Santa Maria - Mantua - scale 1:50 modified kit semi scratch and diorama
zoly99sask
Well-Known Member
Administrative
Moderator
#1
Hello fellow ship model builders ,this is my new build log for the ship Santa Maria.Updates are coming soon.
Zoltan
zoly99sask
Well-Known Member
Administrative
Moderator
#3
Hello everyone,before I start my build log I have a few interesting pictures for you.My last year visit at West Edmonton Mall in Edmonton,Alberta,they have a Santa Maria replica inside the mall,here are a few pictures of the ship.
IMG_3294 (1920x1280) (640x427).jpg IMG_3304 (640x427).jpg IMG_3319 (427x640).jpg IMG_3307 (640x427).jpg IMG_3364 (640x427).jpg IMG_3317 (427x640).jpg
Zoltan
zoly99sask
Well-Known Member
Administrative
Moderator
#6
Thank you very much, Eric, yes the replica is full-size.
Zoltan
zoly99sask
Well-Known Member
Administrative
Moderator
#7
The instruction booklet has no written instructions whatsoever just pictures,they are good for guidelines but in my case, that means nothing because I will heavily modify the kit.
IMG_2469 (800x533) (2).jpg IMG_2471 (800x533) (2).jpg IMG_2472 (800x533).jpg IMG_2473 (800x533) (2).jpg IMG_2474 (800x533).jpg IMG_2475 (800x533) (2).jpg
Zoltan
zoly99sask
Well-Known Member
Administrative
Moderator
#8
Thank you very much Denis for looking in ,I have plenty of sitting area for the followers. :D
I am sharing the rest of the kit supplies, the blocks, and the rigging lines are gonna be replaced for sure,the rest just don't know yet.
IMG_5790 (640x427).jpg IMG_5791 (640x427).jpg IMG_5793 (640x427).jpg IMG_5799 (640x427).jpg IMG_5802 (640x427).jpg IMG_5803 (640x427).jpg IMG_5804 (640x427).jpg IMG_5805 (640x427).jpg IMG_5806 (640x427).jpg IMG_5808 (640x427).jpg IMG_5811 (640x427).jpg IMG_5812 (640x427).jpg IMG_5813 (640x427).jpg IMG_5814 (640x427).jpg IMG_5815 (640x427).jpg IMG_5810 (640x427).jpg
Zoltan
zoly99sask
Well-Known Member
Administrative
Moderator
#9
After removing the laser cut bulkheads and the backbone and two part special reinforcing parts securing the bulkhead I did dry fit test.
The backbone/keel
Bulkheads and the rest of the framing parts
Zoltan
zoly99sask
Well-Known Member
Administrative
Moderator
#11
As for the simulated planking,I will use it as a subdeck and going to plank it with real wood as the title of the log says "heavily modified".
Zoltan
Donnie
Well-Known Member
Madison, MS
#12
WOW !!!
Very impressive on all of it !!! Seems like a well designed kit to build. Can't wait to see this one come to life !
Donnie
zoly99sask
Well-Known Member
Administrative
Moderator
#13
Hello to all ,I have some updates, little bit behind with updates.
Dry fit the framing.
Zoltan
zoly99sask
Well-Known Member
Administrative
Moderator
#14
Installing the bulkheads was a little bit interesting, first I had to slide into one of the reinforcing parts one by one each bulkhead, the interlocking slots must facing outwards and after the second reinforcing part slides in with interlocking slots facing also outwards just the opposite side.Here are a few pictures I took from the instruction booklet showing these steps.The instruction manual free to download.
http://www.cornwallmodelboats.co.uk/manuals/mantua/775.pdf
2016-07-19 20.40.13_000 (800x600).jpg 2016-07-19 20.40.33 (800x600).jpg 2016-07-19 20.40.41_002 (800x600).jpg 2016-07-19 20.42.58_001 (800x408).jpg
With this method no need for more reinforcement between the bulkheads , the whole structure really sturdy and not even glued in yet.
Zoltan
zoly99sask
Well-Known Member
Administrative
Moderator
#16
Hello again, started to install the first few bulkheads with the help of two square ruler to keep everything square, adding bulkheads, now number 4, I started with number 3.
IMG_5102_wm (800x449).jpg IMG_5103_wm (1920x1079) (900x506).jpg 2015-11-08 13.17.30_000 (800x600).jpg 2015-11-08 16.17.01 (800x600).jpg 2015-11-08 16.17.39 (800x600).jpg 2015-11-08 16.17.56_wm_000 (800x600).jpg IMG_5106 (800x449).jpg
Zoltan
zoly99sask
Well-Known Member
Administrative
Moderator
#17
Fitting bulkheads continues.​
Bulkhead number 5
Bulkhead number 6 and 7
Bulkhead number 1,2 and 3A also fitted, 3A supports the quarterdeck
Zoltan
zoly99sask
Well-Known Member
Administrative
Moderator
#18
Bulkhead number 8 fitted and glued in and the whole reinforcing structure with the installed bulkheads is mounted on the backbone/keel and glued in, bulkheads number 9 and 10 also fitted and glued in on the keel.
2015-11-11 13.16.11_000 (800x600).jpg 2015-11-11 13.16.20_000 (600x800).jpg 2015-11-11 16.15.55_wm (675x900) (600x800).jpg
Stern frame fitted and glued in
Zoltan
zoly99sask
Well-Known Member
Administrative
Moderator
#19
Time to do some fairing, looking through the bulkheads I realized that bulkhead number 2 needs some shimming on the port side.
IMG_5124 (800x533).jpg 2015-11-11 16.59.42_wm (1440x1920) (600x800).jpg IMG_5125 (800x533).jpg 2015-11-11 17.53.11_wm (1920x1440) (800x600).jpg
Zoltan
zoly99sask
Well-Known Member
Administrative
Moderator
#20
After finished installing the bulkheads and some initial fairing and shimming I decided to add little more reinforcements at forecastle and stern area.
And at stern between bulkheads number 1,2 and 3.
Zoltan
