I have continued with the planking working my way down towards the Keel. I have taken my time with this, fitting one plank a day, trying to make sure each plank fitted up tight to the one above. I hit a problem about half way through with the C.A. glue, it must have started to "go off" because it would not stick the planks to the Frames, it would stick the planks to my fingers though. I have noticed this before, when you want something to stick it won't, when you don't it will stick. In the process of planking I also managed to break the tops off of a couple of Ribs and one frame, but they can all be repaired. I was so busy trying to get the planks in place before the glue set that I didn't pay attention to where I was holding the boat.
Master Korabel give you 2 each of the last plank next to the Keel, one is wider to allow for any variations in the planking. The gap that I had was narrower than either of the 2 planks so I had to gradually adjust a plank to fit, at least I had a spare one in case of any problems. I just need to rub the Hull down now before I remove the frame supports on the inside. There are a few small gaps between a couple of planks, that's the trouble with using Macro Mode on my phone camera, but if you hold the boat at arm's length you can't see any gaps, and in hot weather "all the boards did shrink" see Rime Of The Ancient Mariner by Samuel Taylor Coleridge.
Cheers Andy
Cheers Andy
