Thank youSparky,
I think your garboard strake is way up high at stem. If you install it as is, it is going to push all the planks above it. It might help to mark run of each plank on frames, before you actually start planking it. Looks great.
So would I do a square cut or taper it?Hello Sparky,
I would even cut at the beginning of the second bulkhead. Agree with Gennaro, you will end up extreme curve of the planks.
Thank you very much... Having a difficult time understanding how to plank. I initially figured a smaller model might be easier for my first planking. But not the caseYou will need to taper it near the beginning of the second bulkhead. Check out this photo (courtesy of @Dave Stevens (Lumberyard) )
Not sure on trim the Garboard plank? I soaked the plank and placed on the bulkheads to get the shape. Question is to I cut the plank where the arrows are pointing to?View attachment 143483
Hi SparkyDo your plans show in side view the running of planks? You can see in the image below, where garboard plank ends in cutter Cheerful. Another excellent tutorial on planking is David Antscherl's (http://www.admiraltymodels.com/Planking_primer.pdf).
Thank you ordered last night. Will stop planking now and will read the book once it gets here>Hello Sparky, It is totally understandable. You may avoid most of frustrations if you better understand the entire process. We always wanted to get our hands dirty with building, but a much feasible way to learn it first. There are many books out there to teach you planking, below one of them and I consider it as the primer. It is really tiny and cost symbolic price...but you will understand the process of planking and can apply to your model.
Model Shipways MSB113 Planking The Built-up Ship Model By Jim Roberts 692756774146 | eBay
By Jim Roberts. The information is also useful for over-planking solid hull models.www.ebay.com
you may find even a better price (used)![]()
Hi Ian, Thanks for the tipHi Sparky
Note the manual says the garboard plank should end about an eighth of an inch forward of the join in the keel. Most of what has been said above is in that direction. Jimsky's comment in post #6 above shows what I had to do to make mine fit but that example is further towards the bow than the recommendation for our 18th Century longboat.
Thank you for the visual post.Do your plans show in side view the running of planks? You can see in the image below, where garboard plank ends in cutter Cheerful. Another excellent tutorial on planking is David Antscherl's (http://www.admiraltymodels.com/Planking_primer.pdf).
Thank you for the photo, seeing the tamper helped me as to I doing incorrectly.You will need to taper it near the beginning of the second bulkhead. Check out this photo (courtesy of @Dave Stevens (Lumberyard) )
