much. Where did you find these pictures? I did not have such success with simple online search prompts containing xebecs oars oarsmen sitting standing etc
The second picture does not look like a xebec but it is more to illustrate how rowing while standing works, right?
Summary​
That's really conflicting.
I may be a little bit biased because I don't trust LLMs and tend to avoid them (always have been a scifi fan and AI positive but regarding ChatGPT and the lot I became quite a luddite ROTF )
Don't know what references copilot used. The "argumentation" does not quite do it for me.
For example the stability point. Xebecs required large crews for handling the big lateen rig (like dhows). Sure they would have to do it in a coordinated manner regarding stability but just standing alone would shift the center of gravity critically?
Impressive, xebecs really are quite an illusive topic! I searched days (counted in hours) for informations online to various questions I had. For example did they rig the yards inside or outside the shrouds? Apparently both was possible.
In the end I decided to rig the yards on my design outside of the shrouds:
(still work in progress and not that impressive compared to the wooden builds of you guys, I guess. But it's 1:250 scale, not much small detail feasible)
Interesting possibility with the hatch covers and sitting on deck!
In fact, I came across various pictures of xebecs with something on the hull side that I interpreted as openings for the oars and these where located quite low. Lower then the gunports
Impressive enough at 1/250 scale!
ElMax, you have a nice example of a xebec. In Jean Boudriot and Hubert Berti's monograph they have a very nice model they use in their discussion's, the fore sail yard is rigged on the port side, between the shrouds and mast, and the main mast yard is rigged on the starboard side between the shrouds and mast. The mizzen is rigged back to the port side. The yards had to be hauled vertical then dipped and past to opposite sides from time to time. That will be my rigging plan when I get to that point.
