Kit Review: "H.M. Armed Cutter Alert 1777 (Second Edition) - Plank On Bulkhead", Scale 1:64 - Vanguard Models
Jimsky
Administrator
Administrator
Forum Moderator
Brooklyn, New York USA
The model kit of the Alert is depicted after her refit with twelve six-pounder guns and a full complement of twelve half-pounder swivel guns, giving an ordnance total of twenty-four guns. We have many pages about the history of Alert here at SOS, I will rather concentrate on the kits itself.
Scale: 1:64
Length overall - 637mm/25.078"
Width overall - 256mm/10.078"
Height overall - 517mm/20.354
There are two versions of the kit to choose from - Standard and Premium. The version differences are:
Standard * Basswood laser-cut wood parts (including sub desk),
* Cast metal cannons
Premium (Limited to 10 kits on initial release)
* Pearwood laser cut wood parts
* Sub desk laser cut using 0.8.mm plywood
* All 24 cannons (12 x 6-pounder and 12 x half-pounder swivel) cast resin in black
The Model.
Once the model has been built, it should look like the model shown in the below photos (courtesy of Vanguard Models, Chris Watton)
I have purchased a premium version of the kit, so the review will be based on this kit.
The Kit
The kit was delivered really fast (less than a week, from England to the US). Kit designed as a double plank on bulkheads, all parts are high-grade quality including cast resin cannons and 3 sheets of photo-etched parts in different thicknesses. The Kit parts inside a reasonably large box, well packed with bubble-wraps and all parts where sealed in plastic bags. Once the box opened, you will see a spiral-bound A3-size instruction manual.
All packed well in a bubble-wrap
The base kit contents
Content of the kit\Timber and Timber strips
A few words about the timber\timber strips. The kit of Alert contains boxwood for the deck planking and pearwood for the final hull planking. All timber strips sealed in thick plastic sleeves to avoid incoming moisture. They are properly labeled and matched with the inventory sheet. The timber strips are nicely cut from the same billet and match the color.
Limewood strips for first planking
Boxwood for deck planking
Pearwood for final hull planking
to be continued...
The Fittings
A really tidy way to store all the fitting in one place, this kit presents the spick and span 'Fitting pack' box. Keeping all 'under the hood' make it easy to find, and reference the number from the inventory
Opening the box reveals a number of labeled plastic bags with various fittings. Let's take a look at each of them. Please note a cast resin (grey color) large winch. In my opinion, it looks great just needs a little cleanup. The anchors are white metal. The photo speaks itself!
A special wording about the cast resin cannons. They are already black in color and doesn't require paint (IMHO). Very hight cast with small details such royal emblem. Cannonballs a bit oversized (If you will try to insert) :)
details and close up
Half-pounder swivel guns. They come with the PE fret (handles)
to be continue...
Blocks, deadeyes
The next packets will contain deadeyes and blocks. They are single and double blocks of different sizes on average quality. IMHO, I wish the 'premium kit' contains premium blocks made from pear or boxwood. Master Korabel makes very nice blocks, and it would be a nice fit for such a kit.
Deadeyes, however, really good quality and doesn't require sanding (ready to use). Look at the drill holes-they are even on all pieces.
The last packets contain parrel beads and also the mainstay ‘mouse’.
We will discuss the Photo-Etched parts next...
Photo-Etched parts
The kit contained three frets in 0.2mm, 0.4mm and 0,6mm made from brass. All the parts will intricate many of the components including the stern decoration, eyebolt rings, gudgeon\pintle for the rudder and many others to compete for metalwork. One of the frets included mast hops and deadeye's strops (nicely made)! It does have a nameplate so you can use it on the stand.
rigging is next...
The Rigging
All riggings come in a zip-lock bag. There where 6 flat spools of various rigging thread in black and natural colors. In a separate packet, you will find a cable work thread, looks like the anchor cable - extremely realistic. All spools are labeled for future use and identification.
The next we will discuss timber wood
Structural sheet and other wood timber use in the kit
All sheet material is laser-cut and comes in a single thick clear plastic sleeve. The structural parts come in 3mm and 2mm MDF board. They contained: Falsekeel, bulkheads, bulkheads securing parts, inner\outer bow parts. I know, that some of us prefer to have plywood instead of MDF. Personally, I don't mind MDF as it always comes warp-free, and in this kit, both boards is no exception!
3.0mm MDF
2.0mm MDF
For the false deck and poop, the kit introduced 0.8mm ply (warp-free)
a close look at the false deck
The rest of the parts are laser-cut from actual pearwood timber. Those are a combination of different thicknesses 3.0mm, 1.5mm, and 1.0mm boards. These are contained parts for everything else (timber-related). From hatch coamings, transom\cap rails, stem\sternpost to gun carriages and carriages parts. One part is, however, puzzled me quite a bit. The gun carriages axle part is square??!!! You would think you should round them...think twice, the weels hole is also square. Not sure why...
1.5mm board: hatch coamings, gun carriages
Keel, stem, and sternpost, Windlass and rudder parts (3.0mm)
cap and transom rails 1.0mm
One word of caution: All the MDF and wood timber parts are not numbered. I strongly suggest labeling the parts according to the master sheet (before removing parts from boards)
The next, we will discuss the manual
Instruction manual (spiral-bound book)
Before we move to the manual, it worth to mention another few parts: A sail clothes and something rather unusual for wooden kits - a clear acrylic display base. Should you decide to rig Alert with the sails, there a plenty of material provided, and the instruction manual contains templates in scale 1:64 (just transfer sail template into the cloth!
Clear plastic base, assembled really easy but require a special glue. CA will work but may clog the surface
The kit doesn't provide plans (the way you can build it from scratch), however, the rather large (A3 size) manual will definitely complement and help build the model the right way! The manual printed in full color on glossy, thick paper (56 pages total). As I mentioned before - spiral bound. A step-by-step guide, real intuitive, containing photos along with text explanations.
The first few pages introduce with upper and side elevation drawings following by building tips and recommended tools and 2,5 pages of the inventory list.
Inventory pages
The next few pages show parts and their corresponding numbers. As mentioned before, and this is critical to transfer all the parts number into the actual timber boars before cutting the sheets.
The next pages will show construction stages in photographs and annotations to them. Those photographs very intuitive, clearly showing the given task at hand.
Obviously, there are pages dedicated to Masting and Riggins. Those provided as drawings in scale 1:64 with accompanying dimensions and diameters. Also, very detailed rigging plans supplied showing seizing and ratlines clearly.
Conclusion
This is a great kit supplied with high-end timber and fittings. The construction can captivate for many hours at the bench. A gorgeous model can, and most importantly, should be build without 'bashing' ...but in the end, it is your call.
I hope this is somewhat informative and will help to know the kit better. :)
Happy New Year everyone!!
to be continued...
Boy, quality of kits definitely improved over the years. Boxwood, pear - almost unheard of only a few years ago.
yea...the timber in this kit - first class! Very unusual for the kits manufacturers. If I remember, only Master Korabel supply Perwood Timber in their kits.
Fantastic kit and review, for me the only setback is the scale.
I agree with you Zoly, I wish it could be the scale 1:48, but... in scale as this kit is the length overall - 637mm and height overall - 517mm. At scale 1:48, it will be huge and required more space for display (unless you build it as a gift, then who cares... :p )
The Trident Alert is 1:48 scale
Chris Watton’s kits are always first rate. I’m looking forward to the Trident version of Alert. I wonder if it will have photo etched versions of the painted decorations like this kit has.
