3DPrinting an Embossing Wheel to Pattern Copper Tape for Hull Coppering
  • Thread starter Thread starter johnv
  • Watchers Watchers 5
Geelong, Australia
Copper tape to copper the hull of my 1:72 model 74 gun ship Bellerophon.
I used 5mm wide copper tape for my model USS Constitution in 2025 and it was reasonably effective.
I was persuaded that at 1:93 scale the nail impressions would not be visible on my Constitution copper plating, but in researching the topic for Bellerophon I came across this photo of HMS Trincomilee, a frigate made 1817 in Bombay for the British navy.
HMS Trincomalee is still afloat, although this shot was taken when she was in drydock for repairs. Even though the coppering is not original it does show the nail positions by the dimpling which the nails produce in the copper sheets. Somewhat confusingly, it also shows the upper sheets overlapping the lower ones, which was not the practice for British ships of war in the original era. From this distance of a few meters the dimpling is clearly visible.
So I decided that my Bellerophon model would have nail heads showing on the copper sheets.
For the nail pattern I used a diagram from Mark Stanforth's monograph "The Introduction and Use of Copper Sheathing - A History" which shows the front sheets overlapping the rear ones AND the bottom sheets overlapping the upper ones. This overlap apparently only occurred in Royal Navy ships. On merchant navy ships the upper plates overlapped the lower ones. I can find no explanation for this difference.
The diagram also shows the location and nail spacing of the edge nails compared with the centrally located ones.
While not copying this diagram precisely for my Bellerophon, it was very influential.
I removed every alternate nail impression of the edge nails because at my 1:72 scale they would have been only 0.5mm apart. I might yet reintroduce them because one eagle eyed member of my model engineering club imediately spotted the difference today.
As you can see I drew up the pattern in AutoCAD, saved it as a dxf file without the dimensions and borders....
.... and imported it onto a tangent plane of a 3D impression wheel modelled in Solidworks, then used the wrap with emboss option to wrap the nail head impressions around the wheel, which now has tiny projections for the nail head embossing (tiny ... 0.1mm high and 0.1mm diameter) and slightly higher for the plate divisions (about 0.12mm high). Saved the model as an stl file. Printed one wheel, modified the resin print settings, and then printed 2 port and 2 starboard wheels in basic water washable resin. The resin print runs took 1.5 hours each.
Draining the unused resin back into the printer tray.
After washing, de-supporting and curing the wheels I made some test patterns in some laser cut strips of copper tape. At this stage I just used a rough handle to hold the wheel. When my 25 meter 6mm wide tape rolls arrive I will make a proper jig to position and spring pressure the wheel onto the tape and make accurately positioned strips for their embossed patterns.
This was the first printed wheel and first wobbly copper tape impression. The 26mm diameter wheel was printed at a 45 degree angle to the build plate, but some pins did not print properly, hence the imperfect impression pattern in the test tape. The later 4 wheel printed wheels were printed with the side faces parallel to the build plate, and the minute pins came out perfectly. I used a 0.02mm layer height.
So, waiting impatiently for the rolls of 6mm wide tape to arrive, so I can finalise my design for the jig to print 65-70 strips 800mm long, and then to attach them to Bellerophon. Why 6mm tape for 5mm coverage? I will overlap the tape strips by approx 1mm .
Watch this space for "Coppering Bellerophon -3". The picture below is Bellerophon waiting for coppering. It is from Amati/Vanguard plans, but almost a scratch build. I am using some Amati brass etched parts.
This project has advanced.
The rough wooden handle has now been replaced by a 3D printed jig, and I am up to the 4th or 5th redesign and testing of the main component which is the impressing wheel.
The jig for holding the impressing wheel under pressure, the slot for feeding the 6mm wide copper tape, and the large wheel which holds the copper tape.
The tape feed wheel is made in 2 pieces to accept the standard Chinese copper tape wheels. This one is specifically designed for 6mm wide tape, as is the slot in the base of the jig.
The base of the jig can be held in a vice, or clamped to a bench or table.
I had planned to install springs to apply the downward pressure on the impression wheel, but used rubber bands as a temporary measure, and the bands worked so well that I will not bother with springs.
The wheel fits neatly into the slot. It is resin 3D printed. Supports are used on one face, and that face is cleaned up on a lathe. The central hole must be perpendicular to the faces, so I reamed it accurately to the shaft size, also 6mm.
Port and starboard wheels must be made. And since I do not know how the wheels will wear, I made 4 of them for each side. I also did some tests of protrusion length, and 0.18mm seemed to be the best.
Those nail heads are 0.16mm wide which is about twice the diameter of the original nails at 1:72 scale. I am still considering whether see if true scale size looks better.
I am planning to impress 800mm long strips of the copper tape, and then to apply them to my Bellerophon, overlapping the strips by approx 0.5-1mm.
I have not yet decided whether to start from the keel, as in full size practice, or from just above the water line which would permit the lower strips to overlap the upper strips, also as in full size practice. That is the main disadvantage of the copper tape, compared with solid copper panels.
The subtlety at this scale is very impressive. FAR better than any kit or aftermarket copper plating which is rarely, if ever, to scale. Thanks for sharing.
Very, very impressive (forgive the pun) design solution John. I spent quite a time a while back trying to find a realistic solution for the coppering of my 1:64 Syren. The kit manual provided a technique for indenting the provided tape but I just could not replicate it effectively so I ended up buying indented tape from China. Your embossing tool is a well thought out and designed solution.
Thankyou for your very kind feedback. John
And ditto. Thankyou very much indeed. John
P.S. I am happy to share the stl files of the jig and the wheel, but note that they are specific for 48" x 14" plates at 1:72 scale and approx 1mm of tape overlap.
Some modifications of the copper tape embossing tool, f
inished the coppering of the 1:72 Bellerophon, painted the rest of the hull, and am now working on the 18pr gundeck and guns.
Wonderful and very creative machine! Definitely something very useful. Thank you for offering to publish your str files. Dedennis from our wonderful group has published some files of a ropewalk, waterline marker, plank bender and other useful machines on Makerworld. Perhaps it would be a good idea to (if not already done) to have a place here where such files could be stored for use by our members?
Rob
love your solution to a big problem.
I bought a little tool from Artesania but it's hard to align the wheel with the copper strip:
thankyou for the kind feedback.
Maybe you could mount your ponce wheel in a jig like the one which I printed, but the wheel would need smooth sides to fit neatly in the jig track. Maybe you could fit some washers on the sides. Might not be possible. The wheel sides need to be the same width as the groove which the tape runs in. A loose fit leads to wandering impressions as I discovered with an early version of my jig.
Rob
Yes. The stl files are published on another ship modelling website but I would be happy to so the same here. No doubt there will be completed jig copies available soon. But note that my present design is only for 1:72 models. The stl could probably be scaled for other ship scales but I have not yet tried that. I have committed to do so at 1:48 for a friend. One complication is that the wheel needs to be resin printed and the jig itself FDM printed. And some basic machining with a small lathe. It gets a bit machinery intensive.
