Dakkadakkadakkadakka!
Oh what a picture!
A couple of months ago, on finishing a ten month long (long for me) wooden ship project, I was sick and tired of modelling. It seemed to me then that I'd never want to re-enter the miniature world. Well, it turns out that I needed three things to pull me back in. First, i needed to take a good long rest until the last project started looking good even to its most bitter critic - myself. Second, I needed a short term project, no more than a month's worth, with no pressure to do anything exceptional. It was to be "just for fun".
Third was that inspiring painting on the box of the new Airfix Anson Mk.1.
It depicts an event of the 1st June 1940. While on patrol over the evacuation beaches of Dunkirk the three man crew of this obsolescent aircraft from 1935, engaged and SHOT DOWN two Bf109Es and damaged a third. I bet any surviving bad guys all claimed to have been hit by a Spitfire! It was a combat with a happy ending and well worth commemorating in plastic 85 years later, wouldn't you say? I'll aim to be finished by June 1st at the very, very latest.
This is a crackerjack kit. Airfix have long been associated with the cheaper, 'toy-like' end of the model kit market but in recent years they have improved their standards of fit, detail and complexity time after time. While this is not yet quite comparable to the wonderful engineering of Tamiya, nor is it anywhere near Japanese prices. For me it's very affordable and straight out of the box should produce a very acceptable model.
I've already started.
My first step in a plastic build is to cruise through the instruction manual cleaning up parts and making as many sub-assemblies as possible before painting. This trayful represents an evening's work and everything here will be receiving its sprayed base coat of interior green before further detail painting with a brush. The idea is to be efficient with my use of the airbrush and use it the minimum number of times. It takes a few minutes to set up and tear down my spray bay and I don't want to be repeating that tedious process over and over, even though I really enjoy the actual spraying.
The cockpit framing is going to look amazing but at this point it's going to prevent me making much progress on sub-assemblies as it will restrict access for the paintbrush. That's not always the case and on many aircraft kits I'd be building in a lot more before painting.
Yes, I know the roof looks a mess. It will be in the shadows and very hard to see so I'm no more bothered about the ejector pin marks than the good people at Airfix were. It's good enough.
These are two side frames of the port wheel well. The one on the left is pretty good considering that it will be very difficult to see in situ. The whole assembly will be sprayed silver and then shaded with an oily wash and the moulded lightening holes will look fine. I still couldn't resist drilling them out though - just for fun.
Notice that there's a little burring and the holes look generally ragged.
They still look bad at this magnification, don't they? Believe me, most of that is invisible to the Mk.1A eyeball now that it's been treated (left) to a swift swipe with Tamiya Extra Thin cement, dried with a breath. Ideally, I'd use the gentler, quick setting one but I had none so the usual stuff did the job.
It fitted together perfectly and has made a strong framework for attaching the undercarriage to the wing spars, just like the real thing.
That's how far I've got in two sessions. There's no rush to finish because compared to our usual models, there's so little of it. It is possible to over complicate things like this if you wish, but I'll be keeping things fairly simple on this one. Apart from the painting. I like fancy paintwork and I have a few ideas to try out.
It's been years since I enjoyed myself this much with plastic. I hope you enjoy reading about it too.
I''ll see you again when there's something worth the seeing.
Oh what a picture!
