Bravo - it is looking very good
The open structure is looking very nice, Donnie. A good choice. Also for dry adding the treenails. The linseed oil will point them out a bit.Here's the latest. I think I am done with the deck planking. I on purpose left out a lot of strips so that the lower deck can be seen. The cannons are just in place - there is no rigging yet. I have to order more supplies from Zoltan. The blocks will be 2.5mm this time to complement the smaller size cannons.
In the meantime, I will add treenails to the decking. All I do is drill the holes and push the toothpicks in and cut them off. I do not use glue as the likelihood of them coming out is unlikely. Besides the Linseed oil will help seal them in. This way, I do not have to worry about scrapping glue.
That's using your noodleThank you all for the kind words.
The latest. Finally got all the treenailing done on the top deck. Please read a special note below after images !!!
PLEASE NOTE: Part number SB - if you are planning to rig cannons, DO NOT glue this piece in - but only dry fit it. Then before removing, mark off the locations for the Ring Bolts that will be installed onto SB. Then when marked, remove SB. Then you can install the Ring Bolts with no problems along with the Pulleys. After which, then install SB with all the Ring Bolts already attached. This would be easier rather than trying to install Ring Bolts later.
I like this photo very much - good work my friend
