Bokapi wood strips - planking
Pwh
ottawa,ontario,canada
Starting on the 1st layer planking of Scottish Maid (AL) using 2 x 5 mm strips. What is the best method for bending this hard wood?
Peterborough Ontario Canada
I can’t say I’ve ever really heard of this type of wood. I looked it up on my wood database and received the reply “not found”. I’m guessing this is a name given to another actual type of wood.
I’d say take a strip and soak in water for a bit to see if it will bend. All wood will bend to some degree but some are more difficult than others. Sorry if this sounds simplistic but I’ve had zero experience with this wood.
John
Pwh
It’s an old kit and has a number of bokapi wood. I tried soaking in water and it does bend a bit. Tried using a plank crimper but the wood is to brittle. Not sure why the kit would use such a thick hardwood for the 1st planking. I might try a different wood.
