Hi all need to get a mini-chop saw, looking at HARBOR FREIGHT they have 2 types a 2inch that will take up to 1/2 inch material, and a 6 inch that will take up to 1 inch material QUESTION IS THIS IS THE 6 INCH FOR WOOD OR ONLY METAL. THANKS ALL Don
WHAT ABOUT THE 2 inch
NEED A REAL ACURATE ONE
HI GILLES AND MIKE, I AM GOING TO POST A PICTURE IN THE Le ROCHFORTE LOG, FRAME No. 25 through 32 and SOME FRAMES IN THE BOW SECTION ALSO MY PLAN TO DO THESE TYPE OF FRAMES IS TO MILL THE NOTCHES as a a one piece section for where they go once i have the notches milled where thbelong i want to cut the vertical ito the 2 pieces as shown on the FRAME PLAN I KNOW THERE ARE OTHER WAYS TO DO THIS BUT FOR ME AND SKILLS AT THIS TIME (AGE) I FIND THIS ABOUT THE BEST WAY TO DO THIS, AND LOOKING AT THE MINI-CHOP SAW NOT GOING TO WORK AT ALL, RIGHT NOW THINKING ABOUT USING MY BAND SAW WITCH HAS A FINE TPI BLADE AND USING SOME CLAMPS AS HOLD DOWNS OR SOMETHING SIMULAR TO THEN MAKE THE VERTICAL CUTS AS NEEDE THE OTHER PICES OF THE V FRAMES DO NOT PRSET A PROBLEM AS I DO NOT HAVE TO WORRY ABOUT THE NOTCES AS I CAN OVER CUT THE VERTICALS AND FINISH THEM ON THE DISK SANDER, ANY OTHER IDEAS WOULD BE A BIG, BIG, HELP I will post frame No.25 with this message and then re post in the log. THANKS ALL don
I have used a 2'' Harbor freight chop saw for many years. It is inaccurate but very useful when you have to cut metal tubing or strip and don't want to dull the blade of a better saw. The trick is to replace the toothed saw blade with an abrasive disc. Don't know what the current price is, but mine was $25 and I have certainly gotten my money's worth.Hi all need to get a mini-chop saw, looking at HARBOR FREIGHT they have 2 types a 2inch that will take up to 1/2 inch material, and a 6 inch that will take up to 1 inch material QUESTION IS THIS IS THE 6 INCH FOR WOOD OR ONLY METAL. THANKS ALL Don
