Thanks my friend.beautiful carving!!!
No carving of a stallion on the front?A little side project. The Admiral wanted a little cabinet for the spices—one that keeps out sunlight so the spices stay fresh. I found a secondhand medicine cabinet online. I cleaned it, lightly sanded the inside, and thoroughly sanded the outside. I removed the glass from the door and made a panel out of cherry wood. (A tabletop that I cut into thin strips.) I covered the outside with cherry veneer and did a lot of sanding, polishing, and finishing.
View attachment 632516View attachment 632517View attachment 632518
Cherry wood stays beautiful. I did have to clear off my hobby table first, though. But now that the project is finished, I can set up my router station again and get back to work.
And actually it was a lot of fun to do. Especcially to get the veneer on those rounded ends and corners in a way it looks like a piece of wood.
Good to see you back i business. I was ready to start again on the stallion, but 2 ropewalks came in between. So patience is neededNo carving of a stallion on the front?
very nice work on the carving Stephan. Had a lot to catch up.
Always nice to build a ‘spicy-cabinet’ for the Admiral, Stephan. ‘Liefde gaat door de maag!’A little side project. The Admiral wanted a little cabinet for the spices—one that keeps out sunlight so the spices stay fresh. I found a secondhand medicine cabinet online. I cleaned it, lightly sanded the inside, and thoroughly sanded the outside. I removed the glass from the door and made a panel out of cherry wood. (A tabletop that I cut into thin strips.) I covered the outside with cherry veneer and did a lot of sanding, polishing, and finishing.
I got a lot of love, you knowLiefde gaat door de maag
Good business these ropewalks.Good to see you back i business. I was ready to start again on the stallion, but 2 ropewalks came in between. So patience is needed
Thanks Christian, you're welcome. It's started as an experience with other wood then European Boxwood. Apple, pear and sherry behave also good when you use a rotary tool with small burrs. It's a little more different because the inconsitance in hardness of the wood.I found your log today, Stef. Really nice progress.
Thanks RogerLooking good Stephan, I always enjoy looking at your progress.
