- Nov 25, 2018
Be more optimistic, friends .We will survive this infection COVID., I'm going to make duplicates and save them for future projects.....if I survive this one.
Has nothing to do with the infection.Be more optimistic, friends .We will survive this infection COVID.
Nice flip flops LolI"ve got the gunport patterns installed. You really need to carefully measure to get them installed correctly. I still had to cut out several bulkheads and deck sections to make room for the dummy cannon boxes. This is also my first try at using the brass nails. Not pretty. I'll remove them when everything is set, everything will be covered up with the next layer. My feet give an idea of the scale. It's big.
View attachment 145862View attachment 145863View attachment 145864
So, cutting through the bulkheads didn't foul up the intregrity of the framing?I"ve got the gunport patterns installed. You really need to carefully measure to get them installed correctly. I still had to cut out several bulkheads and deck sections to make room for the dummy cannon boxes. This is also my first try at using the brass nails. Not pretty. I'll remove them when everything is set, everything will be covered up with the next layer. My feet give an idea of the scale. It's big.
INTEGRITYSo, cutting through the bulkheads didn't foul up the intregrity of the framing?
