Le Saint Philippe 1693 1:48 piani Lemineur Ancre
Salve a tutti voi questo progetto in scena di costruzione del modello di San Filippo in scala 1:48 da monografia ANCRE, confido nei consigli e aiuto di tutti voi. Alcune immagini del lavoro svolto fino ad oggi .
google translator:
Greetings to all of you this project on the scene of the construction of the model of St. Philip in scale 1:48 by ANCRE monograph, I trust in the advice and help of all of you. Some images of the work done to date.
65275663_2369260403310122_6007831074330116096_n.jpg65043552_2369260069976822_2174532922533478400_n.jpg65043040_2369260446643451_4725775970605203456_n.jpg65154014_2369260176643478_6630638333393371136_n.jpg64846426_2369260099976819_7948394240369754112_n.jpg65071329_2369260129976816_8859348540334276608_n.jpg64958171_2369260519976777_8550904269971128320_n.jpg65228462_2369260223310140_5662650956546834432_n.jpg64890572_2369260316643464_8107528911899852800_n.jpg64934320_2369260546643441_4050762559425347584_n.jpg64914141_2369260979976731_2038674989472808960_n.jpg65133467_2369260269976802_4222550818789785600_n.jpg65433551_2369260376643458_3552610043159379968_n.jpg65254366_2369260719976757_8551340222036574208_n.jpg64940540_2369260763310086_8468723738664239104_n.jpg65010170_2369260833310079_1211908473780961280_n.jpg67239252_2383445318558297_8404178501988515840_n.jpg65241861_2369260879976741_91969023767478272_n.jpg
Hi Giancarlo, very good job but your photos hurt the neck ! ;)
I will change it - your health is too important
Edit:
I tried it, but because of any unknown reason I can not turn them......copies of photos on my computer are shown correctly - but when I am uploading them they are once more wrong.....sorry, but seems to be that we have to life with them in this way - or Giancarlo is revising his original photos...... :confused:
[QUOTE = "NMBROOK, post: 67503, membro: 2622"]
Benvenuti nel forum Giancarlo. Non vedo l'ora di seguire la tua compilazione e discutere i dettagli con un altro costruttore di Saint Philippe
Cordiali saluti
Nigel
[/CITAZIONE]
Sono io che non vedo l'ora di vedere la tua creazione in 1:36 .
[QUOTE = "Michel, post: 67509, membro: 6528"]
Ciao Giancarlo, ottimo lavoro ma le tue foto fanno male al collo! ;)
[/CITAZIONE]Grazie Michel mi dispiace per il tuo collo .
Edit:
Italians are malicious .. :p
Scusate , ma ho provato a girarle anche io ma niente quando le vado a aprire sono caricate verso giusto poi per qualche strano arcano si rigirano !!!!!! Vorrà dire che pagherò una serie di massaggi alla cervicale a Michel ????
Chiedo scusa , ma solo a me capita che le immagini che carico vengano girate , oppure capita anche a voi ? Grazie
Excuse me, but only to me it happens that the images that load are turned, or it happens also to you? Thank you
I have uploaded images last night and I had no problem.
Ho caricato immagini ieri sera e non ho avuto problemi
Ti ringrazio , ma io provo a caricare le immagini nel verso corretto ma poi mi vengono girate .
I thank you, but I try to load the images in the correct way but then they are turned to me.
Esci, riavvia il browser e accedi di nuovo, quindi riprova.
Sign out, restart your browser and sign in again then try again.
Mi scuso con voi tutti , ma ho riprovato a ricaricare le immagini , ma vengono sempre capovolte ?????? Non capisco
Scusate !!!!!
I apologize to you all, but I tried again to reload the images, but they are always flipped ?????? I don't understand
sorry !!!!!
64907798_2369260796643416_4447841116393308160_n.jpg65101423_2369260589976770_2317381288530542592_n.jpg65303923_2369260929976736_8125224692555448320_n.jpg65314177_2369260636643432_5527806970775470080_n.jpg65730155_2376342202601942_24836670591336448_n.jpg65805501_2376342019268627_3767537834513137664_n.jpg65950172_2376342079268621_6244178902676144128_n.jpg66049387_2376342149268614_1307472101707350016_n.jpg66426661_2383445215224974_4275948235920506880_n.jpg66651062_2383445158558313_25296764667953152_n.jpg66710862_2383445348558294_4901329318560399360_n.jpg66716090_2383445251891637_8654760075291787264_n.jpg67343945_2383445278558301_4720338146871476224_n.jpg
Scusate !!!!!
sorry !!!!!
Ciao, ho corretto le tue immagini, non per ordine, ma domani potrò lavorare anche su questo.
Hi ,I have fixed your images ,not in order but tomorrow I can work on that too.
Hallo heren,
Ik merkte hetzelfde, aangezien de server update alle geüploade foto's horizontaal worden geplaatst, ook foto's die verticaal werden genomen.
tip use your phone or tablet this is easier to turn then your pc :)
