- Jun 17, 2021
Any port in a storm!
Thanks, Pug.Peter I admire your determination.
A lesson not to give up; sit back, think about it and carry on.
Recognising an error is not a failure, just change your tack and feel the rewards.
Seems to me, you're making all the right onesMostly there's no other choice.![]()
Got a Deja-vu by this quota of you. I did the same with my Bluenose and that they also differs from each others.I've been comparing all the clipper rigging plans I have,
I believe originally chain. Then rods with couplings. Mine are synthetic line, wrapped around the deadeye the two sides glued together with CA, threaded through the holes in the channels and nailed with tiny brads through the ends.Were the original ships lower deadeyes straps, rods or chains.
How are yours made, Peter?
had the drill down to a science AND an art!)
use a pretty fine grit. It' easy to take off too much too fast. Any scratches you put into the wood have to come out later. Try to find the half-life of getting to the finished piece. If you get to the edge, you've gone too far.
