Thank you Heinrich!Dean this is absolute beautiful eye candy. The standard ties in beautifully with the overall look of the ship and accentuates and contrasts the hull in just the right ration! Very well done!
Dean, I am pleased to see you talk about wooldings in this thread. I don’t remember seeing anyone else discussing them in their threads. (Bad pun)Started the wooldings on the main yard...9 on and 10 to go. 7 wraps each!
I think wooldings should be black or dark brown for standing rigging. I think it’s odd they suggested running rigging for them! And they should be a large size rope.Dean, I am pleased to see you talk about wooldings in this thread. I don’t remember seeing anyone else discussing them in their threads. (Bad pun)
My admiral is afraid I will break her sewing machine!Hi Dean,
Lovely to read your Admiral is willing to help with the sails.
Building Le Mirage, my Admiral told me how the machine works and wished me succes.
But it's nice that she was confident.
Thanks for information Dean.I want to talk about rope for a minute. For those of you who may build this ship, the supplied rope is not enough!
This is what they give you, plus one more roll of the .15 rope that was used up by the time I finished all the shroud lines!
they tell you to use the .15 rope for mast wooldings...I chose to use the above waxed black rope for the masts and bow sprit wooldings.
Even then I’m almost out of the .15 rope that I need for the yard wooldings. There won’t be enough left to do everything else at that point.
They want you to use that for all the running rigging on the sails and yards!
I chose to use white rope for the sails running rigging.
They don’t provide any.
luckily I have a lot of extra rope to chose from...
So I chose the above white rope for the sails, and the rope to the left of that for all the running rigging for the yards.
The large yard ropes to hang it, are going to be the dark .50 rope.
In conclusion, my rigging will be color coded and have some variety.
This would not have been possible using what was supplied. In retrospect I should have purchased better blocks. I’m doing that after this build to have a good surplus on hand.
I ran out of blocks too...sigh! But I had extra, so I’m using them!Thanks for information Dean.
Curently I’m working on OCCRE’s Montanes and just begun the masts. After reading your post I understand that most probably I’ll need extra ropes for rigging.
Best regards.
What is a parrel for?Today I was able to finish the main yard. There was a lot of ropes and pulleys to attach. And I had to make the parrel and attach it.
I put the first rope through the upper two center holes...
then I came back through the lower center holes, adding beads as I went...
then I added a rope and beads to the outer two rows. No one told me you had to make necklaces when building a ship!
Anyway, then I tied a rope through the two rope loops on the right side to attach to the yard.
On the left I tied the upper two ropes and the lower two ropes. Glued and trimmed one rope. Then I tied the inner two ropes left together in the center, then glued and trimmed one rope. That way I had one rope to tie onto the loop on the yard I made for attaching around the mast.
on the yard and glue is drying.
So the yard is done and I will go over it and do any touch up required.
now to get the admiral to sew the main sail tomorrow!
Then I will add reef ropes and tie to the yard and get ready to raise the yard on the mast.
I hope to get this main mast, yard and sail up and rigged this week.
Then next week the foremast! Then I’m done...and on to the POF Bluenose!
I will have to build a display case at some point soon.
It wraps around the mast, and acts like a bearing to allow the yard to swivel and move up and down on the mast. They usually used wooden balls and plates on ropes to make them.What is a parrel for?
Parrels (Racke; Racaggers)What is a parrel for?
Ken,Hi dean, Looking good there. I’m impressed with the neat organised way that you store your cord and stuff, I wish that I could get my head around storing things as well but if you look at my stash it looks like it was organised by a mad woman. In comparison see my wife’s sewing tray, I made it for her some years ago and there is never a thread out of place. I’m banned from touching any of it under the threat of dire consequences and any sail making costs me dearly, at least a meal out in a fine restaurant.
I have no experience bleaching wood. You could however dry brush a lighter color on top and let the dark grain pop. Of course that is painting wood, and won't look as good as stain or natural wood. I would definitely test any modifications to the walnut prior to using on the ship!Hi, I’ve just got my Euromodel Ajax, more of that later but checking it out I see that they have supplied walnut for the decking, I regretted initially using it on my Amerigo and I don’t want to make the same mistake again. I was thinking that bleaching it might do the trick, does anyone have experience with this or do I just bite the bullet and buy some new stuff
