It was at this point I decided to check some of the kit fittings to see how they would look. There is a large carburetor vent on the engine hatch. When I put the part on the hatch I knew there was going to be a problem. On the real boat the vent does not touch the dark center plank. As you can see in the photos of the prototype the vent is over partially onto the center plank. If I moved it over to keep it off the center plank it would be too close to the hinge strip. I was annoyed with this issue because it could have been addressed back at the beginning if I had noticed it. The only thing I could was make the hatch wider. You can understand why at this late date I didn’t really want to cut the deck planking. Did I mention I was annoyed? Should I just leave it and go with the kit placement I asked the First Mate. She said I would be happier if I fixed it.
After an adult beverage and staring at it for awhile I got to cutting. I just had to go slow and make several thousand cuts with a #11 blade. I kept seeing the blade go skittering across the deck hatch and really messing it up. Fortunately this did not happen and I got both deck planks lifted off and attached them to the hatch. It is not a perfect patch but it got me the room I needed.
