CUTTY SARK- ARTESANIA LATINA-1:84
I am a little be anxiuous when I saw beautiful works and ship : wich one will be the next build for me ? too much choice and not enough time and money !
Thank you sir. I have not built enough kits to give a fair recommendation ( only 3 including this one) but artesanias older elite series ships seem to be quite detailed and would recommend them if you can get a hold of them.
Regards
Hi all.
the channels have been fitted as well as the larger deadeyes(i am busy with the smaller ones). I messed up with the channels in the provided mohogany so i used some left over walnut. I also fitted some of the features on the front of the boat. The anchor davits were quite tricky as the instructions are blurry. The front railing has also been fitted.
regards.
Hi all.
regards.
Good morning. Looking very good.
Hi all. This will be my first build log and will be of my 3rd model ship kit. I started this build back about a month ago and have only now thought to do a log. Not many photos have been taken up until this point. I will post the photos that I have up until today. I will then update you all as I go on to another step. Feel free to ask any questions or comments regarding the build, where I can improve etc…
Regards
Hallo @joocy
we wish you all the BEST and belayed a HAPPY BIRTHDAY
Hi all.
a milestone has been reached. All deck fittings have been added and the whole deck has been varnished( unfortunately, the metal pieces on which the 3 lifeboats at the back rest are too small and are broken. I have decided to hang two of the lifeboats on the rear davits). The next step is to fit all the eyebolts and anchors etc.. and then its onto the masts and rigging.
kind regards
Hi all. Small update.
the bowsprit is done and work has started on the foremast. Alot of the metal pieces’ rings came broken as can be seen in one of the photos. I have thus far used the intact ones. Any ideas to fix or substitute are welcome. Ordinarily, i would just super glue the broken pieces but the broken off rings are nowhere to be found. Maybe i just have to insert extra eyebolts in the mast or is there a more elegant solution? All comments and suggestions are welcome.
kind regards
kind regards
Good morning. Lovely work she is looking good. Broken and lost kit parts are super frustrating. Especially here in SA where replacements are hard to come by. I would see if you can find same sized rings from a bead shop (Beads for Africa) and solder these back onto the main mast ring. Also check out Jix Hobbies (From Pretoria) on line they carry some AL parts. Cheers Grant
