look good Guy
Good evening Guy. Lovely model. I like the map base. Cheers GrantI used the airbrush to darken the sails. The base now has the two maps of Smith's journeys around the Chesapeake on it, and I just glued down the cradle and the hull. I need to solder the battery and switch to the leads for the LED light in the lantern. A drawer goes in the empty space in front to hold the switch. The sides of the case are finished and the pieces for the top are cut but need to be painted before installing them. I can see light at the end of the tunnel!
Hallo @GuyHI started this kit in Nov. 2022, and have been keeping a log with comments and pictures. It is a Word document, attached below. I can convert it to pdf if anyone wishes. This is my first log here in SOS so learning as I go. I can attach updated logs as I make progress, or post pictures, questions, and comments one at a time here in this thread.![]()
I am about to start this kit, and found your build log. I must say I love the format (I did convert it to a pdf) - easy to read with commentary and photos. I look forward to learning from your experience!
Many thanks, CarlThanks, Carleroo, that is very gratifying. I found this kit to be challenging but fun to complete. Feel free to contact me if you have any questions about it as you build your model.
Guy
Hello Guy,Thanks, Carleroo, that is very gratifying. I found this kit to be challenging but fun to complete. Feel free to contact me if you have any questions about it as you build your model.
Guy
Happy birthday !Ignore my earlier question about the order of the frames. I looked ahead in the instruction manual and the answers were there, in front of my face!
Thanks!!Happy b-day Guy
Kept my Shallop dark - no paint. Didn't think I'd like it painted. But I like your painted Shallop. Nice work too, BTW. Fun to look closely.I used the airbrush to darken the sails. The base now has the two maps of Smith's journeys around the Chesapeake on it, and I just glued down the cradle and the hull. I need to solder the battery and switch to the leads for the LED light in the lantern. A drawer goes in the empty space in front to hold the switch. The sides of the case are finished and the pieces for the top are cut but need to be painted before installing them. I can see light at the end of the tunnel!
