Hi Lawrence ,your Oliver Cromwell looking great!!I guess no rigging for this one just stub mast?
     As a way to introduce our brass coins to the community, we will raffle off a free coin during the month of August. Follow link ABOVE for instructions for entering.  |
Hello Zoly, I thank you very much for your visit to my build log, also for your very nice comments. Yes there will be Rigging that is for sure. The stubby Mizzen Mast is just to protect the Binnacle against breakage as it is wired in for lights. Thanks for all the Likes.Hi Lawrence ,your Oliver Cromwell looking great!!I guess no rigging for this one just stub mast?
Great looking wheel. Very curious how you went from solid circle to spoked wheel.
Jan
He Jan, sorry I left that part out, after cutting out my circle out on my disk sander I then scribed the inside of the wheel rim. I then cut out to almost to this scrive line using my Jewelry's Saw . I then used needle files to come out to the line. The spokes were turned in my Dremel not all that great but the best I had having no lathe at hand. The spokes were tapered on two sides on the inside end so that they all came together. I then lay my wheel on a flat surface moving each spoke back a bit as to apply my glue and putting it back in place. I then cut the center drum and turned one end down on my drill press the thickness of the spokes plus a little wood disk to hide and attach to the ends of the spokes and then glued it up. This would have been very simple with a lathe, but with ought one this is the best that I could do.
Hope this helps, this was a very pleasant and enjoyable part of my build. You would find it fund to try.
Regards Lawrence
Hello Jim, I thank you for your visit to my build log, also for your very nice comments. The sizes for my wheel I took from my TFFM book and the mounting brackets from my HMS Bounty book, and this is what I came up with. Harold Hahn does show the wheel on his plans but with very little detail. However this was a fun thing and a very rewarding thing to build.Great results Lawrence!! The wheel is a model itself, and it is perfectly fit on the desk.![]()
Thank you Maarten, I thank you for your visit, and also for your very kind words. Thanks again for all of your likes.I missed a lot in a week, wonderfull progres.
Hello Uwe, No problem, Thanks for your visit and also for your very kind words.Hallo Lawrence,
I made a longer time no comment on your log, sorry for that - very good looking work and good progress![]()
 Dave.Hello Nova Storm, I thank you for your kind words. Welcome to my build log, your words and comments are always welcome here. Please pull up a chair and join in the fun of building this little ship. Please stop by often as the door to the Old Ship Yard is always open. May I ask what part of Nova Scotia you come from, just curious!Beautiful work!
