There is no easy way to make these and have them look right. What is your scale? I have seen copper wire used for the stirrups as it is soft and easy to shape and rope for the foot ropes on the smallest scales.What’s the easiest and quickest way to make the yard stirrups?
This is my current plan. I bought blackened copper wire for this.I have seen copper wire used for the stirrups
1:98 is the scaleThere is no easy way to make these and have them look right. What is your scale? I have seen copper wire used for the stirrups as it is soft and easy to shape and rope for the foot ropes on the smallest scales.
I second this idea. At 1:96 scale small eyebolts can be used. They already have the eye for the foot ropes to go through.On some models I have used eyebolts (kit left-overs) as stirrups. They were quite long, used thin wire and had a small eye. I can't remember which kit maker they came from. They seemed about right for scale. I just pushed the ends into the yard. A cosmetic band of wire or thread could be added round the yard if required.
The photo below shows some blackened copper wire I bought some time ago. I have screwed up the end and the coating seemed to survive.
Aside: Ny profile that Amazon has built up has concluded that my hobby is jewellery making because I buy a lot of wire, small vices, bead grippers etc!
OH well another idea dashed into dust!As always and as it should be, your choice in the end.The eyebolts at Model Expo look much larger than 0.01" (0.25mm) diameter that would be to scale. They describe them as 0.75mm so triple what they should be. Also, they are only 6mm long which is far short of the 3 feet they would hang down. 6mm is closer to two feet so will not be close to what they should be at 1:98.
Amati ?As always and as it should be, your choice in the end.The eyebolts at Model Expo look much larger than 0.01" (0.25mm) diameter that would be to scale. They describe them as 0.75mm so triple what they should be. Also, they are only 6mm long which is far short of the 3 feet they would hang down. 6mm is closer to two feet so will not be close to what they should be at 1:98.
Maybe once you see what the sizes of the footropes and stirrups are you can decide what material to use. Keep in mind on the actual ship the stirrups were served and hung three feet below the yard. At your scale it will be difficult to serve the stirrups unless you use copper wire and super small thread for the serving. I would forget the serving, but your choice.
Main mast diameter on Victory is supposedly 41". The main stay circumference is thus about 20.5" (6 1/2") The footropes are thus 1.5" diameter and the stirrups are 1" diameter.
At 1:98 the stirrups would be 0.01" diameter and the footropes 0.015" diameter. If you go with thread, the stirrups would be Tex 45 or 50 medium to heavy commercial sewing thread. If copper wire, 30 gage. For the footropes, the thread to match the rope size would be Tex 100 to 130. Hope this helpS
